Hi, first thank you for all your Work.
I have the same Issue, the Trigger never âfireâ. I used HA Calender and tried like your Video, but i donât find a mistake.
same here sadly
@Blacky thanks for this blueprint, it works great! I have one request: is it possible to add the possibility of choosing a custom notification icon?
Itâs the notification status bar icon as per the docs Introduction | Home Assistant Companion Docs
It would be great if you could add support for it ![]()
Itâs the same for me. I use another HACS integration called chore helper (Chore Helper - Track recurring or manual chores with flexible scheduling) which creates its own calendar with full day entries as well and I have the exact same problem that the start seems to be never triggered. And my automation is more than basic:
alias: Kalender Chore
description: ""
use_blueprint:
path: Blackshome/calendar-notifications-and-actions.yaml
input:
calendar: calendar.chores
include_calendar_trigger: disable_key_word
include_start_notify: enable_start_notify_options
start_notify_data:
- sticky
- high_priority
start_notify_device:
- 9544dc2deb9ccc0acb20338639131160
- cf3099cc85bc3ea995a6e85d689e591a
Any chance that we can set up something like this as trigger:
- platform: state
entity_id:
- calendar.ferien
to: "on"
- platform: state
entity_id:
- calendar.ferien
to: "off"
Would maybe help.
Looks like they have a know issue. Have you taken this into account and maybe applied and offset?
âThere is a known issue I havenât resolved yet related to how bare dates show in the Home Assistant UIâthey always appear a day early for some reason, even though the underlying value is correct and shows up right on the calendar. For example, the due date in the screenshot below is actually 4/10/2023, but it shows as the 9th within the attributes. I donât know why this happens yet.â
Blacky ![]()
There is not one single trace. So I think it is never triggered anyway or am I wrong? So I donât even know how to debug this. As well when I only get the chance once a dayâŚ
Yeah, it is probably how they made the integration. I have worked of the official HA calendar.
Maybe you can replace the trigger in the blueprint to what you think it should be, like this.
triggers:
- platform: state
to: "on"
entity_id: !input calendar
offset: !input start_calendar_offset
- platform: state
to: "off"
offset: !input end_calendar_offset
Then it may work for you.
Blacky ![]()
I now set a start_calendar_offset. I donât know why it works then.
description: ""
use_blueprint:
input:
start_notify_data:
- sticky
- high_priority
start_calendar_offset:
hours: 6
minutes: 12
seconds: 0
days: 0
Whatâs not good is that as I add a start_action_button the notification will not arrive on my phone anymore. Why?
description: ""
use_blueprint:
input:
start_notify_data:
- sticky
- high_priority
hours: 6
minutes: 38
seconds: 0
days: 0
start_notify_interruption_level: active
include_start_action_buttons:
- enable_start_action_button_1
start_action_button_1: Erledigt
include_start_action_button_confirmation: enable_start_action_button_confirmation
start_time_delay:
hours: 12
minutes: 0
seconds: 0
start_action_button_confirmation_title: "{{ trigger.calendar_event.summary }}"
start_action_button_confirmation_message: Der Task wurde erledigt.
start_time_delay_confirmation_message: Der Task wurde Ăźbersprungen, da die Zeit abgelaufen ist.
start_action_1:
- action: chore_helper.complete
metadata: {}
entity_id: >-
{% set event_name = trigger.calendar_event.summary %} {% set
found_entity = states | selectattr('name', 'equalto', event_name) |
map(attribute='entity_id') | list %} {{ found_entity[0] if
found_entity | length > 0 else 'none' }}
start_action_button_stop_confirmation_message: Abbruch
So you got it working now⌠that is good. Just take note of the known issue in the integration your using. As my above post it is 24 hours out "is actually 4/10/2023, but it shows as the 9th within the attributes. "
This is because your have no text in the Start Notify - CANCEL Action Button
Enter the names for all enabled Action Buttons below, including the CANCEL Action Button. Missing any button names may prevent the automation from functioning correctly and could result in not receiving the notification.
Once you add the text âStornierenâ say to the Start Notify - CANCEL Action Button input you will receive the notification.
Blacky ![]()
Thanks @Blacky for your help and Blueprint.
Iâve tried to get it running with a local ICS Calendar⌠but same - no trigger.
Iâm giving up for now and will see if this may be a thing in the future ![]()
Thank you, it finally works for me. I will adjust your blueprint a bit for my case as I would like to have a non-swipeable notification in this case. So it needs to be permanent on Android. I will delete it in the action buttons.
And I want to change the icon and icon color (only possible on Android) to really see it is a task for me because itâs a task calendar. If I have changed it and it works do you want the result?
Okay wow I underestimated how big the blueprint is. Not sure if Iâm able to change it so easily :')
Your welcome.
All good, I know how to do all the code and I would like to keep this post for the actual blueprint.
Blacky ![]()
Hi Iâm looking forward to implementing this â I added an all day event with the keyword #birthday# to my calendar and filled in the Blueprint to create the Caltest automation.
alias: Caltest
description: ââ
use_blueprint:
input:
calendar: calendar.my_cal
calendar_trigger: â#birthday#â
include_start_notify: disable_start_notify_options
start_notify_data:
- high_priority
I notice that when I do a manual run-actions of the automation the log shows:
2025-03-12 10:36:11.067 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: âdict objectâ has no attribute âcalendar_eventâ when rendering â{{ trigger.calendar_event.summary }}â
2025-03-12 10:36:11.068 ERROR (MainThread) [homeassistant.components.automation.caltest] Error rendering variables: UndefinedError: âdict objectâ has no attribute âcalendar_eventâ
2025-03-12 10:38:07.842 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: âdict objectâ has no attribute âcalendar_eventâ when rendering â{{ trigger.calendar_event.summary }}â
2025-03-12 10:38:07.842 ERROR (MainThread) [homeassistant.components.automation.caltest] Error rendering variables: UndefinedError: âdict objectâ has no attribute âcalendar_eventâ
You cannot do a manual run of the automation.
You also need to set up your notification correctly. You need to enable a start or end notification and set up your devices to be notified.
Blacky ![]()
Thanks was that âyou cannotâ or âyou canâ do the manual run?
Once I enabled the notifications all works as advertised. Thanks for sharing this it will be very well used in our implementation. I want to experience the automation for a while and then make any suggestions. Some kind of common pre-defined notifications comes to mind like trash day type, or birthday or even weather event at expected time. But maybe these are all just manual defined due to the users specific needs.
