Calibration of aqara temperature sensors
Yeah, this is called ‘splitting your configuration’ (otherwise you end up with a 10MB configuration.yaml (exaggeration)) but splitting makes managing changes easier and more logical AND tracking down where you put the customisation for ‘this’ widget a LOT quicker.
You can split individual areas as you are doing now, so input_number, binary_sensor, automation etc or you can use packages. My configuration.yaml has 27 lines in it, 3 of them comments.
It would be nice if there was something like this:
homeassistant:
  customize:
    sensor.aqara123:
      calibrate: -2
I’ve created a feature request to have something in the UI to do this for us, vote on it if you’re still interested in a simpler method than what’s currently avaliable:
I am trying to calibrate the humidity from an Aqara Temprature sensor.
I use the following script:
And get:
Any idea what I could be doing wrong?
Please post code not pictures of code!
Your issue is that sensor: at the beginning has to be all lowercase.
Which Zigbee integration do you use for your Aqara sensors ?
You can probably configure your temperature offset directly in Zigbee integration which would be much more cleaner.
I have a Conbee and I think the only integration used is Phoscon, right?
It appears all my sensors are significantly low on humidity, the output is low and I compared them with sensors already in place in the Aqara app. Would be great with a smoother option since the sensors can become quite many.
The most common ‘universal’ Zigbee integrations in Home Assistant are probably : ZHA, Zigbee2MQTT and Deconz.
I don’t about about ZHA or Deconz, but I know that you can configure temperature/humidity offsets in Zigbee2MQTT plugin configuration. It’s probably also available in ZHA and Deconz.
Aha, then it must be DeConz I am using. I will look up the other option, thanks!
I love you! Thanks! It works!
You are using deconz then, deconz doesn’t have this feature to offset sensors as far as I know.
Hey everyone! I am trying to add 1 tenth of one degree +.1 to my bedroom temperature. when I put it into configuration.yamal it confirms the coding is correct. When I go to validate the configuration all I get is a throbber that never returns a valid or invalid configuration. So what am I doing wrong? Newbie here when it comes to coding! Thanks for any help.
    sensors:
      corrected_temperature:
      friendly_name: "Bedroom Temp"
      value_template: "{{ states('sensor.bedroom_temperature')|float + .1)|round(1) }}"
I use following code for this an works perfectly:
template:
  - sensor:
      - name: Temperature Library # calibrated
        state: >
          {{ states.sensor.multi_sensor_library.state | float(default=20) - 0.5 }}
        unit_of_measurement: "°C"
