This may be a naive question and showing how far my education in python has to go but I’ve started migrating all my more complex automations to AppDaemon over the past couple of weeks - and just want to confirm the best way to achieve this.
I know this example below doesn’t work - but it’s the easiest way to show what I’m trying to accomplish - what would be the best way to go about achieving a similar result?
import appdaemon.appapi as appapi
# Test App
class TestApp(appapi.AppDaemon):
def initialize(self):
self.listen_state(self.test, entity='input_select.house', new="Sleep")
def test(self, entity, attribute, old, new, kwargs):
self.run_in(self.call_service("homeassistant/turn_off", entity_id="input_boolean.speech_notifications"), seconds=5)
Essentially (like everyone else here ), I have an app that sets house mode. Morning/Home/Sleep/Away etc.
When each mode is set, particularly with ‘Sleep’ and ‘Away’, I’d like certain things to happen in a particular order, with delays after specific actions.
I know I could just use self.run_in() as documented and define separate functions for the tasks that need to be delayed - but (and this is where perhaps I’m being naive) it seems like overkill to define a new function for a single callback to dim the lights, and another to turn off the TV, etc for the purposes of putting 30 seconds between them.
Happy to be corrected and told that is the correct way to do it, but just wanted to check there wasn’t a “cleaner” method.
If I created a specific worker thread via queue to handle these operations, would it be save to use time.sleep?
Thanks!
