Hello guys,
I have a Welcome and a Goodbye routines, that are turning on or off lights in my apartment. (AppDeamon)
Tonight I tried to add some “sequentiality” to the routines, so that the lights are either turning on or off in a nicely timed sequence…
In order to do so I tried to write some code that is trying to achieve (functionally) this :
“Call this particular service in that amount of delay”
So I tried to mix run_in and call_service… and I never managed…
I am debugging my code since one hour now and I am starting to get desperate
I ended up creating an intermediate callback function and I find my solution really ugly.
It is working but I am not really proud of the execution.
See for yourself :
Helper method:
Does : Turn on the lights of the entry, living room and kitchen
Returns : Nothing
def act_on_arriving_home(self, bom):
if bom["action"]:
self.say_something("greeting")
self.run_in(self.helper_call_service, 1 , service = 'light/turn_on', entity_id = "light.entry_lights", transition = 3, brightness_pct = 100)
self.run_in(self.helper_call_service, 3 , service = 'light/turn_on', entity_id = "light.living_room_lights", transition = 3, brightness_pct = 100)
self.run_in(self.helper_call_service, 5 , service = 'light/turn_on', entity_id = "light.kitchen_lights", transition = 3, brightness_pct = 100)
Helper method:
Method present mostly because I am too dumb and did not managed to bundle the run_in and the call_service in one shot :)
def helper_call_service(self, kwargs):
service = kwargs["service"]
kwargs.pop("service")
self.call_service(service, **kwargs)
I saw a reply in this post that seems to indicate that run_in() has been designed to be called with an external callback… But still I am interested in seeing a way to achieve what I want in one function…
If you find a more elegant solution and I all ears
Honestly I think it’ s my understanding of python that is the limiting factor here !
Regards,
Jenova70
