Camera troubles
Hey Guys,
So heres the thing, I have a very simple camera that live streams my hallway. I’m not sure what model it is but here is what I am sure of.
The camera live streams on this IP - rtsp://10.8.X.X:XXXX/test
All I do is connect to a VLC using this link and volia! I’m watching the stream. (Local Network is a must)
I tried many configurations to connect my camera to HA. The only one that looks is…
- platform: ffmpeg
  input: rtsp://10.8.X.X:XXXX/test
The stream is showing on my HA but the quality is absolutely horrible, the resolution is frightening to look at.
Any idea of how I can improve it? I thought its probably from the platform I choose but generic doesn’t work for me.
Here is what I found in my logs as well
Logger: haffmpeg.core
Source: /srv/homeassistant/lib/python3.8/site-packages/haffmpeg/core.py:162
First occurred: 4:06:38 PM (2 occurrences)
Last logged: 4:07:03 PM
Timeout while waiting of FFmpeg
have you looked at the addon Home Assistant Community Add-on: motionEye - Home Assistant OS - Home Assistant Community (home-assistant.io)?
That would allow you to integrate it and even have more functions
Hey Piggyback,
Thank you for the recommendation, I wasn’t successful in installing the integration. MotionEye asked for URL, Admin Username, Admin Password, and Surveillance pass/user. Which I don’t have.
I also tried using WebRTC from HACS but the installation was bugged or something
not sure these are mandatoy fields, but I usualy find a lot of information in this page Connecting to IP Cameras (ispyconnect.com). If you can find the brand, you´re halfway there!
You would really need to figure out what model it is and maybe there is another URL for a higher quality stream. If you can’t find any brand or model number you could try this app, there is also same app available in Google Play if you have android:
But I have a feeling there is a URL other than test available. Is there a web interface for the camera or an app that does work with it? That would also point to the make of the camera.
