In short
Some things are currently very tedious to do with templates. I want to add some high level Python functions to simplify them.
i.e. I want to be able to do this:
- service: light.turn_on
entity_id: light.foo
data_template:
brightness_pct: "{{ my_custom_function() }}"
color_temp: "{{ another_custom_function() }}"
Is there currently any way to add my own Python functions and make them globally available in templates?
One example of why I want this
I really don’t like what I have to do currently to change light levels based on time of day:
entity_id: light.living_room_lights
data_template:
brightness_pct: >
{% if now().hour <= 6 %}10
{% elif now().hour <= 15 %}100
{% elif now().hour <= 18 %}80
{% elif now().hour <= 20 %}50
{% elif now().hour <= 22 %}30
{% else %}10
{% endif %}
transition: 5
This is super verbose, confusing and it doesn’t actually change the light level smoothly based on the time, it changes in chunks with a long transition so I hopefully won’t notice.
I’m kind of surprised this isn’t already better supported in HA (at least I haven’t found any other solutions) so I want to write my own Python method where I can declaratively set my light preferences based on the current time.
I want to write a function that does that, something like this:
data_template:
brightness_pct: '{{
time_based_value({
"00:00": 1,
"06:00": 1,
"08:00": 100,
"16:00": 100,
"20:00": 50,
"22:00": 20,
transition: 1
This function would check the current time, then print a value right in between the previous time value and the next time value. For example, if the time was 07:00, the above function call would output “50”. If the time was 07:30, it would output “75” etc.
This would be much more Pythonic than using long if/else chains. It also has the advantage that the transitions can be much, much shorter, so the light responds much faster when turning auto control on/off, or turning the light on/off.
Since this time_based_value
function doesn’t already exist, can I add it myself somewhere? Would it be as easy as adding it to the configuration somewhere, or would I need to jump through a lot of hoops like forking HA and adding it to the core?
