Sorry if this is a stupid question, but I’m just starting to transition from Smartthings to HA.
I have a bunch of HomeSeer HS-WD100+ dimmers around the apartment. So far I’ve only moved one over to connect to HA directly so that I can work out the kinks. I addressed the the known issue with incorrect reporting status by changing the refresh value to true and instituting a delay, but now I’m having trouble getting the dimmer to work with the Transition command.
I found this thread, and I’m thinking my problem is that COMMAND_CLASS_SWITCH_MULTILEVEL needs to be v2 or higher, but my zwcfg_ file shows v1.
Is that value provided by the dimmer? Is it something I can change in the zwcfg_ file? Would trying to upgrade the firmware do anything?
Thanks!
