Brendan4
(Brendan)
1
Pretty new to HA and looking for a Zigbee relay with the switch input decoupled from the relay outputs on a zigbee relay. I bought one of these as a test https://www.aliexpress.com/item/1005005719531451.html?spm=a2g0o.order_detail.order_detail_item.3.31bef19cMhJPQO#nav-specification
The relay and the switch are coupled permanently as far as I can tell. Is there any way to seperate?
webturner
(Stephen Turner)
2
I found something similar for a Sonoff ZigBee device and created a blueprint to do the decoupling in an automation:
Can you see if this does what you need?
