I just bought a couple of Sonoff ZBMINI Zigbee switches. They work well for me with regular “dumb” lightbulbs. I use a Raspberry Pi 4 with Conbee II Zigbee gateway, which runs deCONZ and Home Assistant software.
Currently, I assume the ZBMINI works as follows:
- SWITCH: connected to a light switch button, measures the position of the switch: open or closed
- RELAY: turns the power to the lightbulb on or off
- The SWITCH position is linked directly to the RELAY: when I change the SWITCH position, the RELAY state is toggled between on (provide current to the lightbulb) and off (do not provide current to the lightbulb)
- After pairing the ZBMINI with my Smart Home setup (Raspberry Pi 4 with Conbee II Zigbee gateway, running Home Assistant and deCONZ), I am able to control the relay from Home Assistant.
- I cannot seem to be able to read the SWITCH position from Home Assistant
This setup works well for regular (dumb) lightbulbs.
However, when using smart Zigbee lightbulbs (e.g. Philips Hue, IKEA TradFri), this behaviour is not desirable: when the RELAY turns off the power, the smart lightbulbs stop their function as a Zigbee router and are no longer reachable by the Smart Home platform.
In this case, I would like to use the existing physical switch as a software switch, that toggles the smart bulb in HA and does not touch the current flow.
The Shelly 1 smart switch solves this by allowing a user to configure the button as a “detached switch”, which unlinks the SWITCH and the RELAY:
- The SWITCH acts as a detached sensor: when changing the SWITCH position, the Shelly 1 sends an MQTT message which can trigger an action in the Home Automation software (e.g. toggling the smart lightbulb). The RELAY state does not change.
- The RELAY acts as a detached relay: its state can be changed through the Home Automation software.
- This allows a user to use the SWITCH to toggle the smart lightbulb, or initiate other action with any connected device really.
- The smart Zigbee lightbulb can continuously stay connected to power, allowing it to act as a Zigbee router.
Does this type of functionality exist for the Sonoff ZBMINI? If not, does anyone have any other recommendations on how to use a ZBMINI together with a smart bulb which acts as a Zigbee router?
