Can I use home assistant with an existing Qolsys iq panel (with IQ mini door sensors) to send text or email when triggered?
I used to use brinks home security and I still have all my hardware from that.
Qolsys IQ Panel (https://qolsys.com/iq-panel/)
and a bunch of IQ Mini door sensors (https://qolsys.com/iq-dw-mini/)
Can I use home assistant to arm/disarm that panel and those devices and have an email or text go out if the door sensors are triggered? Without using the brinks service.
In in the same position. Did you find a solution?
The closest answer I’ve found is integration through Alarm.com. https://www.home-assistant.io/integrations/alarmdotcom/
We are making some progress…
You can use this app in AppDaemon:
