I’d like to display, in one of my UI panels, a value that is derived by a simple calculation based on two sensors. I don’t need to use this value anywhere else. I could create a template helper but I was just wondering if there is a way to specify the expression directly in the UI element config somehow?
not all (in fact most) cards do not accept and display templates, however the mushroom-title-card does.
take a look at that and see if that gives you what you want.
Markdowncard would be an alternative as well.
Or if you use button-card
and/or mushroom-cards
(not only the title one @armedad
mentioned), you can define all fields via templating.
Something like this button:
Just create a template sensor and put that value in any card you like.
