Hi!
I cannot access the hassio-boot
partition on the SD card after flashing the correct image for my RPi 3B+ using etcher.
Tried on macOS as well as Windows.
Hi!
Try on linux if possible, I think MAC and Windows need some special drivers/software in order to recognize the boot partition.
Finally showed up but apparently its called hassos-boot
Saving my-network
with the following contents to ~/CONFIG/network
did not boot up my Pi
[connection]
id=my-network
uuid=72111c67-4a5d-4d5c-925e-f8ee26efb3c3
type=802-11-wireless
[802-11-wireless]
mode=infrastructure
ssid=xxxxx
# Uncomment below if your SSID is not broadcasted
#hidden=true
[802-11-wireless-security]
auth-alg=open
key-mgmt=wpa-psk
psk=xxxxx
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
I wouldnât need to put that file in there if not for this issue, where it supposedly cannot recognize the Ethernet linkâŚ
I strongly suggest to not use Wireless connection for your Home Assistant server, always go wired unless itâs not possible. Do you have no possibility to put it on a wired connection?
Did you read the post from the mod that this is not an issue but normal behaviour?
Honestly this would be a non-issue if add-ons were supported on âManual installationsâ, then I couldâve used my Pi 4.
With itâs stuck there, do you mean you canât access the web interface at all?
Whats the reason for not using your Pi 4 for this?
Nope.
Some progress have been made but the web UI is still not reachable
Overclocked and runs off an SSD, with Plex and related installed. Not sure Iâd be able to pull that off with this hack.
Ah I see, I think thereâs a workaround for this but havenât tried it myself.
Can you sucessfully ping the Home Assistant server at 10.0.0.4? Iâd wait for an hour or maybe even overnight and check again if the web UI is still not available. The first time it takes some time.
Yes. I donât see any indication that its trying to download anything either. The Ethernet indicator isnât even blinking rapidly.
If this doesnât work, I might go back to venv
on the other Pi, the only issue is the installation of add-ons.
You know you can do a supervised install on raspbian (or other linux OS you use on your pi) ?
Then you have your add-ons.
I managed to do just that. I need some help setting up add-ons. For example, I want to set up this plugin.
Am I doing this correctly?
The camera configuration needs to go in your configuration.yaml, not on the card.
That looks ok. Validate your configuration and restart HA to get it working.
Can you see your picture if you manually browse to http://10.0.0.6/image.jpg ? Maybe open a new topic for your camera, as I donât have a camera myself, and nobody will look for a camera problem under this topic name.
Yeah I can.
Just for your information, this is not an add-on, you donât need Home Assistant Supervised for this, this is just a standard configuration, which is supported by every installation type.
