Cannot Access pi-hole
Hey everybody! So I finally got hass.io up and running with Samba, SSH, DuckDNS, and Node-Red. However, I seem to be at an impasse with the pi-hole addon. I configured my router to use my raspberry pi, which HA is running on, as its DNS server and forwarded the port 4865. However, everytime I try to actually access pi-hole, I get this error:
Failed Host Check: myduckdns.duckdns.org vs 192.168.x.xxx, 2600:8803:b400:3e:ef3d:9223:3555:4514, hassio.local, pi.hole, localhost, hassio, hassio.local
So I thought maybe my error was the port forwarding, so I disabled the port forward and I get an error that says ā€œThis site cannot be reachedā€
My config for the addon is as follows:
ā€œpasswordā€: ā€œmypasswordā€,
ā€œupdate_lists_on_startā€: true,
ā€œadmin_portā€: 4865,
ā€œdns_portā€: 53,
ā€œsslā€: true,
ā€œcertfileā€: ā€œfullchain.pemā€,
ā€œkeyfileā€: ā€œprivkey.pemā€,
ā€œinterfaceā€: ā€œā€,
ā€œipv6ā€: true,
ā€œipv4_addressā€: ā€œā€,
ā€œipv6_addressā€: ā€œā€,
ā€œvirtual_hostā€: ā€œā€,
ā€œhostsā€: []
My logs look this (this is with the ports forwarded):
[āœ“] Pulling blocklist source list into range
[i] Target: raw.githubusercontent.com (hosts)
[i] Status: Pending…
[āœ“] Status: Retrieval successful
[i] Target: mirror1.malwaredomains.com (justdomains)
[āœ“] Status: No changes detected
[i] Target: sysctl.org (hosts)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[i] Target: hosts-file.net (ad_servers.txt)
[i] Consolidating blocklists…
[āœ“] Consolidating blocklists
[i] Extracting domains from blocklists…
[āœ“] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 134660
[i] Removing duplicate domains…
[āœ“] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 112361
[i] Nothing to whitelist!
[i] Parsing domains into hosts format…
[āœ“] Parsing domains into hosts format
[i] Cleaning up stray matter…
[āœ“] Cleaning up stray matter
[āœ“] DNS service is running
[āœ“] Pi-hole blocking is Enabled
[cont-init.d] 50-gravity.sh: exited 0.
[cont-init.d] 99-tests.sh: executing…
dnsmasq: syntax check OK.
[30-Mar-2019 19:58:03] NOTICE: configuration file /etc/php7/php-fpm.conf test is successful
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
[cont-init.d] 99-tests.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[2019-03-30 19:58:03.556 1099] Using log file /var/log/pihole-FTL.log
[2019-03-30 19:58:03.556 1099] ########## FTL started! ##########
[2019-03-30 19:58:03.556 1099] FTL branch: master
[2019-03-30 19:58:03.556 1099] FTL version: v4.2.3
[2019-03-30 19:58:03.556 1099] FTL commit: aae487e-dirty
[2019-03-30 19:58:03.556 1099] FTL date: 2019-02-25 17:18:14 -0800
[2019-03-30 19:58:03.557 1099] FTL user: pihole
[2019-03-30 19:58:03.557 1099] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-03-30 19:58:03.558 1099] SOCKET_LISTENING: only local
[2019-03-30 19:58:03.558 1099] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-03-30 19:58:03.558 1099] MAXDBDAYS: max age for stored queries is 365 days
[2019-03-30 19:58:03.558 1099] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-03-30 19:58:03.558 1099] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-03-30 19:58:03.558 1099] DBINTERVAL: saving to DB file every minute
[2019-03-30 19:58:03.558 1099] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-03-30 19:58:03.558 1099] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-03-30 19:58:03.558 1099] PRIVACYLEVEL: Set to 0
[2019-03-30 19:58:03.559 1099] IGNORE_LOCALHOST: Show queries from localhost
[2019-03-30 19:58:03.559 1099] BLOCKINGMODE: Null IPs for blocked domains
[2019-03-30 19:58:03.559 1099] REGEX_DEBUGMODE: Inactive
[2019-03-30 19:58:03.559 1099] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-03-30 19:58:03.559 1099] DBIMPORT: Importing history from database
[2019-03-30 19:58:03.559 1099] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-03-30 19:58:03.559 1099] PORTFILE: Using /var/run/pihole-FTL.port
[2019-03-30 19:58:03.559 1099] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-03-30 19:58:03.559 1099] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-03-30 19:58:03.560 1099] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-03-30 19:58:03.560 1099] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-03-30 19:58:03.560 1099] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-03-30 19:58:03.560 1099] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-03-30 19:58:03.560 1099] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-03-30 19:58:03.560 1099] Finished config file parsing
[2019-03-30 19:58:03.562 1099] Database successfully initialized
[2019-03-30 19:58:03.563 1099] New forward server: 8.8.4.4 (0/4096)
[2019-03-30 19:58:03.563 1099] New forward server: 8.8.8.8 (1/4096)
[2019-03-30 19:58:03.566 1099] Resizing ā€œ/FTL-stringsā€ from 4096 to 8192
[2019-03-30 19:58:03.571 1099] Resizing ā€œ/FTL-stringsā€ from 8192 to 12288
[2019-03-30 19:58:03.586 1099] Resizing ā€œ/FTL-stringsā€ from 12288 to 16384
[2019-03-30 19:58:03.612 1099] Resizing ā€œ/FTL-stringsā€ from 16384 to 20480
[2019-03-30 19:58:03.615 1099] Resizing ā€œ/FTL-queriesā€ from 229376 to 458752
[2019-03-30 19:58:03.644 1099] Resizing ā€œ/FTL-stringsā€ from 20480 to 24576
[2019-03-30 19:58:03.659 1099] Imported 7054 queries from the long-term database
[2019-03-30 19:58:03.660 1099] -> Total DNS queries: 7054
So it seems like pi-hole itself is working, its just that I cannot access its front end. Any ideas?
Did you fix it? I have pretty much the same issue.
What port should be forwarded to what internal port?
I can connect with lan but not wlan and also not nabu.casa nor duckdns. I added the urls without http or port to the virtual server in pihole config. But no luck so far.
I did not, but if I remember correctly, it was due to my config folder not having a set static ip when I set up my hassio instance. But thinking on it now, that doesn’t really sound right. Sorry I’m no help.
I’m seeing the same issue on 2 instances of Hassio - ā€œFailed Host Check: myhost.com vs 192.168.1.x, fdaa:bbcc:ddee:0:6abb:dc19:8295:9ee6, a0d7b954-pi-hole.local.hass.io, pi.hole, localhost, hassio, hassio.localā€
I’m on 0.98.5 and whilst PiHole is running I can’t log onto the Dashboard/Interface. It’s not killing me yet - but it will be a problem if I need to change some of the settings…
Any advice as to how to fix this would be appreciated.
It turns out it did work for me.
I just had to put my nabu casa url in the virtual_host.
But it took a while for it to work… I don’t know why.
I assume it should work with the duckdns url too.
good luck!
  "update_lists_on_start": false,
  "ssl": true,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "interface": "",
  "ipv6": false,
  "ipv4_address": "",
  "ipv6_address": "",
  "virtual_host": "xxxxxxxxx.ui.nabu.casa",
  "hosts": []
Thanks - This did the trick!
Let me know if you can configure the sensors :wink:
Still getting unknown but tried so many configs… Ty
Here is my config for the pihole sensors. Working after the latest update (4.0.0)
I’m not sure what did the trick but I guess it might be the port number.
Anyway, it’s working now thanks to your help! Awesome, thanks!
update: I’ve since moved this from my sensor.yaml to configuration.yaml as described on the pi-hole sensor component page.
#                  PI HOLE                    #
pi_hole:
  host: 192.168.0.11:4685
  ssl: false
  verify_ssl: false
#                  PI HOLE                    #
pi_hole:
  ssl: false
  verify_ssl: false
I think the documentation is wrong on the port
I believe it should be 4865
From the Pi-Hole Add-On Page:
You are correct, Ill submit a PR and get the docs corrected.
If you find errors like this make a PR to get them fixed. Its quick and easy.
Thank so much for the info
I spent my evening trying to troubleshoot this problem due to the doc mixup, I didn’t feel like then figuring out how to edit the docs.
Thanks again!
I need additional help with this.
I get the same error as mentioned above.
BUT
I can access pi-hole if I access it via url = http://ip-address
Although accessing it via domain name like url hassio or url hassio.local
does not work.
I added hassio.local under hosts in the pi-hole configuration,
added it to virtual hosts etc. but nothing works.
Any help would be appreciated.
There is more than one error mentioned above I think.
Are you using the hassio addon? If so you need to specify port 4865.
Sorry, I am referring to the following error -->
Failed Host Check: hassio vs 192.168.1.xxx, , a0d7b954-pi-hole.local.hass.io, pi.hole, localhost, hassio.local, hassio.local.local, hassio.local
I have not defined the port with the IP but it is under the network section in the pi-hole hass.io configuraiton screen.
Actually it is unclear on reading above which of the dyslexic pair 4865/4685 is correct, and I don’t have hassio here. You need to use one or the other though.
I am not sure I understand why changing the port would make a difference.
It works with the IP address as URL but not with the domain name (same port)?
Specifying the Port with the IP I get the same error but now with IP:4865 listed.
This thread is about connecting home-assistant pihole integration. What are you asking for? Accessing the pihole web page?
