Hi
New to home automation, loving it so far. I’m stuck trying to change the sensitivity and detection interval on my Aqara P1. When I try, nothing happens. Whan I refresh my browser, it reverts to medium and 30 seconds. I’ve tried locating the config file for ZHA but cant find it, so now I’m turning to you guys for help.
Did you ever get this sorted properly? I have upgraded to the latest firmware (0x26780700) and I can change the timeout but not the sensitivity or the motion trigger indicators.
Was curious about the OP’s inability to change sensor settings, which he outlines in his opening post. (Missed your first response initially.) Solution to why I was encountering the issue here, though may be separate to the reason why OP is having problems.
Sorry, thought I had email subscribed to the thread, but apparently not. It is with ZHA/Conbee 2. This is my first battery powered device and I didn’t realise I had to wake it up.
Yes, i have the same problem. HA with ZHA Sky Connect and 3 Aqara P1 in my house. You can configure the P1 Motion sensor only when you do the pairing. After it Home Assistant bring lots of error messages and a setting (e.g. sensivity) isnt possbile to change.
