Cannot install supervisor 2024.11.3 hassos
When I click install on supervisor I get the error below… bit stumped, not sure what to do… a google search gave no results
Failed to perform the action update/install. Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.42/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error (“toomanyrequests: retry-after: 444.382µs, allowed: 44000/minute”)
Jon
I have the same error, might be external, as the error is: toomanyrequests: retry-after.
Probably a GitHub error, have seen it with another repository too.
But I’m not sure
I am unable to update to the latest 2024.11.3 as I have the following error message
Yesterday updated the Debian machine that I ran to their latest version including Kernel, but am unsure if it that’s or an error from HA
I have of course rebooted
Failed to perform the action update/install. Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found (“No such image: Package amd64-hassio-supervisor · GitHub”)
same problem here
I have just added a post with my error but now just seen yours
When attempting to update, it appears it is looking to pull the image from “localhost”
Any ideas on this one?
Failed to perform the action update/install. Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.46/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
It is a GitHub issue.
Roger thank you, I will try again tomorrow.
ah, thanks for sharing… if its a someone else problem not much we can do
same problem here :frowning:
+1 same problem here
Same here too.
Same problem here
The error that you are getting is displayed after trying to update 3-4 times in a row and failed. The original reason for failing can be found in the log and is this:
homeassistant.components.home assistant OS.handler.HassioAPIError: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/amd64-home assistant OS-supervisor:2024.11.3/json: Not Found (“No such image: Package amd64-hassio-supervisor · GitHub”)
Btw i have the same problem :frowning:
I have the same problem. Log attached.
Logger: homeassistant.components.websocket_api.http.connection
Quelle: components/websocket_api/commands.py:245
Integration: Home Assistant WebSocket API (Dokumentation, Probleme)
Erstmals aufgetreten: 10:21:41 (1 Vorkommnisse)
Zuletzt protokolliert: 10:21:41
[139750771192688] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 262, in async_install
    await self.coordinator.supervisor_client.supervisor.update()
  File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/supervisor.py", line 43, in update
    await self._client.post(
  File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/client.py", line 173, in post
    return await self._request(
  File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/client.py", line 122, in _request
    raise exc_type(result.message, result.job_id)
aiohasupervisor.exceptions.SupervisorBadRequestError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
    single_response = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 157, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 502, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 264, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
Same here. Does this have anything to do with trying to update from remote?
Same problem
Here too. Seems lie a general problem. Anyone succeeded in upgrading supervisor to 2024.11.3?
same here, looks like to many people try to update and home assistant is hitting some request limit (thought ghcr doesn’t have one in contrast to docker.io) and then people start retrying over and over again making it worse :smiley:
Snap… ‘no such image’…
+1. (same problem)
