Cannot install supervisor 2024.11.3 hassos
Same problem here.
i want to update my supervisor but i cant …
there is the error log.
Hope somebody can help me.
HA installed on Raspberry Pi4.
  • Core2024.11.1
  • Supervisor2024.11.2
  • Operating System13.2
  • Frontend20241106.2
Logger: homeassistant.components.websocket_api.http.connection
Quelle: components/websocket_api/commands.py:245
Integration: Home Assistant WebSocket API (Dokumentation, Probleme)
Erstmals aufgetreten: 10:19:35 (5 Vorkommnisse)
Zuletzt protokolliert: 10:32:43
[547640878000] Unexpected exception
[547340286224] Unexpected exception
[547264460064] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 262, in async_install
    await self.coordinator.supervisor_client.supervisor.update()
  File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/supervisor.py", line 43, in update
    await self._client.post(
  File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/client.py", line 173, in post
    return await self._request(
  File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/client.py", line 122, in _request
    raise exc_type(result.message, result.job_id)
aiohasupervisor.exceptions.SupervisorBadRequestError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("toomanyrequests: retry-after: 599.324µs, allowed: 44000/minute")
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
    single_response = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 157, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 502, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 264, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("toomanyrequests: retry-after: 599.324µs, allowed: 44000/minute")
thanks and best. greetings.
mfg
Interesting that it says 44000 downloads per minute are allowed which seems quite high… however some other components now force you to upgrade supervisore before you can update them so I guess this is triggering a tonn of extra downloads from people who had been refraining from updating supervisor before
Same problem here.
Also here the same problem.
In case you all did not see it:
Please don’t post “me too” just thumb up the issue(s).
I’m in the same boat, but with an added problem: I rebooted and now it won’t boot because I have an outdated supervisor.
Any ideas on how to boot with the version without updating?
imagen
Having the same issue
Although it apparently starts well, I cannot connect
it’s my problem
Got the docker rate limit issue, but then I just logged in with my account docker login to have “my own” rate limit, but now I get a 404.
Error: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
Hmm, trying to install 2024.11.2 gives me the "toomanyrequests: retry-after: 691.115µs, allowed: 44000/minute" error.
I’ll jump over to the github issue.
+1 for me too.
Same here.
Same :-(:-(:-(:-(:frowning:
I got the same error unfortunately “ha supervisor repair” didn’t help. I am running on a VM in Uraid
Same here :frowning:
Same error here, have to wait it says for 44000 minutes hope that is a joke!
Hi :slight_smile: same error here (hardware Green Nabu Casa) ; we’ll see tomorrow…
Same boat…
