Same here - hope they fix is quick HA is down on my side ;(
Same here
Die Aktion update/install konnte nicht ausgeführt werden. Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error (“toomanyrequests: retry-after: 50.008µs, allowed: 44000/minute”)
Yep here too, i really was thinking it was a problem on my side.
But all my systems have the same issue, so must be github.
Reporting the same issues.
any solutions to fixed this? restore also failed since the supervisor become unstable
It is a GitHub issue and whether you get a too many request or no such image error. it is still the same.
Just wait it out!
I did try also a manual pull, doesn’t work as well
also ha core check throws an error, so i think we just have to wait guys
➜ ~ ha core check
Processing... Done.
Error: Can't execute command: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=latest&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant: Internal Server Error ("toomanyrequests: retry-after: 768.393µs, allowed: 44000/minute")
its a Github issue.
I will wait till tomorrow, because spamming the updates cause more problems
i guess the problem was not resolved yet
then we play the waiting game
Mods closed my similar topic without getting chance to ask - is my current, running HA depended on GitHub? I understand I cant install HA now when GitHub may have some issues, but how come running HA instance in WM is influenced and gets to the “emergency console” mode when GitHub is down? Its quite a shocker that my HA is so much depended - you just wake up and everything is down.
Failed to perform the action update/install. Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 424.832µs, allowed: 44000/minute")
Also with my Hass on Synology VM. Let’s hope it will be fixed soon!
Hi all
Same issue here
same here , since 12h
must be a pretty popular update for github to responde with ‘to many requests’
Same here…
same issue here, waiting
Indeed. The problem is not so much the issue with the update, but the fact that as soon as HA sees there is a supervisor update it prevents you from doing all sorts of other things. That seems totally inappropriate and hopefully an oversight rather than deliberate design.
same here, following for updates
it means that if a reboot will happen now, the supervisor will not start?
I deleted my Vm, think it was my problem and now I can’t start a new one.
It stays on setup trying to update the system before let me do anything.
