Trying to solve a problem with HA Cloud, I uninstalled the Homeassistant App on my iPhone.
The HA Cloud & remove issue is now resolved.
The reinstall iOS App askes me to authenticate (username / password).
Then the 2FA token, after which the following error is displayed.
The HA Logs give the following exception…
2022-01-09 13:52:33 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/person/__init__.py", line 214, in _entity
_registry_updated
await self.async_update_item(
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/collection.py", line 265, in async_update_it
em
await self.notify_changes(
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/collection.py", line 141, in notify_changes
await asyncio.gather(
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/collection.py", line 370, in _collection_cha
nged
for entity in await asyncio.gather(
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/collection.py", line 350, in _update_entity
await entities[change_set.item_id].async_update_config(change_set.item) # type: ignore
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/person/__init__.py", line 450, in async_u
pdate_config
self._unsub_track_device = async_track_state_change_event(
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/event.py", line 250, in async_track_state_ch
ange_event
entity_callbacks = hass.data.setdefault(TRACK_STATE_CHANGE_CALLBACKS, {})
AttributeError: 'NoneType' object has no attribute 'data'
The log files from the app, show data for the sensors being passed to HA, getting respones, then…
2022-01-09 13:56:28.566 [Info] [main] [HAAPI.swift:733] registerSensors() > finished registering sensors: fulfilled([(), (), (), (), (), (), (), (), (), ()])
2022-01-09 13:56:28.566 [Info] [main] [OnboardingAuth.swift:70] perform(checkPoint:checks:) > OnboardingAuthStepSensors: fulfilled()
2022-01-09 13:56:29.061 [Info] [main] [Bonjour.swift:34] stop() >
2022-01-09 13:56:36.106 [Info] [main] [LifecycleManager.swift:170] connectAPI(reason:) > Connect finished for reason warm
and
2022-01-09 13:20:01.700 [Info] > HomeAssistant-Extensions-Widgets Version: 2021.12.1 Build: 2021.327 PID: 2428
2022-01-09 13:20:01.700 [Info] > XCGLogger Version: 7.0.1 - Level: Debug
2022-01-09 13:20:01.702 [Info] > XCGLogger writing log to: file:///private/var/mobile/Containers/Shared/AppGroup/48DA914C-D7FD-4CFA-9471-8F60ADFB9543/logs/HomeAssistant-Extensions-Widgets.txt
2022-01-09 13:20:01.703 [Info] [webhookmanager-data] [WebhookManager.swift:712] init(identifier:delegate:delegateQueue:background:) > webhook-io.robbie.HomeAssistant.Widgets initial tasks: []
2022-01-09 13:20:01.703 [Info] [webhookmanager-data] [WebhookManager.swift:712] init(identifier:delegate:delegateQueue:background:) > non-background initial tasks: []
2022-01-09 13:20:01.703 [Info] [main] [ServerManager.swift:362] migrateIfNeeded() > no historic server found to import
The same App works on my iPad, without issue.
HA works from a web browser on the phone.
Any suggestions?
