Hi there, I can’t access the HassOS gui (ie http://homeassistant.local:8123) after updating to the latest HassOS version. I have no access via a browser or via the iOS app. I get the error messages (on my desktop browser): “hassio.local refused to connect” or “hassio.local didn’t send any data”.
I do think it is running (at least partially) because I have the Homekit integration (so I can see all my Hass devices in the iOS Home app) and the devices I’ve checked seem to be functioning (ie I can turn home assistant’s lights and outlets on and off from my iOS Home app).
Any ideas what could be wrong? (I’m not super technical but I’ll give anything a shot if you can explain it in layman terms )
Cheers!
ps I have tried restarting my Raspberry Pi but that didn’t make a difference.
Can you also try clearing your browser’s local cache? Just for the local site… I’ve noticed after clearing the cache you can solve most of these issues…
Actually, I don’t think I had/have SSH set up. Is it an add-on? I still have a screen open from before everything went pear-shaped and the only add-ons I have are Duck DNS and File editor.
With the screen attached I’m presented with “homeassistant login:” but it doesn’t seem to accept the login details I use for the app or for the gui. Are there different login credentials from the command prompt?
Sorry, I should clarify: I have an old window/tab in my browser still showing the information of add-ons I’ve installed. But it’s not actively connected (it just hadn’t been refreshed). The previous post means “with the monitor attached…”. So, I now have a monitor and keyboard attached and am trying to log in through the command line.
Hi @tom_l, I checked both logs. I can’t print them out here but I’ll retype the warnings (orange lines).
Core logs:
-[homeassistant.setup] Setup of input boolean is taking over 10 seconds
-[homeassistant.setup] Setup of ffmpeg is taking over 10 seconds
-[homeassistant.setup] Setup of zone is taking over 10 seconds
-[homeassistant.setup] Setup of input_select is taking over 10 seconds
-[homeassistant.setup] Setup of input_text is taking over 10 seconds
-(zeroconf-Engine-240) [zeroconf] Error sending through socket 10*
*This last one came through 5 hours later (the others were just after boot) so I’m not sure it’s related to my access issues.
Supervisor logs: Had no orange lines - all green.
I also ran the various supervisor and core repairs, rebuilds, and updates - nothing made any difference but one thing I did notice was that the IP address listed under both core and supervisor is 172.30.32.1 - that’s not part of my local network. IP should be something like 10.X.X.X
ps Sorry about the delay - I need this monitor for work too.
Any thoughts on those notes in the core log, do they help diagnose what’s wrong? I’m wondering if I should just start from scratch and restore from a snapshot.
