Can't add a node to Aeotec z-wave
Using HassOS or Raspbian?
Apparently, there is an issue with the Aeotec stick and the Pi4.
Hi Everyone,
Got it to workā€¦ I used a USB 3.0 hub to connect with the USB 3.0 port on the Raspberry pi4.
Then I added the integration through the config file in Configuration.yaml rather then via the integration menu.
I used this hub; Sabrent 4-Port USB 3.0 Hub with Individual LED Power Switches (HB-UM43) bought through Amazon:
Iā€™m having a similar issue trying to add nodes. My sd card crapped the bed, I replaced it and restored a backup. They z wave network works fine but unable to add new nodes. I get a similar message saying the command failed. Using the aeotek gen 5 stick as well. Any ideas?
OS?
Pi4 or Pi3 or Other?
Paste the first 10 lines of your OZW_Log.txt.
HASSIO 0.104.3
Pi3
2020-01-21 21:06:23.972 Always, OpenZwave Version 1.4.3452 Starting Up
2020-01-21 21:06:35.619 Info, Setting Up Provided Network Key for Secure Communications
2020-01-21 21:06:35.620 Info, mgr, Added driver for controller /dev/ttyACM0
2020-01-21 21:06:35.620 Info, Opening controller /dev/ttyACM0
2020-01-21 21:06:35.620 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-01-21 21:06:35.621 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-01-21 21:06:35.622 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-01-21 21:06:35.622 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-01-21 21:06:35.622 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-01-21 21:06:35.622 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
and hereā€™s the log from where it fails to include a node:
2020-01-21 21:44:08.576 Detail, Notification: ControllerCommand - Starting
2020-01-21 21:44:08.577 Detail,
2020-01-21 21:44:08.577 Info, contrlr, Sending (Command) message (Callback ID=0xa9, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0xa9, 0xd8
2020-01-21 21:44:08.629 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0xa9, 0x07, 0x00, 0x00, 0x1c
2020-01-21 21:44:08.630 Detail,
2020-01-21 21:44:08.630 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-01-21 21:44:08.630 Info, contrlr, ADD_NODE_STATUS_FAILED
2020-01-21 21:44:08.630 Detail, contrlr, Removing current message
2020-01-21 21:44:08.630 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-01-21 21:44:08.630 Detail, Notification: ControllerCommand - Failed
2020-01-21 21:44:08.631 Detail,
2020-01-21 21:44:08.631 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-01-21 21:44:08.683 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0xa9, 0x06, 0x00, 0x00, 0x1d
2020-01-21 21:44:08.684 Detail,
2020-01-21 21:44:08.684 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-01-21 21:44:08.684 Detail, Node006, Expected reply was received
2020-01-21 21:44:08.684 Detail, Node006, Message transaction complete
2020-01-21 21:44:08.684 Detail, contrlr, Removing current message
2020-01-21 21:44:08.684 Detail, Notification: ControllerCommand - Completed
Try running your whole log thru the openzwave analyzer:
http://www.openzwave.com/log-analyzer
from my limited knowledge of the logs it seems the existing nodes work fine, its just functions of including nodes failsā€¦ Is this happening because i swapped sdcards and restored a backup?
http://openzwave.com/log-analyzer/public/594fb35f-e648-4ac3-a1f1-ae2f6e882024/
I have same issuesā€¦ ion past add lots of nodes but now I cant add them
