I am new to HomeAssistant. The first look is impressive! I like it very much. So I have some devices with tasmota flashed (Sonoff Basic and Sonoff Touch 2CH, Tasmota 9.2.0) and want to add these devices to my HA installation.
If I try to add tasmota from integrations, the window closes immmediately and an error log appears. There is also a notice that my mqtt config is invalid, but I don’t have anything installed like that. Do I need an additional mosquitto service installed on the same machine?
Here is the error log from HA (Version 2021.1.4, I’ve installed HA from Ubuntu snaps via “sudo snap install home-assitant-snap”):
2021-02-04 09:21:15 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tasmota. Setup failed for dependencies: mqtt
2021-02-04 09:21:15 ERROR (MainThread) [aiohttp.server] Error handling request
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/components/config/config_entries.py", line 136, in post
return await super().post(request)
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/helpers/data_entry_flow.py", line 69, in post
result = await self._flow_mgr.async_init(
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/data_entry_flow.py", line 119, in async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/config_entries.py", line 532, in async_create_flow
await async_process_deps_reqs(self.hass, self._hass_config, integration)
File "/snap/home-assistant-snap/123/lib/python3.8/site-packages/homeassistant/setup.py", line 339, in async_process_deps_reqs
raise HomeAssistantError("Could not set up all dependencies.")
homeassistant.exceptions.HomeAssistantError: Could not set up all dependencies.
Please help to find out whats wrong with my installation
Thanks for your help!
Greetings from Germany
