I’m try to add Spotify however I’m hitting a bit of a wall.
I hit configure, it goes through to Spotify account linking stage fine then sits on “loading next step for Spotify” for 30 seconds before bringing up a blank box that just says “close”…
Any ideas what I’m doing wrong as I’ve followed on the instructions, on the latest version of HA if that helps.
Did you find a solution as same thing for me?
No sorry. Still having the same issue. I can’t seem to get around it and it’s so annoying
Same here …
Same issue here. Anybody found a solution?
If anyones still having this issue I just randomly tried again and it worked, maybe something’s been fixed so give it another try
If you can’t get things working inside of HA you could consider just building a home audio system that you then link into HA. Instructions to building and audio system with LMS exist here. LMS provide the ability to work with spotify and lots more.
