Hello!
I have been using home assistant for a long time, (2018 ish). I have ran it on a dell optiplex as haos always. It runs fine and everything until now. My network in my house is flat as it can be, 1 desktop switch plugged into a verizon fios g3100 router.
I can ping from the console on HAOS to the router, and the public IP.
I can nslookup google.com. Which means the DNS is running.
I looked at the default route which is a 192.168.1.1 and it routes it there fine.
I can access HA locally via its ip & homeassistant.local
I can ssh into the HAOS fine with dropbear, and access it locally.
I am unable to get it to route traffic from it to the world, even though I am able to access the web from the same port, and router
When I run nmcli con edit "Home Assistant OS default"
It returns nothing, which I suspect causes issues.
https://github.com/home-assistant/operating-system/blob/5eb7ccb7611a06a00013d4292b5e8bd75147195d/Documentation/network.md
I work with some network engineers, and they looked at all the tables, and said they were fine.
I am just stumped. Is there a no internet setting on the home assistant that I am missing?
Thanks for your help!
docker:
address: 172.30.32.0/23
dns: 172.30.32.3
gateway: 172.30.32.1
interface: hassio
host_internet: false
interfaces:
- connected: true
enabled: true
interface: eno1
ipv4:
address:
- 192.168.1.217/24
gateway: 192.168.1.1
method: auto
nameservers:
- 192.168.1.1
ready: true
ipv6:
address:
- [retacted]
- [retacted]
gateway: null
method: auto
nameservers: []
ready: true
mac: [retacted]
primary: true
type: ethernet
vlan: null
wifi: null
supervisor_internet: false
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
^C
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2050ms
# nmcli g status
STATE CONNECTIVITY WIFI-HW WIFI WWAN-HW WWAN
connected (site only) limited missing enabled missing enabled
Core 2024.9.3
Supervisor 2024.10.3
Operating System 13.1
Frontend 20240909.1
ping 192.168.1.1
192.168.1.1 is alive!
ping 8.8.8.8
^C
ping REDACTED.duckdns.org
REDACTED.duckdns.org is alive!
# cat NetworkManager.conf
[main]
dns=default
plugins=keyfile
autoconnect-retries-default=0
rc-manager=file
[keyfile]
unmanaged-devices=type:bridge;type:tun;driver:veth
[logging]
backend=journal
[connection]
connection.mdns=2
connection.llmnr=2
[connectivity]
uri=http://checkonline.home-assistant.io/online.txt
interval=600
[device]
wifi.scan-rand-mac-address=no
# cat netconfig
# The network configuration file. This file is currently only used in
# conjunction with the TI-RPC code in the libtirpc library.
# Entries consist of:
# <network_id> <semantics> <flags> <protofamily> <protoname> \
# <device> <nametoaddr_libs>
# The <device> and <nametoaddr_libs> fields are always empty in this
# implementation.
udp tpi_clts v inet udp - -
tcp tpi_cots_ord v inet tcp - -
udp6 tpi_clts v inet6 udp - -
tcp6 tpi_cots_ord v inet6 tcp - -
rawip tpi_raw - inet - - -
local tpi_cots_ord - loopback - - -
unix tpi_cots_ord - loopback - - -
