maco2035
(Maco2035)
21
This might help to find something:
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy DROP 0 packets, 0 bytes)
106K 16M DOCKER-USER 0 -- * * 0.0.0.0/0 0.0.0.0/0
106K 16M DOCKER-ISOLATION-STAGE-1 0 -- * * 0.0.0.0/0 0.0.0.0/0
978 82701 ACCEPT 0 -- * docker0 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
0 0 DOCKER 0 -- * docker0 0.0.0.0/0 0.0.0.0/0
7038 432K ACCEPT 0 -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT 0 -- docker0 docker0 0.0.0.0/0 0.0.0.0/0
59894 13M ACCEPT 0 -- * hassio 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
4567 290K DOCKER 0 -- * hassio 0.0.0.0/0 0.0.0.0/0
33740 2232K ACCEPT 0 -- hassio !hassio 0.0.0.0/0 0.0.0.0/0
4567 290K ACCEPT 0 -- hassio hassio 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Chain DOCKER (2 references)
0 0 ACCEPT 6 -- !hassio hassio 0.0.0.0/0 172.30.32.6 tcp dpt:80
0 0 ACCEPT 6 -- !hassio hassio 0.0.0.0/0 172.30.33.2 tcp dpt:8889
0 0 ACCEPT 6 -- !hassio hassio 0.0.0.0/0 172.30.33.2 tcp dpt:8888
0 0 ACCEPT 6 -- !hassio hassio 0.0.0.0/0 172.30.33.2 tcp dpt:8554
0 0 ACCEPT 17 -- !hassio hassio 0.0.0.0/0 172.30.33.2 udp dpt:8189
0 0 ACCEPT 6 -- !hassio hassio 0.0.0.0/0 172.30.33.2 tcp dpt:5000
0 0 ACCEPT 6 -- !hassio hassio 0.0.0.0/0 172.30.33.2 tcp dpt:1935
0 0 ACCEPT 6 -- !hassio hassio 0.0.0.0/0 172.30.33.3 tcp dpt:1627
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
7038 432K DOCKER-ISOLATION-STAGE-2 0 -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
33740 2232K DOCKER-ISOLATION-STAGE-2 0 -- hassio !hassio 0.0.0.0/0 0.0.0.0/0
106K 16M RETURN 0 -- * * 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-ISOLATION-STAGE-2 (2 references)
0 0 DROP 0 -- * docker0 0.0.0.0/0 0.0.0.0/0
0 0 DROP 0 -- * hassio 0.0.0.0/0 0.0.0.0/0
40778 2664K RETURN 0 -- * * 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-USER (1 references)
WallyR
(Wally)
22
Well, something is amiss.
This shows that 290K data have been sent to the DOCKER chain.
This shows that no data have been handled in the DOCKER chain.
It looks like the hassio is not set up to have host permissions in docker.
Are you running Portainer by any chance?
nickrout
(Nick Rout)
23
Are you really running HAOS? Or some other install method?
maco2035
(Maco2035)
24
I am running this in haos. 100% postive, as I had to manually type my ssh keys into the console in my basement
I donāt know what is happening in the iptables.
There is no containters.
What I have installed in my machine:
HACS
Duckdns add on
Wiregaurd add on (off and uninstalled now)
Grocy add on (off)
Wyze add on
WallyR
(Wally)
25
Looking at all this info and I can only see one place for the issue to be located and that is your router.
nickrout
(Nick Rout)
26
This is from your first post. What filetime is this exactly (full path and name please)
Also please go to Settings/About. Tell us what you see there
Core
2024.11.1
Supervisor
2024.11.3
Operating System
13.2
Frontend
20241106.2
maco2035
(Maco2035)
27
I have done a full factory reset on the router and it still has issues.
maco2035
(Maco2035)
28
It looks old because I am unable to update it.
This is from today:
Core 2024.9.3
Supervisor 2024.10.3
Operating System 13.1
Frontend 20240909.1
Welcome to Home Assistant OS.
Use `ha` to access the Home Assistant CLI.
# ha network info
docker:
address: 172.30.32.0/23
dns: 172.30.32.3
gateway: 172.30.32.1
interface: hassio
host_internet: false
interfaces:
- connected: true
enabled: true
interface: eno1
ipv4:
address:
- 192.168.1.217/24
gateway: 192.168.1.1
method: static
nameservers:
- 192.168.1.1
ready: true
ipv6:
address:
- fdb8:b56f:def3:b34c:390b:a643:952a:d878/64
- fe80::1e43:a84b:ef42:df51/64
gateway: null
method: auto
nameservers: []
ready: true
mac: 98:90:96:D4:05:B7
primary: true
type: ethernet
vlan: null
wifi: null
supervisor_internet: false
maco2035
(Maco2035)
29
This is my routers port forwarding
u
WallyR
(Wally)
30
I do not think it is your portforwarding rule, but rather a firewall rule or some defect with your router.
Have you tried restarting it?
maco2035
(Maco2035)
31
I have factory reset my router, and also restarted it a few times. The router is on the factory settings.
maco2035
(Maco2035)
32
Yes I have, I posted it below the photo of it.
nickrout
(Nick Rout)
33
Here is mine. A few differences in settings
~ # ha network info
docker:
dns: 172.30.32.3
interface: hassio
host_internet: true
interfaces:
- connected: true
enabled: true
interface: enp0s18
ipv4:
address:
- 192.168.20.84/24
gateway: 192.168.20.1
method: auto
nameservers:
- 192.168.20.1
ready: true
ipv6:
address:
- fe80::67c6:43f7:d18b:cb8d/64
gateway: fe80::2a5:4cff:fe68:1331
method: auto
nameservers: []
ready: false
mac: 02:9D:8A:03:82:C3
primary: true
type: ethernet
vlan: null
wifi: null
supervisor_internet: true
maco2035
(Maco2035)
34
Yeah I have no clue whats different anymore.
nickrout
(Nick Rout)
35
- Mine has
host_internet: true
- Mine has
method: auto in the ipv4: section1.
- yours has
gateway: null in the ipv6: section, mine has an address.
- Mine has
ready: false in the ipv6: section
- Mine has
I am by no means an expert on internet settings (particulalarly ipv6), but I would think one of the following might be a problem;
- you having ipv6 enabled, but no ipv6 gateway. or
- supervisor_internet being turned off.
maco2035
(Maco2035)
36
Sorry I didnāt mean any disrespect. I am sorry if my tone was incorrect.
What I mean, is that I have settings that are almost the same, but just defined by the user which is the same on the router, and the machine.
I have turned off ipv6 and I have similar problems still.
supervisor_internet is what is broken.
Thanks again for all your help!
nickrout
(Nick Rout)
37
I didnāt read that into your reply at all.
WallyR
(Wally)
38
I think this is just a sensor, so the lack of internet will automatically make it false.
Auto just means DHCP is used to assign the IPv4 address.
It is not best method, but it should work.
Yours have a gateway for a fe80 network, which is a non-routable network, so it is an invalid gateway.
This is a sensor too and the lack of a working gateway would probably make it false
maco2035
(Maco2035)
39
Thanks Wally!
I turned off ipv6 in my router. I can turn it on and report back what changes.
maco2035
(Maco2035)
40
I enabled ipv6, and this is what I have.
docker:
dns: 172.30.32.3
interface: hassio
interfaces:
- connected: true
enabled: true
interface: eno1
ipv4:
address:
- 192.168.1.217/24
method: auto
nameservers:
- 192.168.1.1
ready: true
ipv6:
address:
- 2600:4040:7b95:6900:17b2:95b7:efe6:bfb4/64
gateway: fe80::baf8:53ff:fe2e:74e9
method: auto
nameservers:
- 2600:4040:7b95:6900::1
ready: true
primary: true
type: ethernet
vlan: null
wifi: null
