Can't connect to homeassistant:8123
Hi there, I am having the same issues with a Pi 4B. I can see it on the network, but can’t connect to the web service. Were you able to solve your issues?
FYI, I believe this was a problem with the balenaEtcher. I downloaded and used the official Raspberry Pi Imager. And was able to get it running right away.
I did have the use http://ipaddress:8123
Hi there, I also have the same issue
I can’t connect with - http://homeassistant.local:8123/
but it works with - http://192.168.178.19:8123/
The funny thing is that I’m not directly connected with my router but via a wifi booster power plug because I was connecting to it from the first floor.
When I went downstairs and was connected to the wifi of my router, using the first link did work. Does this have to with some kind of DNS setting?
Did you end up figuring this out? I’m having a similar issue; I can connect to homeassistant.local with my hardwired pc, but not over WiFi on my phone. Only my local IP works on my phone.
I’m having the same problem. Was running fine, ran the update then it disconnected and I can’t access it now. Tried local:8123 and IP:8123
I’m having the same issue with my new install. I can ping homeassist.local, and everything is working fine. However, I can’t get connected to the server on port 8123 through my browser. That tells me the network connection is OK, but perhaps the server is not?
I ended up connecting both my computer and the Pi via ethernet to the router, i could then connect for a period of time where I initiated all the software updates and this fixed it. Still not 100% sure what the issue was, occasionally i get the same issue and a software update fixes it.
I got my server up and going. Since this was my first install, I just wiped the disk image and started fresh. I think I broke something by not shutting down properly.
I moved home so changed also internet provider. I have another router now. I connected rasberry thorugh ethernet cable and got the ip in the rounter which is 192.168.0.38/24.
Then I tried with the ip 192.168.0.38:8123 from a computer which was also connected in the same network with the cable. It says that is not available.
I have duckdns configured, donno if I need to deactivate this:
#Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
    base_url: xxxx.duckdns.org added:8123
    ssl_certificate: /ssl/fullchain.pem
    ssl_key: /ssl/privkey.pem
I have an issue to connect to HA.
it is installed on a mini PC (VM) which is connected to network via WiFi extender.
It’s having an assigned ip in the router.
I can connect from a tablet but not from my phone.
My phone has as well installed the app which is connected to another HA installed on synology.
Before switching to mini PC I wanted to try the version installed on it (supervised version with add-ons).
Try this:
Disconnect all the wired devices from your router.
Only the Raspberry Pi should be connected, then try to access again.
I had the same problem but there were two things I needed to do to resolve the issue:
  1. The DuckDuckGo search engine that was failing the resolution. I went into Chromium and set the search engine to Google.
  2. I also needed to add 192.168.1.x HomeAssistant.Local to the end of /etc/hosts file.
That was it!
I lost access to HA in the moment I did the same configuration you mention here. Did you solve your issue? can you share how?
Hi, i am facing the same. Out of a sudden the connection is not working anymore
identified possible reason.
  1. IP was banned; so i changed config…yaml added trusted networks but doesnt work; set up ban ip to false
    unfortunately no effect. for a short period like minutes i was able to use the android app to connect.
But now i dont have an idea. pls dont ask for external/internal ip/dns i tried all the stuff. but only internal. which is fine for me.
when i use an vpn and get another ip it works then again.
But i dont have any idea! Maybe the best to remove HA and go back to Domoticz which worked like a charm
Had he same issue. My mistake was as simple as adding https://x.x.x.x:8123
This work for me:
ha core update --version 2022.8.2
banner
thank you so much! spent a lot of time until i read your comment. thanks!
Had similar issue where I needed to log in using the 192.168.1.x:8123 (found out what the “x” was from my network’s modem page). I have a NetGear modem, which may require me to do many factory resets and that requires reauth of my DuckDNS, so I ended up abandoning them and going through a different secure server provider.
You can find the HA hub’s IP address through a program like Wireless Network Watcher or Glasswire
I use Home Assistant on a virtual machin Virtual Box for 1 year
I was developing some dashboards as an update for the HA supervisor was proposed to me (I accept)
Now when I start the VM hHA seems to be started correctly, give me the IP address and the URL to reach my server : http://homeassistantpc.local :8123 as usual.
information from CLI:
When I try to connect with this address I get the answer:
*Unable to connect
An error occurred during a connection to homeassistantpc.local:8123.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
What are the reasons for that?
Is it possible to restore a backup from the CLI interface ?
Is it possible to download the backup of my application from the backup repository?..
I just had the same issue. It was somehow tied to duckdns that i had set up previously. When I made some changes to my config file I got locked out. I added the “s” to the http and that fixed the issue. Thank you!
