Can't find add-ons in 2022.2.5
Hello, I installed HomeAssistant OS (via VirtualBox with the provided vdi in the docs. Windows - Home Assistant
After installing and going through setup, I don’t see the supervisor tab in the left menu bar.
I can however see that Supervisor is installed via Configuration > Devices and Services. If I click on configure supervisor here. I’m brought to the add-ons store.
Is there a way I can add Supervisor to the sidebar panel?
I’m running:
Home Assistant 2022.2.5,
Home Assistant OS 7.2
supervisor-2022.01.1
System Info from Configuration → Settings → Info
See this:
and this:
Perfect. Thanks all.
