I have an add-on which has a web-server on port 5052 and if in the config.yaml for the add-on I set:
ports:
5052/tcp: 5052
ports_description:
5052/tcp: Web interface
Then the web interface works fine on homeassistant.local:5052
However I want to support ingress so in the config.yaml I set:
ingress: true
ingress_port: 5052
When I re-install the add on and click on the ingress it says its unavailable. What am I missing?
