This topic is part of the community-driven cookbook where you can find other topics you might be interested in or might like to contribute to.
Thanks to @anon11644107 who posted this a while ago.
Some system dashboards take several clicks to access. To save time you can add custom buttons to the side toolbar.
Using panel-redirect.js
Create a file called panel-redirect.js in your www folder.
It should contain the following:
Add a link to the sidebar to any path in Home Assistant
Put this file in <config>/www/panel-redirect.js
In configuration.yaml:
panel_custom:
- name: panel-redirect
# url_path needs to be unique for each panel_custom config
url_path: redirect-server-controls
sidebar_title: Server Controls
sidebar_icon: mdi:server
module_url: /local/panel-redirect.js
config:
# Where you want to redirect to
target: /config/server_control
class PanelRedirect extends HTMLElement {
connectedCallback() {
if (this._info) {
this._navigate();
set panel(info) {
this._info = info;
if (this.isConnected) {
this._navigate();
_navigate() {
history.replaceState(null, "", this._info.config.target);
const event = new Event("location-changed", {
bubbles: true,
composed: true,
event.detail = { replace: true };
this.dispatchEvent(event);
customElements.define("panel-redirect", PanelRedirect);
Then... Example configuration.yaml:
frontend:
# Zigbee network map -----------------------------------------------------------
url_path: redirect-zigbee
sidebar_title: Zigbee network
sidebar_icon: mdi:chart-bubble
config:
target: config/zha/visualization
You can get the target url by opening Home Assistant in a browser and navigating to the appropriate screen.
Addition by @Sir_Goodenough ...
Using Custom panel - Home Assistant
panel_custom:
- name: ha_supervisor
sidebar_title: Supervisor
sidebar_icon: mdi:home-assistant
js_url: /api/hassio/app/entrypoint.js
url_path: 'hassio/dashboard'
embed_iframe: true
require_admin: true
config:
ingress: Supervisor
- name: config/logs
sidebar_title: Logs
sidebar_icon: mdi:math-log
module_url: https://10.27.18.8:8123/config/logs
embed_iframe: true
require_admin: true
config:
ingress: Logs
Using Webpage dashboard
There's another for iframe capable external websites using webpage dashboard
The webpage dashboard uses the webpage card. This method replaces the old YAML iframe method if you used to have some of those.
These are less customizable, but can be installed using the GUI or YAML in your Dashboard. See the code and examples in the links rather than me repeating them here.
