I have a few MQTT switches, sensors, and lights that stopped working after updating to HA 2022.9.0. I read through the release/change notes and made (what I thought) were the necessary modifications to my configuration.yaml and added a mqtt.yaml file.
In my configuration.yaml file I have a line reading:
mqtt: !include mqtt.yaml
in my mqtt.yaml file I have the following entries after formatting the items slightly (all passed configuration.yaml check in developer):
switch:
- name: "Man Cave Fan"
state_topic: "tele/Man_Cave_Fan/STATE"
command_topic: "cmnd/Man_Cave_Fan/POWER"
availability:
- topic: "tele/Man_Cave_Fan/LWT"
payload_on: "ON"
payload_off: "OFF"
optimistic: false
qos: 0
retain: true
light:
- name: "Aprils Lamp"
command_topic: "cmnd/Aprils_Lamp/POWER"
state_topic: "tele/Aprils_Lamp/STATE"
state_value_template: "{{value_json.POWER}}"
availability_topic: "tele/Aprils_Lamp/LWT"
brightness_command_topic: "cmnd/Aprils_Lamp/Dimmer"
brightness_state_topic: "tele/Aprils_Lamp/STATE"
brightness_scale: 100
on_command_type: "brightness"
brightness_value_template: "{{value_json.Dimmer}}"
white_value_state_topic: "tele/Aprils_Lamp/STATE"
white_value_command_topic: "cmnd/Aprils_Lamp/White"
white_value_scale: 100
white_value_template: "{{ value_json.Channel[3] }}"
rgb_command_topic: "cmnd/Aprils_Lamp/Color2"
rgb_state_topic: "tele/Aprils_Lamp/STATE"
rgb_value_template: "{{value_json.Color.split(',')[0:3]|join(',')}}"
effect_command_topic: "cmnd/Aprils_Lamp/Scheme"
effect_state_topic: "tele/Aprils_Lamp/STATE"
effect_value_template: "{{value_json.Scheme}}"
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
qos: 1
retain: false
light:
- name: "CR-10 Lamp"
command_topic: "cmnd/cr10light/POWER"
state_topic: "tele/cr10light/STATE"
availability_topic: "tele/cr10light/LWT"
brightness_command_topic: "cmnd/cr10light/Dimmer"
brightness_state_topic: "tele/cr10light/STATE"
white_value_state_topic: "tele/cr10light/STATE"
white_value_command_topic: "cmnd/cr10light/White"
rgb_command_topic: "cmnd/cr10light/Color2"
rgb_state_topic: "tele/cr10light/STATE"
effect_command_topic: "cmnd/cr10light/Scheme"
effect_state_topic: "tele/cr10light/STATE"
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
light:
- name: "Man Cave Light 1"
command_topic: "cmnd/mancavelight1/POWER"
state_topic: "tele/mancavelight1/STATE"
availability_topic: "tele/mancavelight1/LWT"
brightness_command_topic: "cmnd/mancavelight1/Dimmer"
brightness_state_topic: "tele/mancavelight1/STATE"
white_value_state_topic: "tele/mancavelight1/STATE"
white_value_command_topic: "cmnd/mancavelight1/White"
rgb_command_topic: "cmnd/mancavelight1/Color2"
rgb_state_topic: "tele/mancavelight1/STATE"
effect_command_topic: "cmnd/mancavelight1/Scheme"
effect_state_topic: "tele/mancavelight1/STATE"
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
light:
- name: "Man Cave Light 2"
command_topic: "cmnd/mancavelight2/POWER"
state_topic: "tele/mancavelight2/STATE"
availability_topic: "tele/mancavelight2/LWT"
brightness_command_topic: "cmnd/mancavelight2/Dimmer"
brightness_state_topic: "tele/mancavelight2/STATE"
white_value_state_topic: "tele/mancavelight2/STATE"
white_value_command_topic: "cmnd/mancavelight2/White"
rgb_command_topic: "cmnd/mancavelight2/Color2"
rgb_state_topic: "tele/mancavelight2/STATE"
effect_command_topic: "cmnd/mancavelight2/Scheme"
effect_state_topic: "tele/mancavelight2/STATE"
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
light:
- name: "Xanders Light Strip"
command_topic: "cmnd/xanderlightstrip/POWER"
state_topic: "tele/xanderlightstrip/STATE"
availability_topic: "tele/xanderlightstrip/LWT"
brightness_command_topic: "cmnd/xanderlightstrip/Dimmer"
brightness_state_topic: "tele/xanderlightstrip/STATE"
white_value_state_topic: "tele/xanderlightstrip/STATE"
white_value_command_topic: "cmnd/xanderlightstrip/White"
rgb_command_topic: "cmnd/xanderlightstrip/Color2"
rgb_state_topic: "tele/xanderlightstrip/STATE"
effect_command_topic: "cmnd/xanderlightstrip/Scheme"
effect_state_topic: "tele/xanderlightstrip/STATE"
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
light:
- name: "Man Cave Lamp 2"
state_topic: "stat/Man_Cave_Lamp_2/POWER"
command_topic: "cmnd/Man_Cave_Lamp_2/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
light:
- name: "Deck Lights"
state_topic: "stat/Outdoor_Lights/POWER"
command_topic: "cmnd/Outdoor_Lights/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
light:
- name: "Living Room Lamp 1"
state_topic: "stat/merkury1/POWER"
command_topic: "cmnd/merkury1/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
light:
- name: "Living Room Lamp 2"
state_topic: "stat/merkury2/POWER"
command_topic: "cmnd/merkury2/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- name: 'Basement Temperature'
state_topic: "/BasementClimate/BasementClimate/Temperature"
unit_of_measurement: Ā°C
# value_template: '{{ value_json.Temperature }}'
qos: 0
# retain: true
- name: 'Basement Humidity'
state_topic: "/BasementClimate/BasementClimate/Humidity"
unit_of_measurement: '%'
# value_template: '{{ value_json.Humidity }}'
qos: 0
# retain: true
- name: 'Basement Sensor Uptime'
state_topic: "/BasementClimate/Uptime/Uptime"
unit_of_measurement: 'minutes'
qos: 0
# retain: true
- name: "Outdoor Temperature"
state_topic: "tele/Outdoor_Lights/SENSOR"
value_template: "{{ value_json.AM2301.Temperature }}"
unit_of_measurement: "Ā°C"
- name: "Outdoor Humidity"
value_template: "{{ value_json.AM2301.Humidity }}"
unit_of_measurement: "%"
The only item that appears to be working is the first switch that is a fan; that works fine. The other lights , and sensors donāt register. What am I doing so wrong?
I assume this is a typo - and it really says:
availability_topic: "tele/Man_Cave_Fan/LWT"
Nope; not a typo. Thatās the configuration example given from the MQTT switch page.
mqtt:
switch:
- unique_id: bedroom_switch
state_topic: "home/bedroom/switch1"
command_topic: "home/bedroom/switch1/set"
availability:
- topic: "home/bedroom/switch1/available"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 0
retain: true
I see that is an example given, but as you arenāt using any of the options in the availability key, I donāt see the point in using it.
Anyway the next thing I see -
I donāt see:
options in the default schema.
home-assistant:dev
ā home-assistant:light_remove_white_value
opened 12:11PM - 17 Aug 22 UTC
You are amazing! Thanks for contributing to our project!
Please, DO Nā¦ OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
Support for `white_value`, which was deprecated in Home Assistant Core 2021.5, has been removed.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Remove `white_value` support from light
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] š„ Silver
- [ ] š„ Gold
- [ ] š Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
Getting closer. Apparently I had some major yaml errors. Should only have one light:, Sensor:, and switch: line per each set. The lights are the last bit that arenāt working and thatās probably due to how the white_value part has change and I havenāt quite got that part figured out yet.
Here is my current mqtt.yaml file.
switch:
- unique_id: man_cave_fan
# availability_topic: "tele/Man_Cave_Fan/LWT"
payload_on: "ON"
payload_off: "OFF"
optimistic: false
qos: 0
retain: true
- unique_id: man_cave_lamp_2
# availability_topic: "tele/Man_Cave_Lamp_2/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- unique_id: deck_lights
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- unique_id: living_room_lamp_1
availability_topic: "tele/merkury1/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- unique_id: living_room_lamp_2
availability_topic: "tele/merkury2/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
light:
- name: aprils_lamp
schema: json
brightness: true
color_mode: true
supported_color_modes: ["rgbw"]
qos: 1
retain: false
- name: "cr10_lamp"
schema: json
brightness: true
color_mode: true
qos: 1
retain: false
- name: "man_cave_light_1"
schema: json
brightness: true
color_mode: true
qos: 1
retain: false
- name: "man_cave_light_2"
schema: json
brightness: true
color_mode: true
qos: 1
retain: false
qos: 0
# retain: true
qos: 0
# retain: true
qos: 0
# retain: true
Can we just check double check these topics - because there are a few issues that immediately jump out -
Topics generally should not start with /
because what that really means behind the scenes is <empty>/
it will still work but it should be avoided.
is this definitely correct? If so why does humidity and temperature both have this weird pattern of topic - and then uptime - instead of using BasementClimate twice, instead uses it once and then has uptime twice? /BasementClimate/Uptime/Uptime
Since you are migrating - you might as well add unique_id to all the entities that are missing it in this file, if it helps, I just use https://www.uuidgenerator.net/ to generate a UUID and then refresh the page to get a new UUID for the next entity.
Can you list what is actually working from your file and what is not, to make it easier to spot the issue.
The /BasementClimate/BasementClimate, etc is correct and is one of the sensors working and reporting data correctly with that setup.
WRT my mqtt.yaml file, the parts that arenāt working are aprils_lamp, cr10_lamp, man_cave_light_1, and man_cave_light_2. These are all RGBW tuya bulbs that were flashed with Tasmota some time ago.
This was the config for the lights before 2022.9.0 came out that worked.
- platform: mqtt
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
- platform: mqtt
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
- platform: mqtt
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
- platform: mqtt
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
qos: 1
retain: false
It looks like you want to be using the schema: template rather than schema: json. See further down the page for examples:
Looking at Tasmota docs -
mqtt:
light:
- name: "RGB Light"
command_topic: "cmnd/tasmota/POWER"
state_topic: "tele/tasmota/STATE"
state_value_template: "{{ value_json.POWER }}"
availability_topic: "tele/tasmota/LWT"
brightness_command_topic: "cmnd/tasmota/Dimmer"
brightness_state_topic: "tele/tasmota/STATE"
brightness_value_template: "{{ value_json.Dimmer }}"
rgb_command_topic: "cmnd/tasmota/Color2"
rgb_state_topic: "tele/tasmota/STATE"
rgb_value_template: "{{ value_json.Color.split(',')[0:3]|join(',') }}"
effect_command_topic: "cmnd/tasmota/Scheme"
effect_state_topic: "tele/tasmota/STATE"
effect_value_template: "{{ value_json.Scheme }}"
effect_list:
- 0
- 1
- 2
- 3
- 4
payload_on: "ON"
payload_off: "OFF"
See here: Home Assistant - Tasmota in case this still isnāt right - this is all the information they have for the lights. Note they still have the white_value stuff in there so just ignore those parts.
You are right. This got confusing real fast.
Iāve posted a bit of an update over here to my situation. Still having issues getting these specific Merkury bulbs to work correctly.
oldercoder
(Oldercoder)
September 18, 2022, 7:54pm
11
Changes are not only breaking our configuration but also our heart too. Should have been simpler. why not implementing backward compatible solutions. better yet some kind of conversion tool. care for us dear valuable software authors. Thanks million any way.
