I am running HA in container ubuntu in NUC.
I had AdGuard running OK for about 2-3 weeks but one day I don’t know what changed and it stopped working correct.
Add-on version: 2.3.1
You are running the latest version of this add-on.
System: Ubuntu 16.04.6 LTS (amd64 / qemux86-64)
Home Assistant version: 0.105.4
Supervisor version: 200
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] adguard.sh: executing...
[cont-init.d] adguard.sh: exited 0.
[cont-init.d] discovery.sh: executing...
[09:35:42] INFO: Successfully send discovery information to Home Assistant.
[cont-init.d] discovery.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[09:35:42] INFO: Starting AdGuard Home server...
2020/02/18 09:35:42 [info] AdGuard Home, version v0.100.9, channel release
2020/02/18 09:35:42 [info] Upstream 0: 1.1.1.1:53
2020/02/18 09:35:42 [info] Go to http://127.0.0.1:45158
2020/02/18 09:35:42 [info] Starting the DNS proxy server
2020/02/18 09:35:42 [info] Ratelimit is enabled and set to 20 rps
2020/02/18 09:35:42 [info] The server is configured to refuse ANY requests
2020/02/18 09:35:42 [info] DNS cache is enabled
2020/02/18 09:35:42 [info] Creating the UDP server socket
2020/02/18 09:35:42 [info] Listening to udp://[::]:53
2020/02/18 09:35:42 [info] Creating the TCP server socket
2020/02/18 09:35:42 [info] Listening to tcp://[::]:53
2020/02/18 09:35:42 [info] Entering the UDP listener loop on [::]:53
2020/02/18 09:35:42 [info] Entering the tcp listener loop on [::]:53
[09:35:42] INFO: Starting NGinx...
nginx: [alert] detected a LuaJIT version which is not OpenResty's; many optimizations will be disabled and performance will be compromised (see https://github.com/openresty/luajit2 for OpenResty's LuaJIT or, even better, consider using the OpenResty releases from https://openresty.org/en/download.html)
I tried with Pi-Hole and had the same nginx error (whatever that is).
Unistalled both of them and tried to install adguard again but I get an error message saying “Failed to install addon, Unknown Error, see logs”.
Then in logs:
20-02-20 22:18:49 ERROR (SyncWorker_15) [hassio.docker.interface] Can't install hassioaddons/adguard-amd64:2.3.1 -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:38263->[::1]:53: read: connection refused").
After some hours of searching,I will try to sum up where I believe the problem is.
1st) The NUC has static IP through my router. I guess I should have it through this procedure but I don’t know how to do that since there is no “import from USB” in the system tab. Probably the instructions are only applied to RPI.
2nd) I might have “damaged” the DNS and that’s why I can’t install any add-on. Again I don’t know how to change DNS of NUC. Maybe it is linked with the 1st issue.
3rd) I don’t know how and where to run the command “hassio su repair” (or something like that which I don’t remember exactly now), which could probably repair the DNS issue.
Some of the things that I already tried:
In homeassistant:
and debug:
Also I would like to note that I don’t have SSH add-on installed in HA.
I hope I don;t need to unistall and install HA all over again!!!
Thank you for reading and posting any suggestions!
