Can't install node-red
Tried all. Can’t find it in add-ons. Tried to install with HACS, then activate in integrations. But no luck to get it in add-ons. I’m running latest version of hassos on a RPI4. Tried to add the repository in add-ons, but no luck there
Just to make sure… You went to Supervisor -> Add-on store and searched for “node” and nothing shows up? Normally you wouldn’t even need to add the repo…
FYI: The one from HACS/integrations is “only” an extension to the Add-on and not Node-Red itself.
Yepp, nothing comes up when I’m searching
Can you give me some examples of Add-ons that are there?
Did you add this repo?
https://addons.community
You mentioned you added a repo - which one?
Was it the one in my comment above?
Don’t know wich one. But it didn’t work so uninstalled it. It’s strange though, I can only search the official add-ons. If I remember correctly, I had a lot more add-ons to choose from about a month ago.
Yeah that’s also what I noticed. Try that one, I checked my repo-list and found that for the community addons.
Your link above isn’t complete
it is?
or this
yeah, that one I’ve tried. Just says Unknown
Don’t know what I am doing wrong…
Did you try to reload from the 3-dot menu? What happens if you try to add https://addons.community ? Also unknown?
At the bottom it says you might have to check your system log:
HELP: REPOSITORY IS NOT SHOWING UP
If you have added a repository, but it’s not showing up, it means that the repository contains invalid configuration. Go to the Supervisor panel and then the System tab to find the System log. It should tell you what went wrong. Report this information to the repository author.
20-09-12 14:23:18 ERROR (MainThread) [supervisor.store] Can’t load from repository https://github.com/hassio-addons/addon-node-red/tree/v6.0.4
20-09-12 14:23:18 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/hassio-addons/addon-node-red/tree/v6.0.4 repository
20-09-12 14:23:18 ERROR (MainThread) [supervisor.store.git] Can’t clone https://github.com/hassio-addons/addon-node-red/tree/v6.0.4 repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/addon-node-red/tree/v6.0.4 /data/addons/git/981db822
stderr: 'Cloning into ‘/data/addons/git/981db822’…
fatal: repository ‘https://github.com/hassio-addons/addon-node-red/tree/v6.0.4/’ not found
You can’t add this: https://github.com/hassio-addons/addon-node-red/tree/v6.0.4 as a repo. You have to add this: https://github.com/hassio-addons/repository
Haha, of course! Maybe I should leave the computer for a while and get some fresh air :slight_smile:
No, now it’s time for some nice node-red automations :wink:
Yeah, Never used it before sm got some reading to do :face_with_monocle:
I’m having the same issue where the add-on isn’t available in the Supervisor store. I followed the instructions above but it wont let m add any repository. Not even the example from https://github.com/home-assistant/hassio-addons-example
