Can't Remove Docker Containers
The script is saying exactly what it does. So you just have to revert that.
Simply do the following:
stop services
(thanks @IcyMidnight)
sudo systemctl stop hassio-supervisor.service
sudo systemctl stop hassio-apparmor.service
disable services
sudo systemctl disable hassio-supervisor.service
sudo systemctl disable hassio-apparmor.service
remove services
sudo rm -rf /etc/systemd/system/hassio-supervisor.service
sudo rm -rf /etc/systemd/system/hassio-apparmor.service
removing hassio folders (except the config folder)
sudo rm -rf /usr/sbin/hassio-supervisor
sudo rm -rf /usr/sbin/hassio-apparmor
Now delete the remaining docker images like you always do.
If you want to delete your Home Assistant config files,
Do the following, but be carefull! Your config is lost forever:
sudo rm -rf /usr/share/hassio/
