Suddenly I can’t see the config folder using Samba. Raspberry Pi 3, Windows 10
I’ve restarted Samba but to no avail. Help!
Any suggestions?
Samba log shows other subfolders but not config
added interface wlan0 ip=192.168.1.108 bcast=192.168.1.255 netmask=255.255.255.0
added interface eth0 ip=2a02:c7c:b235:3d00:9f5e:3afe:8e01:52a bcast= netmask=ffff:ffff:ffff:ffff::
added interface eth0 ip=fda1:8d6f:ea34:0:c9af:4801:d5c3:650e bcast= netmask=ffff:ffff:ffff:ffff::
added interface eth0 ip=192.168.1.109 bcast=192.168.1.255 netmask=255.255.255.0
making subnet name:192.168.1.109 Broadcast address:192.168.1.255 Subnet mask:255.255.255.0
create_subnets: ignoring non IPv4 interface.
making subnet name:192.168.1.108 Broadcast address:192.168.1.255 Subnet mask:255.255.255.0
create_subnets: Ignoring loopback interface.
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
added interface lo ip=127.0.0.1 bcast=127.255.255.255 netmask=255.0.0.0
added interface wlan0 ip=2a02:c7c:b235:3d00:6266:d583:ff34:946a bcast= netmask=ffff:ffff:ffff:ffff::
added interface wlan0 ip=fda1:8d6f:ea34:0:7e6a:f797:d69d:818b bcast= netmask=ffff:ffff:ffff:ffff::
smbd version 4.18.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2023
uid=0 gid=0 euid=0 egid=0
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section “[homeassistant]”
Processing section “[addons]”
Processing section “[addon_configs]”
Processing section “[ssl]”
Processing section “[share]”
Processing section “[backup]”
Processing section “[media]”
INFO: Profiling support unavailable in this build.
No builtin backend found, trying to load plugin
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.1.108
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.1.109
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.1.108
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.1.109
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.1.108 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.1.108
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.1.109 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.1.109
Samba name server HOMEASSISTANT is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.108
Samba name server HOMEASSISTANT is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.109
check_ntlm_password: authentication for user [pjrhassio] → [pjrhassio] → [pjrhassio] succeeded
idmap range not specified for domain ‘*’
eapr210920886-1 (ipv4:192.168.1.71:64103) signed connect to service backup initially as user root (uid=0, gid=0) (pid 160)
netbios connect: name1=LOCALHOST 0x20 name2=HOMEASSISTANT 0x0
netbios connect: local=localhost remote=homeassistant, name type = 0
