Hi!
I’m trying to get rid of my 1Home-System. So far I set up Home Assistant for the first time and I’m very excited about everything is working with an ease!
There’s just one thing: Home Assistant does not set the temperature via KNX. Read ist fine, write just won’t work.
Here’s what I have in config:
climate:
- name: "Wohnzimmer Heizung"
temperature_address: "2/1/0"
target_temperature_state_address: "2/2/0"
temperature_step: 1.0
I do not have access to the KNX-System directly. All information I do have comes out of the 1Home setup (used the .knxproj file there). Using 1Home connected to HomeKit works fine.
Setting the temperature using the dev-tool (set value for entity) also works. But I cannot change temperature using the card or Apple-HomeApp.
Any help very appreciated! Thanks in advance.
