File “/esphome/esphome/yaml_util.py”, line 425, in _load_yaml_internal
return _load_yaml_internal_with_type(ESPHomeLoader, fname, f_handle)
61 Caret/chevron
File “/esphome/esphome/yaml_util.py”, line 447, in _load_yaml_internal_with_type
return loader.get_single_data() or OrderedDict()
24 Caret/chevron
File “/usr/local/lib/python3.11/dist-packages/yaml/constructor.py”, line 51, in get_single_data
return self.construct_document(node)
29 Caret/chevron
File “/usr/local/lib/python3.11/dist-packages/yaml/constructor.py”, line 55, in construct_document
data = self.construct_object(node)
27 Caret/chevron
File “/usr/local/lib/python3.11/dist-packages/yaml/constructor.py”, line 100, in construct_object
data = constructor(self, node)
23 Caret/chevron
File “/esphome/esphome/yaml_util.py”, line 86, in wrapped
res = fn(loader, node)
16 Caret/chevron
File “/esphome/esphome/yaml_util.py”, line 156, in construct_yaml_map
value = self.construct_object(value_node)
33 Caret/chevron
23 Caret/chevron
16 Caret/chevron
File “/esphome/esphome/yaml_util.py”, line 255, in construct_secret
secrets = _load_yaml_internal(self._rel_path(SECRET_YAML))
48 Caret/chevron
61 Caret/chevron
24 Caret/chevron
29 Caret/chevron
27 Caret/chevron
23 Caret/chevron
16 Caret/chevron
33 Caret/chevron
23 Caret/chevron
16 Caret/chevron
48 Caret/chevron
61 Caret/chevron
24 Caret/chevron
29 Caret/chevron
27 Caret/chevron
23 Caret/chevron
16 Caret/chevron
File “/esphome/esphome/yaml_util.py”, line 155, in construct_yaml_map
key = self.construct_object(key_node)
31 Caret/chevron
23 Caret/chevron
File “/esphome/esphome/yaml_util.py”, line 96, in wrapped
res.from_node(node)
File “/esphome/esphome/yaml_util.py”, line 57, in from_node
self._esp_range = DocumentRange.from_marks(node.start_mark, node.end_mark)
56 Caret/chevron
File “/esphome/esphome/core/init.py”, line 403, in from_marks
DocumentLocation.from_mark(start_mark), DocumentLocation.from_mark(end_mark)
38 Caret/chevron
File “/esphome/esphome/core/init.py”, line 384, in from_mark
return cls(mark.name, mark.line, mark.column)
38 Caret/chevron
RecursionError: maximum recursion depth exceeded
2024-02-23 10:57:44,534 ERROR 500 GET /secret_keys (0.0.0.0) 109.07ms
2024-02-23 10:57:46,391 INFO 304 GET /devices (0.0.0.0) 1.63ms
2024-02-23 10:57:51,402 INFO 304 GET /devices (0.0.0.0) 2.56ms
2024-02-23 10:57:57,316 INFO 304 GET /devices (0.0.0.0) 1.48ms
