Canvas-gauge-card works only a few minutes
I’m using the lovelace canvas-gauge-card for a power meter.
It’s very nice, and perfect for my use, but on iPhone, the gauge disappears/goes all white after a few (1-10) minutes.
On iPad it works fine. On iPhone (5, 6s, 11Pro) it disappears in the HomeAssistant App, in Chrome, Safari and Edge.
I have to “kill” the app and restart it. Then it’s ok for another few minutes. I’ve tried flushing the cache as well.
Anyone else who has experienced this? And hopefully solved it?
Or, maybe you have an alternative gauge that’s as good-looking?
I use several canvas gauges and don’t have a problem. Post your yaml for the gauge in question.
type: custom:canvas-gauge-card
entity: sensor.effekt_totalt
card_height: 300
shadow_height: 25%
gauge:
  type: radial-gauge
  title: Totalt
  borderShadowWidth: 0
  borderOuterWidth: 0
  borderMiddleWidth: 0
  borderInnerWidth: 0
  highlightsWidth: 30
  numbersMargin: 16
  width: 285
  height: 300
  minValue: 0
  maxValue: 14000
  startAngle: 45
  ticksAngle: 270
  animation: false
  colorPlate: lightyellow
  valueBox: true
  valueDec: 0
  valueBoxWidth: 1
  valueBoxStroke: 0
  colorValueBoxBackground: white
  colorValueText: black
  colorTitle: black
  needleType: arrow
  needleWidth: 14
  needleEnd: 93
  colorNeedle: red
  needleShadow: true
  needleCircleSize: 5
  needleCircleOuter: true
  needleCircleInner: true
  fontValueSize: 40
  fontTitleSize: 40
  fontNumbersSize: 40
  majorTicks:
    - '0'
    - '2'
    - '4'
    - '6'
    - '8'
    - '10'
    - '12'
    - '14'
  minorTicks: 4
  strokeTicks: false
  highlights:
      to: 2000
      color: rgba(0, 0, 255, .25)
      to: 5000
      color: rgba(0, 250, 0, .65)
      to: 10000
      color: rgba(250, 200, 0, .45)
      to: 14000
      color: rgba(200, 0, 0, .65)
  borders: false
I also find it difficult to make the gauge fill the entire card/screen width. What’s the trick?
If you could post a (simple?) sample that works for you, I can test it here and look for differences.
I tried one of the processor_use examples from git. That disappears too.
I’m using the latest version of everything.
Can you include a screen shot of what the gauge looks like when it is visible?
The style section covers size. Here is an example of one of mine:
  - type: custom:canvas-gauge-card
    entity: sensor.purpleair_aqi_a
    style:
      top: 50%
      left: 50%
      width: null
      heigth: null
      box-shadow: none
      background-color: transparent
    gauge:
      type: radial-gauge
      title: AQI
      width: 230
      height: 230
      minValue: 0
      maxValue: 500
      startAngle: 40
      ticksAngle: 280
      valueBox: true
      majorTicks:
        - '0'
        - '50'
        - '100'
        - '150'
        - '200'
        - '250'
        - '300'
        - '350'
        - '400'
        - '450'
        - '500'
      minorTicks: 5
      strokeTicks: true
      highlights:
          to: 50
          color: rgba(104, 225, 67, .75)
          to: 100
          color: rgba(255, 255, 85, .75)
          to: 150
          color: rgba(239, 133, 51, .75)
          to: 200
          color: rgba(234, 51, 36, .75)
          to: 300
          color: rgba(140, 26, 75, .75)
          to: 500
          color: rgba(115, 20, 37, .75)
      borders: 'no'
      needleType: arrow
      needleWidth: 4
      needleCircleSize: 7
      needleCircleInner: false
      animationDuration: 1500
      animationRule: linear
      valueBoxBorderRadius: 10
      colorValueBoxRect: '#222'
      colorValueBoxRectEnd: '#333'
      valueDec: 0
      valueInt: null
If you want more examples:
https://github.com/GlennGoddard/CanvasGaugeBackgrounds
Width and Height should be the same in most cases.
Your major ticks ‘might’ be a problem, but maybe not.
Minor ticks of 4 is a bit small from a range of 0 to 14,000; that is putting over a thousand tick marks into the gauge. Try 500 for now, so you get 28 breaks that ‘should’ line up with the majorTicks.
Try this for now and we can move on from there.
It seems like the “timeout” period depends on how often the sensor is updated.
A gauge for a sensor that updates every 2 seconds died after a few minutes, but one that updates once every few minutes has been running for 2 hours so far.
Typical memory-leak behaviour? (btw: The minor ticks is correct at 4.)
I’m not sure about the updating, I have some that update every 3 seconds and some that update once a day. Can you post a picture of the displayed gauge?
The two-second sensor gauge died too, it just took longer. So did the example you posted.
I gave up on calvas-gauge-card, and went for “custom:flex-horseshoe-card” instead. It’s more complicated, but very nice.
And has been stable for 2 days, so I guess it should be ok.
I don’t know what to think, your card looks like this to me:
xcv
Try Ctrl-F5 and see what happens.
I have the gauges in Horizontal and Vertical layouts. You need to adjust the sizing.
your style just doesn’t work in a horizontal set
I have found some time the canvas gauges sometimes has a caching problem in browsers and I have eliminated that problem for my self by making the gauges the foreground on a picture-element card (Examples)
Yeah, I’ve read that before
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
        entity: sensor.l1_current
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorBorderOuter: '#333'
          colorBorderOuterEnd: '#111'
          colorBorderMiddle: '#222'
          colorBorderMiddleEnd: '#111'
          colorBorderInner: '#111'
          colorBorderInnerEnd: '#333'
          colorNumbers: '#ccc'
          colorPlate: ''
          colorTitle: '#f5f5f5'
          colorUnits: '#f5f5f5'
          height: 150
          highlights:
            - color: rgba(74, 123, 180, .75)
              to: 16
            - color: rgba(4, 205, 24, .75)
              to: 20
            - color: rgba(239, 93, 13, .75)
              to: 26
          majorTicks:
            - '0'
            - '2'
            - '4'
            - '6'
            - '8'
            - '10'
            - '12'
            - '14'
            - '16'
            - '18'
            - '20'
            - '22'
            - '24'
            - '26'
          maxValue: 26
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Proud L1
          units: ampér - A
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 1
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
        entity: sensor.l2_current
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
          transform: scale(1,1) translate(-50%,-50%)
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 16
              to: 20
              to: 26
          majorTicks:
            - '0'
            - '2'
            - '4'
            - '6'
            - '8'
            - '10'
            - '12'
            - '14'
            - '16'
            - '18'
            - '20'
            - '22'
            - '24'
            - '26'
          maxValue: 26
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Proud L2
          units: ampér - A
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 1
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
        entity: sensor.l3_current
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 16
              to: 20
              to: 26
          majorTicks:
            - '0'
            - '2'
            - '4'
            - '6'
            - '8'
            - '10'
            - '12'
            - '14'
            - '16'
            - '18'
            - '20'
            - '22'
            - '24'
            - '26'
          maxValue: 26
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Proud L3
          units: ampér - A
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 1
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
    cards:
        entity: sensor.l1_voltage
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
          transform: scale(0,5) translate(-50%,-50%)
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 207
              to: 253
              to: 275
          majorTicks:
            - '0'
            - '25'
            - '50'
            - '75'
            - '100'
            - '125'
            - '150'
            - '175'
            - '200'
            - '225'
            - '250'
            - '275'
          maxValue: 275
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Napětí L1
          units: Volt - V
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 2
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
        entity: sensor.l2_voltage
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 207
              to: 253
              to: 275
          majorTicks:
            - '0'
            - '25'
            - '50'
            - '75'
            - '100'
            - '125'
            - '150'
            - '175'
            - '200'
            - '225'
            - '250'
            - '275'
          maxValue: 275
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Napětí L2
          units: Volt - V
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 2
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
        entity: sensor.l3_voltage
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 207
              to: 253
              to: 275
          majorTicks:
            - '0'
            - '25'
            - '50'
            - '75'
            - '100'
            - '125'
            - '150'
            - '175'
            - '200'
            - '225'
            - '250'
            - '275'
          maxValue: 275
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Napětí L3
          units: Volt - V
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 2
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
    cards:
        entity: sensor.l1_power
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 1000
              to: 5000
              to: 6000
          majorTicks:
            - '0'
            - '6'
            - '12'
            - '18'
            - '24'
            - '30'
            - '36'
            - '42'
            - '48'
            - '54'
            - '60'
          maxValue: 6000
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Příkon L1
          units: Watt - W x 100
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 1
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
        entity: sensor.l2_power
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 1000
              to: 5000
              to: 6000
          majorTicks:
            - '0'
            - '6'
            - '12'
            - '18'
            - '24'
            - '30'
            - '36'
            - '42'
            - '48'
            - '54'
            - '60'
          maxValue: 6000
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Příkon L2
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 1
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
        entity: sensor.l3_power
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          animation: false
          animatedValue: true
          borders: true
          colorPlate: ''
          height: 150
          highlights:
              to: 1000
              to: 5000
              to: 6000
          majorTicks:
            - '0'
            - '6'
            - '12'
            - '18'
            - '24'
            - '30'
            - '36'
            - '42'
            - '48'
            - '54'
            - '60'
          maxValue: 6000
          minValue: 0
          minorTicks: 2
          startAngle: 45
          strokeTicks: true
          ticksAngle: 270
          title: Příkon L3
          type: radial-gauge
          valueBox: true
          valueDec: 1
          valueInt: 1
          width: 150
          needleType: arrow
          needleWidth: 2
          needleCircleSize: 7
    entity: sensor.power_total_w
    font_size: 1em
    gauge:
      animation: false
      borders: true
      colorPlate: ''
      height: 150
      highlights:
          to: 6000
          to: 16000
          to: 20000
      majorTicks:
        - '0'
        - '2'
        - '4'
        - '6'
        - '8'
        - '10'
        - '12'
        - '14'
        - '16'
        - '18'
        - '20'
      maxValue: 20000
      minValue: 0
      minorTicks: 2
      startAngle: 45
      strokeTicks: true
      ticksAngle: 270
      title: Příkon celkem
      type: radial-gauge
      valueBox: true
      valueDec: 1
      valueInt: 1
      width: 220
      needleType: arrow
      needleWidth: 2
      needleCircleSize: 7
  - type: vertical-stack
    cards:
      - type: custom:bar-card
        entities:
          - entity: sensor.l1_voltage
    style:
      top: 50%
      left: 50%
      width: null
      heigth: null
      box-shadow: none
    gauge:
      type: radial-gauge
      title: AQI
      width: 230
      height: 230
      minValue: 0
      maxValue: 500
      startAngle: 40
      ticksAngle: 280
      valueBox: true
      majorTicks:
        - '0'
        - '50'
        - '100'
        - '150'
        - '200'
        - '250'
        - '300'
        - '350'
        - '400'
        - '450'
        - '500'
      minorTicks: 5
      strokeTicks: true
      highlights:
          to: 50
          to: 100
          to: 150
          to: 200
          to: 300
          to: 500
      borders: 'no'
      needleType: arrow
      needleWidth: 4
      needleCircleSize: 7
      valueDec: 0
      valueInt: null
    cards:
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          type: radial-gauge
          title: AQI
          width: 150
          height: 150
          minValue: 0
          maxValue: 500
          startAngle: 40
          ticksAngle: 280
          valueBox: true
          majorTicks:
            - '0'
            - '50'
            - '100'
            - '150'
            - '200'
            - '250'
            - '300'
            - '350'
            - '400'
            - '450'
            - '500'
          minorTicks: 5
          strokeTicks: true
          highlights:
              to: 50
              to: 100
              to: 150
              to: 200
              to: 300
              to: 500
          borders: 'no'
          needleType: arrow
          needleWidth: 4
          needleCircleSize: 7
          valueDec: 0
          valueInt: null
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          type: radial-gauge
          title: AQI
          width: 150
          height: 150
          minValue: 0
          maxValue: 500
          startAngle: 40
          ticksAngle: 280
          valueBox: true
          majorTicks:
            - '0'
            - '50'
            - '100'
            - '150'
            - '200'
            - '250'
            - '300'
            - '350'
            - '400'
            - '450'
            - '500'
          minorTicks: 5
          strokeTicks: true
          highlights:
              to: 50
              to: 100
              to: 150
              to: 200
              to: 300
              to: 500
          borders: 'no'
          needleType: arrow
          needleWidth: 4
          needleCircleSize: 7
          valueDec: 0
          valueInt: null
        style:
          top: 50%
          left: 50%
          width: null
          heigth: null
          box-shadow: none
        gauge:
          type: radial-gauge
          title: AQI
          width: 150
          height: 150
          minValue: 0
          maxValue: 500
          startAngle: 40
          ticksAngle: 280
          valueBox: true
          majorTicks:
            - '0'
            - '50'
            - '100'
            - '150'
            - '200'
            - '250'
            - '300'
            - '350'
            - '400'
            - '450'
            - '500'
          minorTicks: 5
          strokeTicks: true
          highlights:
              to: 50
              to: 100
              to: 150
              to: 200
              to: 300
              to: 500
          borders: 'no'
          needleType: arrow
          needleWidth: 4
          needleCircleSize: 7
          valueDec: 0
          valueInt: null
yes - extremely ugly
