šŸ”¹ Card-mod - Add css styles to any lovelace card
At least w/o Layout card everything is aligned:
type: vertical-stack
cards:
  - type: entities
    entities:
      - sun.sun
      - sun.sun
  - type: horizontal-stack
    cards:
      - type: custom:button-card
        icon: mdi:home-roof
        icon: mdi:floor-plan
        icon: mdi:youtube-tv
        icon: mdi:server
    cards:
        icon: mdi:home-roof
        icon: mdi:server
    cards:
        icon: mdi:server
Could anyone explain why this is not working?
I want to change the state color text based on the state of it.
type: entities
entities:
  - entity: sensor.screen_sensor_opslagkamer
style: |
      :host {
        color:
          {% if (states.binary_sensor.screen_grote_slaapkamer_contact == 'On')}
            red
          {% else %}
            green
          {% endif %}
Wrong indentation (at least).
:host should be used for a row, not for a whole card.
When I do it like this:
type: entities
entities:
    style: |
     :host {
       color:
          red
        {% else %}
          green
        {% endif %}
It errors out with:
Configuratiefouten ontdekt:
  • Verplichte sleutel ā€œentities.0.typeā€ ontbreekt.
  • Verplichte sleutel ā€œentities.0.nameā€ ontbreekt.
  • Verplichte sleutel ā€œentities.0.tap_actionā€ ontbreekt.
Hi everyone,
what am I doing wrong?
I want the icon to change at 50%
type: glance
entities:
  - entity: cover.shellyswitch25_ba854b
    style: |
      :host {
        --card-mod-icon:
          {% if is_state_attr(config.entity, "current_position", "50") %}
          mdi:check-circle
          {% else %}
          mdi:alert-circle
          {% endif %};
Add card_mod, otherwise it started giving an error:
In short:
  1. It was required to use only "style" keyword before card-mod 3.0.
  2. Starting from card-mod 3.0, the new "card_mod" keyword was added to enable card-mod where it did not work before (but the old notation was supposed to be still working).
  3. Recently HA was updated and the Editor started giving an error if no "card_mod" keyword is specified. But the old notation (w/o "card_mod" keyword ) still works - you just cannot save changes in the Editor!
You specified the same icon for all conditions.
Try using search here or at least read the 1st post: šŸ”¹ Card-mod - Add css styles to any lovelace card - #1238 by Ildar_Gabdullin
Hi sorry, I donā€™t understand.
I read the 1st post, but canā€™t get any further.
I would like to display another icon when the roller blind is open at 50%.
So there is a link on the 1st post to another post which contains a list of styles.
Try a bit at least.
If you meant the two links, unfortunately I havenā€™t found anything that can help me.
Nothing with state_attr.
Icon color is not a problem, but I want to display a different icon using the attributes.
And there is nothing, except via icon_template.
Sorry if I misunderstood you.
This can be done by:
  • template sensor
  • Custom UI
  • config-template-card
As for me, I know nothing about changing an icon by card-mod. By using card-mod you may change icon color, icon size.
see: GitHub - thomasloven/lovelace-card-mod: šŸ”¹ Add CSS styles to (almost) any lovelace card
  - type: entities
    title: Snapshots
    entities:
      - entity: sensor.snapshot_backup
        card_mod:
          style: |
            :host {
              --card-mod-icon:
                {% if states(config.entity) == 'backed_up' %} mdi:check-circle
                {% else %} mdi:alert-circle
                {% endif %};
              --paper-item-icon-color:
                {% if states(config.entity) == 'backed_up' %} green
                {% else %} red
                {% endif %};
Any idea, why
secondary_info: true
is not working here? With this, I cannot save the card and see lotā€™s of errors.
Because of this, probably:
Aaaah. Yes. Was not aware, that it only works with card_mod. Even without this completely, I got the errors. With card_mod and new notation, it is working. Great.
Update: No, not the root cause. It worked once. Back in edit mode, the errors are there again.
O.k. If I use something different than true or false, e.g. a or tru or ā€¦ it is working without errors at the moment.
It was clearly specified ā€œundocumented featureā€ - i.e. probably it is not supposed to work and it may stop working one day.
Here is a picture from my setup:
You can see that:
  • the style works
  • there are errors
I bet that if you are in yaml-mode and create a card with this code then the card will work.
These are Editor issues. The Editor performs syntax checks and gives errors if smth is not as per syntax rules. But as we can see these wrong code works))).
Hi everybody
I have a few RGB downlighters on my verandah that are working great and I would like to display (not change) their status as a bunch of icons only in Lovelace. The native Button card works well and it updates the colour of the icon to match the colour of the light. My problem is I need to remove the background and the shadow. My CSS skills are non-existent, so I was unable to apply Card-mod to the Button card. Just to be clear, I tried this on the vanilla Lovelace Button card. Romriderā€™s custom button card is incredible, but it doesnā€™t follow the colour of the light, so it wonā€™t work for my application.
The closest I could get using the Button card was to stack them in the ā€œcustom:vertical-stack-in-cardā€, but it still doesnā€™t remove all the shadows. It looks like this:
and the Yaml looks like this (up to the first light):
          - type: custom:vertical-stack-in-card
            horizontal: true
            cards:
              - entity: light.verandah
                type: 'custom:button-card'
                show_name: false
                tap_action:
                  action: toggle
                cards:
                    horizontal: true
                    cards:
                        - type: button
                          entity: light.vo2p
                          icon_height: 30px
                          show_name: false
So as you can see, it is close, but not there.
Next stop was to use the excellent custom:paper-buttons-row. It formats beautifully, but it doesnā€™t follow the colour. I set the icon colour with a template and it looks great, but it only updates on page reloads. :frowning: I will also have to manage the colours with some more templating when the RGB attributes drop away.
Here is the yaml up to the first light:
            horizontal: true
            cards:
                show_name: false
                tap_action:
                  action: toggle
              - type: entities
                entities:
                  - type: custom:paper-buttons-row
                    buttons:
                      - - entity: light.vo2p
                          layout: icon
                          style:
                            button:
                              color: >-
                                 rgb({{(states.light.vo2p.attributes.rgb_color[0] | int)}},{{(states.light.vo2p.attributes.rgb_color[1] | int)}},{{(states.light.vo2p.attributes.rgb_color[2] | int)}})
So my question are:
  1. Is it possible to remove the background and shadow of the native Lovelace Button card with Card-mod? If it is, I would really appreciate a small example.
  2. If not, is it possible to update the card (maybe every 10 s or so)?
  3. If somebody managed to achieve this in some other way, please let me know.
  • the style works
even not this. Most of the time, this is not the case as well and I have only a greyed out card with a ircle. And you are not able to save with these errors.
But anyway, as long it is working with foo or bar or tru or whatever <> true/false, is is finefor me for now. :wink:
Did not understand you. But as long as it is fine for you - OK
Styling stack-in-card (specially for @Jens_Wymeersch):
Similar to vertical-stack:
type: 'custom:stack-in-card'
title: Some title
keep:
  background: true
  box_shadow: true
  margin: true
  outer_padding: true
  border_radius: true
cards:
  - type: entities
    entities:
      - entity: sun.sun
      - entity: sun.sun
    card_mod:
      style: |
        ha-card {
          height: 200px !important;
  - type: entity
    entity: sun.sun
    card_mod:
      style: |
        ha-card {
          height: 150px !important;
card_mod:
  style: |
    ha-card {
      border-style: solid;
      border-width: 5px;
      border-radius: 10px;
      background-image: linear-gradient(to right, red,orange,yellow,green,blue,indigo,violet);
      --ha-card-header-color: white;
      --ha-card-header-font-size: 40px;
      height: 550px !important;
      --vertical-stack-card-margin: 0px 20px 80px 20px;
      --ha-card-background: rgba(50,50,50,0.3);
