e-raser
January 4, 2023, 6:51pm
4134
Please note this does not seem to work (anymore) this way:
Using this example, also the entity name (āNetwork throughputā) is changed instead of only the value area.
I am applying this to an entities card inside a grid card.
Instead, one should use .text-content:not(.info):after
and .text-content:not(.info)
to exclude .info
What I could not fix so far, is the entity value being aligned at the bottom (because of the invisible original value space above) which is looking quite ugly
ā Update: for this, using line-height: 0px;
inside .text-content:not(.info)
did the trick.
e-raser
January 4, 2023, 9:44pm
4136
Indeed, youāre absolutely right. Tested it once again: working.
I have no idea why it didnāt for my use-caseā¦
Probably because I already had some styling (colorizing) in there and the navigation is different.
Your example:
style:
hui-generic-entity-row: |
What I had used from one of your other examples:
style:
Full example
type: grid
title: Abfall-Kalender
columns: 1
square: false
cards:
- type: entities
entities:
- entity: sensor.fritzbox_gigabytes_received
name: Network throughput
- entity: sensor.fritzbox_gigabytes_sent
style:
.text-content::after {
content: "{{states(config.entity)|float*1024}} KBit/s";
color: var(--primary-text-color);
.text-content {
color: transparent;
- type: entities
title: Abholung heute ā
state_color: true
entities:
- entity: calendar.abfall_home
icon: mdi:home-map-marker
style:
#state-badge {
{% if is_state(config.entity, 'on') %}
color: red;
{% endif %}
.info.pointer {
color: red;
font-weight: 700;
{% endif %}
.text-content:not(.info) {
color: red;
{% endif %}
.text-content:not(.info):after {
content: "Ja, heute!";
color: red;
font-weight: 700;
{% else %}
content: "Nein";
{% endif %}
color: transparent;
line-height: 0px;
I mean it is still working, so nevermind - my fault, wrong alarm.
As mentioned in
OK hereās a real special one. One of the hardest for me personal, even it should be very easy⦠basically.
How to apply
ha-svg-icon {
color: green;
to a custom:bar-card generated by custom:auto-entities?
Here's the code snippet (look for "sensor.abfall_home_bio" / see "full tree" below!) - type: custom:auto-entities
card:
type: custom:bar-card
title: ''
limit_value: false
ā¦
I need to learn the navigation stuff, finally. |
and $: |
are just random characters to me and their positioning too
kajmaj
January 5, 2023, 8:07am
4137
I have following part of LovelaceUI on my wall panels.
I need to change height of the weather card to be aligned with cards on the left and right.
To be more precise, I am able to adjust card height but not to have content adopted to the new size - top padding is not changed and bottom padding is broken, solution seems to me to decrease space between the icon and day or temperatures and precipitation .
So far use"
style: |
ha-card {
height: 178px;
background: none;
font-variant: small-caps;
display: flex;
Could anybody advice the proper solution?
rs443
January 7, 2023, 2:08pm
4138
Hi! I need help to move the text/stage/title āGarageā in my card a few pixels up.
Does anyone have a solution?
Current style:
style: |
style: |
ha-card {
border: none;
--icon-size: 70px;
Full card:
type: custom:stack-in-card
mode: vertical
card_mod:
style: |
ha-card {
height: 110px;
border: none;
background: rgba(var(--rgb-green-color), 0.10);
cards:
primary: Garage
secondary: ''
icon: mdi:garage
icon_color: green
tap_action:
action: none
style: |
ha-card {
border: none;
--icon-size: 70px;
- type: custom:mushroom-chips-card
alignment: end
style: |
ha-card {
--chip-border-width: 0;
#--chip-spacing: 20px;
#margin-top: -45px;
margin: -30px 10px 0px 0px;
chips:
- type: light
entity: light.hue7
content_info: none
icon: mdi:ceiling-light
use_light_color: true
style: |
ha-card {
{% set r = state_attr(config.entity, 'rgb_color')[0] %}
{% set g = state_attr(config.entity, 'rgb_color')[1] %}
{% set b = state_attr(config.entity, 'rgb_color')[2] %}
{% set br = state_attr(config.entity, 'brightness')%}
background: rgba( {{r}}, {{g}}, {{b}}, {{(br*0.00045+0.05)}}) !important;
{% else %}
opacity: 50%;
background: #00000000 !important;
{% endif %}
- type: light
entity: light.huemirror1
content_info: none
icon: mdi:wall-sconce-flat
style: |
ha-card {
{% else %}
opacity: 50%;
{% endif %}
- type: entity
entity: switch.handdukshangare
icon_color: deep-orange
icon: mdi:radiator
content_info: none
tap_action:
action: toggle
style: |
ha-card {
{% if is_state(config.entity, 'off') %}
opacity: 50%;
{% else %}
background: rgba(var(--rgb-deep-orange-color), 0.15) !important;
{% endif %}
- type: light
entity: light.hue6
content_info: none
style: |
ha-card {
{% else %}
opacity: 50%;
{% endif %}
Edit: Solved it:
style: |
ha-card {
border: none;
--icon-size: 70px;
mushroom-state-info {
margin-top: -20px;
e-raser
January 7, 2023, 8:01pm
4139
Stumbled over the same thing, as nearly all my modded cards look very broken now as I updated to HA Core 2022.11. Example:
Instead of using box-shadow: none;
for the ha-card
, using border-width: 0px;
seems to do the trick now. Hopefully I can just search + replace this in all my dashboards, otherwise doing this manually would easily take me 3 to 5 hours.
ā¦and nothing in the 2022.11: A heck of a release! - Home Assistant release notes to have a chance of discovering this before doing the update - or did I miss something? Is there maybe a dev corner or something?
e-raser
January 7, 2023, 8:03pm
4140
But what if āmy themeā is the default HA theme?
Iām pretty sure this one-liner is not a solution in this case, isnāt it.
dbrunt:
!important
oh my god⦠iāve been chewing on this card.button-card-main for days now to change the size of the font⦠your post made my week. adding !important did the trick !!! thanks a million
dbrunt
(Daniel)
January 8, 2023, 4:12pm
4142
Yes, !important is well, important! Overrides everything before. Glad to be of assistance!
I am trying to figure out how to adjust the size of the light adjustment bars in the light card.
I think Iām wasting space, so I would like to have the bar to extend to the left, like I mocked in the screenshot.
(How) can I achieve that with card-mod? And, are there any good tutorials on how to get started with card-mod as a non-developer?
I figured it seems to be the div.container, but I donāt know how to write the card-mod code for that from scratch.
My card code:
square: false
columns: 1
type: grid
cards:
- type: custom:mushroom-light-card
entity: light.group_wz_stehlampe
icon: mdi:sofa
secondary_info: state
show_brightness_control: true
show_color_control: true
icon_type: entity-picture
tap_action:
action: toggle
collapsible_controls: false
primary_info: name
show_color_temp_control: true
layout: horizontal
entity: light.sessel
icon: mdi:sofa-single
use_light_color: false
show_color_temp_control: false
fill_container: true
primary_info: name
tap_action:
action: toggle
hold_action:
action: more-info
double_tap_action:
action: none
layout: horizontal
entity: light.esstisch
tap_action:
action: toggle
primary_info: name
layout: horizontal
entity: light.wohnzimmer_kommode
icon: mdi:buffet
primary_info: name
layout: horizontal
entity: light.group_tv_board
icon: mdi:television
layout: horizontal
- type: custom:mushroom-entity-card
entity: switch.steckdose_tv_x_box
name: TV & X-Box
icon: mdi:power
icon_color: green
tap_action:
action: toggle
primary_info: name
layout: horizontal
Thanks for any help!
e-raser
January 8, 2023, 9:57pm
4144
Please note this (styling the icon ) is not working anymore since HA Core 2022.12:
Because of:
No one found a solution for this yet. If you do, would you mind sharing it here and there?
opened 03:10PM - 09 Dec 22 UTC
closed 09:12PM - 11 Feb 24 UTC
As title, the template-entity-row can not be set to inherit the new color scheme⦠s, see below for an example using the new binary-color which colors blue when on https://github.com/home-assistant/frontend/blob/3c8c1260b172cb2ef01328070e1c900b2cd3d4dc/src/resources/ha-style.ts#L145
in this case the top entity (unmodded, only needs `state_color: true`)
the bottom speaks for itself, the active is also set, but it takes
`paper-item-icon-active-color: gold` from the theme I set before the new color schemes were introduced.
- type: entities
state_color: true
entities:
- binary_sensor.ha_dev_update_available
- type: custom:template-entity-row
entity: binary_sensor.ha_dev_update_available
{% if states[config.entity] is not none %}
{{state_attr(config.entity,'friendly_name').split(': Update Available')[0]}}
{% else %} Initializing
{% endif %}
state: >
{{iif(states(config.entity) == 'on','Update available','Up to date')}}
{% else %} Waiting for state
{% endif %}
secondary: >
{% set id = states[config.entity].object_id.split('_update_available')[0] %}
{% if states['sensor.' + id + '_newest_version'] is not none %}
New: {{states('sensor.' + id + '_newest_version')}} -
{% endif %}Current:
{{states('sensor.' + id + '_version')}}
{% endif %}
active: >
{{is_state(config.entity,'on')}}
<img width="522" alt="SchermĀafbeelding 2022-12-09 om 16 09 51" src="https://user-images.githubusercontent.com/33354141/206732674-f086c20f-91f7-45aa-8e8d-c6efabf1f881.png">
taking out paper color from the theme, leaves us with:
<img width="508" alt="SchermĀafbeelding 2022-12-09 om 16 14 27" src="https://user-images.githubusercontent.com/33354141/206733695-18c45d21-1faf-43a8-a598-c884174d7e47.png">
even though the more info is correctly showing the blue:
<img width="560" alt="SchermĀafbeelding 2022-12-09 om 16 15 18" src="https://user-images.githubusercontent.com/33354141/206733789-7079ab6c-748f-415f-89eb-600acf704544.png">
to be 100% certain it isnt an issue with the config.entity var, I also tried
active: >
{{is_state('binary_sensor.ha_dev_update_available','on')}}
lastly, when taking out the full t-e-r config, and only leaving the auto-entities section
card:
type: entities
title: Binaries update available
card_mod:
class: class-header-margin
state_color: true
show_empty: false
filter:
include:
- entity_id: binary_sensor.*_update_available
state: 'on'
# options:
# type: custom:template-entity-row
# name: >
# {% if states[config.entity] is not none %}
# {{state_attr(config.entity,'friendly_name').split(': Update Available')[0]}}
# {% else %} Initializing
# {% endif %}
# state: >
# {{iif(states(config.entity) == 'on','Update available','Up to date')}}
# {% else %} Waiting for state
# {% endif %}
# secondary: >
# {% set id = states[config.entity].object_id.split('_update_available')[0] %}
# {% if states['sensor.' + id + '_newest_version'] is not none %}
# New: {{states('sensor.' + id + '_newest_version')}} -
# {% endif %}Current:
# {{states('sensor.' + id + '_version')}}
# {% endif %}
# active: >
# {{is_state(config.entity,'on')}}
the blue is shown alright:
<img width="505" alt="SchermĀafbeelding 2022-12-09 om 16 23 31" src="https://user-images.githubusercontent.com/33354141/206735282-276ca73e-648b-46f4-bc99-e42e02781c42.png">
independent from the paper color. so it is the t-e-r preventing the inheritance of the new color scheme
btw, exchanging
# paper-item-icon-color: var(--primary-color)
state-icon-color: '#636B75'
doesnt make a difference, in this case the state-icon-color is used, and still not the supposed binary color
Yes, thank you, I know that this stopped working.
Maintaining all examples to reflect all changes due to some Devās whims is uneasy task. Since most users are quite satisfied with these changes and do nothing to stop this trend, I do not think I will continue to adapt examples to changes which tend to change every release.
e-raser
January 8, 2023, 11:14pm
4146
I totally understand your frustration. Thereāve been a lot of changes recently, especially to the UI. This basically renders many custom integrations useless (my use-case for custom:template-entity-row
is now completely blocked by the HA 2022.12 changes), not even styling them is helpful. Really a bit frustrating
Maybe adding a ātested with HA Core 20YY.MMā for the examples would be an option in future.
Iām trying to use a Google font with this card-mod but Iām failing.
My card is:
type: entity
entity: sensor.dev_display_text_sensor
card_mod:
style: |
ha-card {
height: 100px;
color: yellow;
text-align: center
font-size: 12px
font-family: 'Zen Dots' ;
background-color: blue;
border: solid 1px var(--primary-color); }
And I put this at the top of my Lovelace raw config file:
resources:
- url: https://fonts.googleapis.com/css2?family=Zen+Dots
type: css
Iām ultimately trying to get it to look like this without the "more info " icon. It also wonāt centerā¦
Iām sure itās my css but any help appreciated!
EDIT: turns out Brave browser doesnāt support external fonts but Safari does:
Hi every CSS gurus,
Hereās my problem with mushroom-title-card. Iām unable to change the font-size and text color using card_mod. Please help, I tried different combinations of style on ādiv.headerā, āh1ā, ⦠but cannot find a way to get ā.titleā working.
Card-mod-helper is giving this code after the conversion of the js path: view>hui-view>grid-layout$#root>hui-grid-card:nth-child(1)$#root>mushroom-title-card$div>h1
Hereās the CSS from Chrome:
Thanks a lot!!!
Hey Guys,
I need help with my mushroom template card. I want to animate my icon AND change the size of the card. what am I doing wrong?
Thanks for the help!
type: custom:mushroom-template-card
primary: ''
icon: |-
{% if is_state('switch.kamin','on') -%}
mdi:fireplace
{%- else -%}
mdi:fireplace-off
{%- endif %}
icon_color: |-
orange
{%- else -%}
disabled
{%- endif %}
layout: horizontal
entity: switch.kamin
card_mod:
style: |
:host {
--mush-icon-size: 40px;
mushroom-shape-icon$: |
ha-icon {
{{'--icon-animation: fire 1500ms infinite;'if is_state('switch.kamin', 'on') }}
transform-origin: 50% 85%;
@keyframes fire {
0%, 19%, 23%, 39%, 43%, 49%, 53%, 69%, 73%, 89%, 93%, 100% { clip-path: polygon(0 0, 100% 0, 100% 100%, 0 100%); }
20%, 40%, 50%, 70%, 90% { clip-path: polygon(0 0, 100% 0, 100% 100%, 65% 99%, 66% 49%, 52% 44%, 33% 48%, 33% 82%, 66% 82%, 69% 100%, 0 100%); }
I found the problem.
primary: ''
icon: |-
mdi:fireplace
{%- else -%}
mdi:fireplace-off
{%- endif %}
icon_color: |-
orange
{%- else -%}
disabled
{%- endif %}
layout: horizontal
card_mod:
style:
:host {
--mush-icon-size: 70px;
ha-icon {
@keyframes fire {
gpolzer1
(Gpolzer1)
January 11, 2023, 2:28pm
4152
hello one question please can you also make a border with switch-checked-track-color
catchdave
(CatchDave)
January 12, 2023, 5:14pm
4153
@thomasloven : Question about the right way to enforce the height of the mini-graph-card. I get a warning from card-mod: āmod-card should NEVER be used with a card that already has a ha-card element, such as mini-graph-cardā.
I tried doing it the normal style
way, but to enforce the height of mini-graph card, it seems that the CSS height attribute has to be on the mini-graph-card element, which is above the ha-card element. Would love to know the right/best way to do have a smaller graph card (in height). This is what I currently have (itās in a de-cluttering-template):
small_mini_graph:
card:
type: custom:mod-card
card_mod:
style: |
mini-graph-card { height: 128px; }
card:
type: custom:mini-graph-card
upper_bound_template: '[[upper_template]]'
entity: '[[sensor]]'
entities:
- entity: '[[sensor]]'
color: '[[color]]'
show:
icon_adaptive_color: true
height: 80
font_size: 90
style: |
.states { padding-bottom: 0; }
.header { padding-right: 8px; }
