🔹 Card-mod - Add css styles to any lovelace card
I have a couple of basic questions, couldn’t figure it out (not a frontend guy)…
  1. How do I mod a heading card (type: heading), for example changing the super-small font size or aligning to center?
  2. How to I mod a dashboard tab text (again, changing font or increasing its size, or increasing its width)?
    I did manage to make such changes in other places, simply by appending something standard as below, but it doesn’t work for me in the above cases :frowning:
card_mod:
  style: |
    ha-card  {
      text-align: center;
Im trying to target the color attribute of this subtitle text “Low Humidity” that is shown within this apexcharts-card leveraging card_mod.
I want to either change the text color to red if humidity falls below 30% or to amber if the humidity rises above 50%.
Can someone with a little more card_mod experience help with this?
type: custom:apexcharts-card
experimental:
  color_threshold: true
header:
  show: true
  show_states: true
  standard_format: true
  colorize_states: true
  title: Office Comfort
graph_span: 12h
cache: true
yaxis:
  - id: humidity
    show: false
    apex_config:
      opposite: true
  - id: temperature
    show: false
all_series_config:
  group_by:
    func: last
    duration: 1h
  show:
    header_color_threshold: true
series:
  - entity: sensor.ep1_office_temperature
    type: area
    yaxis_id: temperature
    stroke_width: 3
    opacity: 0.3
    curve: smooth
    color: "#FEB019"
  - entity: sensor.ep1_boho_suite_humidity
    yaxis_id: humidity
    type: column
    opacity: 0.3
    color_threshold:
      - value: 0
        color: "#E74C3C"
      - value: 30
        color: "#585858"
      - value: 50
        color: "#FEB019"
apex_config:
  plotOptions:
    bar:
      borderRadius: 6
      columnWidth: 90%
  tooltip:
    fillSeriesColor: false
    theme: light
    x:
      show: false
  states:
    hover:
      filter:
        type: lighten
        value: 0.7
  subtitle:
    text: Low Humidity
    align: center
    floating: true
    offsetY: -20
    style:
      fontSize: 18px
      color: yellow
  markers:
    strokeColors: "#282828"
    strokeWidth: 3
    shape: circle
  chart:
    zoom:
      type: x
      enabled: true
      autoScaleYaxis: true
    toolbar:
      show: true
      autoSelected: zoom
      tools:
        download: false
    xaxis.type: datetime
    height: 250px
  grid:
    position: back
    borderColor: "#282828"
    strokeDashArray: 0
    xaxis:
      lines:
        show: true
  legend:
    show: false
card_mod: # just an example - div target is incorrect
  style:
      .card-header {
        {% if states('sensor.ep1_office_temperature')|float >= 50.0 %}
          color: red;
        {% elif states('sensor.ep1_office_temperature')|float <= 30.0 %}
          color: amber;
        {% else %}
          color: grey;
        {% endif %}
Chrome Inspector Screenshot
I think I have two very simple questions that I haven’t been able to find answers to for a few days. How can I change the color of the icon in a picture-glance card depending on the entity’s state? If a given entity is active, it should have a different color than other icons? For example: all icons are gray but only fan and light are yellow becuse at the moment are active. Second question, can I change the contrast or color of the bar on which the icons appear at the bottom of the picture-glance card?
1st post of this thread - link at the bottom (titled “fantastic post bla bla”) - heading card
What is a “dashboard tab”?
As for styling with “ha-card” - it may only work for UI elements (cards, for example) which contain “ha-card”. Means - do not use thoughtlessly.
1st post of this thread - link at the bottom - picture glance.
Just use jinja to define a color in a template, check other examples in the thread.
Same, use that given info as a starting point.
I want the icon and text to change color to orange here when hvac_action is “heating”. Can anyone advise how to do this? Thanks very much.
Here is the current YAML:
type: heading
icon: mdi:home-floor-g
heading: Hall
heading_style: subtitle
badges:
  - type: entity
    show_state: true
    show_icon: true
    entity: climate.1_ground_landing_and_toilet_neo
    state_content:
      - current_temperature
      - hvac_action
    tap_action:
      action: more-info
Use examples for Heading card as I already explained you with more details in your initial thread.
1st post - link at the bottom - Heading
thanks. I have had a look at this - saw your post from October 2 (extract below) - and have no idea how I can use the logic from this YAML coding at all for my purpose. Sorry, I just don’t understand.
type: vertical-stack
cards:
  - type: heading
    icon: mdi:fan
    heading: some long long long long long long title
    heading_style: title
    badges:
      - type: entity
        entity: sun.sun
        icon: mdi:fan
      - type: entity
        entity: fan.kitchen
    card_mod:
      style:
        .badges hui-heading-badge:nth-child(1) hui-entity-heading-badge $: |
          ha-heading-badge {
            --icon-color: red;
          state-display {
            color: magenta;
          ha-state-icon {
            animation: rotating 2s linear infinite;
          @keyframes rotating {
            0% {transform: rotate(0);}
            100% {transform: rotate(359deg);}
        .badges hui-heading-badge:nth-child(2) hui-entity-heading-badge $: |
          ha-heading-badge {
            --icon-color: orange;
          state-display {
            color: red;
          ha-state-icon {
            100% {transform: rotate(0);}
          ha-card {
            background-color: lightgreen !important;
            border-radius: var(--ha-card-border-radius, 12px);
            border-width: var(--ha-card-border-width, 1px);
            border-style: solid;
          .title > p {
            color: red;
            white-space: break-spaces !important;
          .title ha-icon {
            --icon-primary-color: yellow;
            --mdc-icon-size: 32px;
  - type: entities
    entities:
      - entity: sun.sun
      - entity: sun.sun
Basic description: how to set a css property dynamically:
ha-card {
{% if state_attr(‘sensor.xxx’,’some_attr’) == ‘xxxx’ -%}
color: green;
{%- else -%}
color: red;
{%- endif %}
Adapt this example to your case.
@Ildar_Gabdullin Many thanks for your support !!!
Your guide to card_mod’s capabilities is amazing
thank you very much.
I tried this and it didn’t work - any suggestions?
type: heading
heading: Hall
badges:
  - type: entity
    show_state: true
    show_icon: true
    state_content:
      - hvac_action
    tap_action:
      action: more-info
card_mod:
  style:
    ha-card {
      {% if state_attr(‘climate.1_ground_landing_and_toilet_neo’,‘hvac_action’) == ‘heating’ -%}
      color: green;
      {%- else -%}
      color: red;
      {%- endif %}
I said “adapt” - which does not mean you should use it “as is”. Use a proper path for elements in your card-mod code.
Thanks. I don’t know how to adapt the language more than I have already done. Sorry, I’m just not that familiar with this all.
I see. Take your prev post with static customized (by card-mod) color; assume it looks like
xxx {
  some-icon-color-property: red;
and then use a jinja expression “{% if … -%} … {%- endif %}” from my example.
I am not giving you a ready solution, not easy from a mobile, so it is better for you to create it yourself.
Hi, could anyone help with this?
I’m having this issue with some of the bar graphs going outside the box
Basically i just need to have them fit inside the box or probably resize it to remove the empty space below
wow, thanks! I need to spend some over over this, great stuff!
I want to increase the text size of the tabs on the top of the dashboard, they are too small on the desktop (circled in red)
Here is the mod for the badge icon size in the Heading card.
Just in case someone wants to modify the icon size.
card_mod:
  style:
    .badges hui-entity-heading-badge $: |
      ha-state-icon {
        --mdc-icon-size: 18px;
Hi everyone, here is my first post:
(sections, type: heading)
I have this, which worked until 2024.10. unfortunately not since 2024.11. Do you know if something has changed since 2024.11 or what could be the reason?
card_mod:
  style:
      ha-heading-badge {
                    {% if is_state('binary_sensor.sensor1', 'on') %}
                      color: orange !important;
                    {% else %}
                      color: white !important;
                    {% endif %}
  .badges hui-heading-badge:nth-child(4) hui-entity-heading-badge $: |
                  ha-heading-badge {
                    {% if is_state('binary_sensor.kontakt_2', 'on') %}
                      --card-mod-icon: phu:double-window-open !important;
                    {% else %}
                      --card-mod-icon: phu:double-window-closed !important;
                    {% endif %}
                .badges hui-heading-badge:nth-child(5) hui-entity-heading-badge $: |
                  ha-heading-badge {
                    {% if states('sensor.kohlendioxid') | int <= 1000 %}
                      /*--card-mod-icon: mdi:check-circle !important;*/
                    {% elif states('sensor.kohlendioxid') | int > 1000 and states('sensor.kohlendioxid') | int <= 2000 %}
                      --card-mod-icon: mdi:cloud-alert !important;
                    {% else %}
                      color: red !important;
                      --card-mod-icon: mdi:alert-circle !important;
                    {% endif %}
                  ha-card.type-heading {
                    font-size: 8px !important;
                    height: 50px; !important;
                    padding: 0px; !important;
The font size adjustment works, but the icon change and the color change no longer do. As I said, only since 2024.11
