šŸ”¹ Card-mod - Add css styles to any lovelace card
Meanwhile @akomelj and @Ildar_Gabdullin found the main source for the trouble 2025.1 caused for card_mod and its customizations on hui-generic-entity-row, whihc apparently is caused by Lint fixes in Fix ALL the eslint warnings (#23165) Ā· home-assistant/frontend@7a12fd2 Ā· GitHub
this is great news, and hopefully an official update to card_mod can be seen soon. for the time being, follow @Ildar_Gabdullin s suggestion and do this
it brought back all mods I could find on entities, and then someā€¦
just copy the original to another www folder, and change the path in the config:
frontend:
  extra_module_url:
# https://github.com/thomasloven/lovelace-card-mod?tab=readme-ov-file#performance-improvements
    - /local/resources/card-mod/card-mod.js
#     - /hacsfiles/lovelace-card-mod/card-mod.js
thanks for the temporary fix!!
crossposting from the 2025.1 release thread
All credits to @akomelj in fact! He has found a particular issue.
Could be not the only one, I am still checking other changes.
Update: went through that commit, seems that renderEntity -> _renderEntity was the only reason. This change affected Entities card, Picture Glance, Glance. All of them tested with patched card-mod, seem to be OK.
@Ildar_Gabdullin @akomelj Great job, guys! Thank you so much!
I really feel myself awkward since it was Andrej who found the issueā€¦
Meanwhile I am asking all css-gurus to find a way to address a ha-entity-marker by itā€™s associated ā€œentity_idā€ if it is available as a property.
Described here.
Of course this method discussed earlier between @elchininet & @Mariusthvdb still can be used:
        card_mod:
          style:
            ha-map $: |
              {% for entity in config.entities %}
                {% if not is_state(entity, 'home') %}
                  div:has(> ha-entity-marker):nth-of-type({{loop.index}}) {
                    filter: grayscale();
                {% endif %}
              {% endfor %}
Thanks, do you know of a way to deal with the gap being present in a conditionally hidden card? I have two hidden on the bottom of a dashboard and it is creating a situation where a scroll bar is bein needlessly added because 2 row-gaps worth of invisible space is being added to the bottom.
Appreciate it.
Sorry, cannot help now, try using Code Inspector & provided examples for the vertical/horizontal stack cards (as usual: try ā†’ fail ā†’ repeat ā†’ succeed)
Thanks for the reply!
Indeed, Iā€™ve managed to make your example with a rotating icon on a mini graph work well here, and I think Iā€™ve understood what was wrong in my initial approach - basically:
  1. I was starting with ā€œmini-graph-card$ā€ instead of within the ā€œha-cardā€;
  2. I need to target the ha-svg-icon level for an animation to apply
  3. I cannot observe some effects on intermediary levels (itā€™s either the whole header or the icon that is several levels below in the DOM)
    Thank you again for these very useful examples.
Nonetheless, getting back to my real problem with a slightly more difficult structure, even after several more hours spent on this, Iā€™m still bumping into an issue that might be due to my lack of correct reading of the DOM.
To contextualize a bit, I have a mini room card and I want to show the state of some sensors on it, through some mushroom-chips. Iā€™d want to be able to apply some of the neat animations shown in this thread on the icons that are within these chips.
My YAML structure is as follows - there are some conditionals Iā€™ve removed to simplify the code (so ignore the fact the icon is static here) and I donā€™t show how the positioning of s1 is handled:
icon: mdi:desk
entity: sensor.temphumsensoroffice_temperature
custom_fields:
  s1:
    card:
      type: custom:mushroom-chips-card
      chips:
        - type: template
          entity: "binary_sensor.occupancysensoroffice_occupancy"
          icon: mdi:motion-sensor
          icon_color:  green
          tap_action:
            action: more-info
      card_mod:
        style: |
          ha-card .chip-container mushroom-template-chip:
              mushroom-chip ha-state-icon:
                  ha-icon:
                      ha-svg-icon {
                        background: red !important;
                        animation: rotation 2s linear infinite;
                      @keyframes rotation {
                        0%   { transform: rotate(0deg); }
                        100% { transform: rotate(360deg); }
For me, this should correspond to the DOM Iā€™m seeing below (and you can see the whole path at the bottom of the screenshot):
However, I do manage to make the whole chip rotate though, if I use:
card_mod:
  style: |
    ha-card .chip-container mushroom-template-chip {
You may say that for this particular example, the outcome is visually the same. But the problem is that eventually, Iā€™ll want to use other animations than rotation, and for instance when clipping with a path, it does matter whether itā€™s the whole chip or just the icon inside that is targeted. So Iā€™m working on rotation merely as an example I want to extend to other animations and it is therefore important to me to target the icon itself.
Iā€™d truly welcome an expert eye on this to point me out the probably obvious mistake I might be doing.
Sorry, can say nothing about mushrooms, not using them.
you can customize the styles for individual chipsā€¦
chips:
  - type: template
    card_mod:
      style: |
        ha-card {
    entity: binary_sensor.movement_backyard
    icon_color: green
    tap_action:
      action: more-info
  - type: template
    icon_color: green
    tap_action:
      action: more-info
Style each individual state-display of the new ā€œHeadersā€ type without targeting individual children:
card_mod:
  style:
    .badges hui-entity-heading-badge $: |
      state-display {
         color: red;
         font-size: medium;
Mushroom Chips are a different animal. Use this as an exampleā€¦
chips:
  - type: template
    entity: fan.bedroom_fan
    icon: mdi:fan
    icon_color: green
    tap_action:
      action: more-info
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
        100% { transform: rotate(-360deg); }
Refer to this thread Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 2)
Yes, if same style is needed for each child.
Good example.
Hi, what am i doing wrong, pleaes?
Cant get the icons to show or change colour based on the state of the lock
camera_view: auto
type: picture-glance
title: Front Door
entities:
  - entity: light.floodlight
    icon: mdi:light-flood-down
  - entity: light.front_spot
  - entity: light.driveway
  - entity: lock.front_door
    tap_action:
      action: call-service
      service: lock.unlock
        entity_id: lock.front_door
    style:
      --icon-color: |
          if (states['lock.front_door'].state === 'locked') {
            return 'green';
          } else {
            return 'red';
      --icon: |
            return 'mdi:lock';
          } else {
            return 'mdi:lock-off';
  - entity: camera.front_door_package_camera
    icon: mdi:package
camera_image: camera.front_door_high_resolution_channel
As a starting point:
1st post ā†’ link at the bottom titled ā€œfantasticā€ ā†’ picture-glance
Ok i have pealed this back and still cant get it to work ā€¦ any pointers please?
camera_view: auto
title: Front Door
entities:
card_mod:
  style: |
    ha-card {
      background: var(--background-card-color);
    #states div:nth-of-type(1) {
      --paper-item-icon-color: [[ if(lock.front_door == "unlocked", "red", "green")]];
How do I need to modify the card_mod style in case of using the decluttering-card?
Iā€™ve found 2 card_mod examples for the decluttering-card, both are using the following code.
card_mod:
  style: '[[STYLE]]'
This would be working fine, but the sense of using the decluttering-card will be lost, because of too many lines left in the card.
Here I found another solution for a bar-card and Iā€™ve tried to transfer this solution to my usecase.
Here is the simplified code with sensor sun.sun to make it run in any environment.
decluttering_templates:
  raumcard_overview_template_icon_links:
    default:
      - ENTITY: sun.sun
      - POSITION_LEFT: 4px
      - CHIP_ICON_SIZE: 0.6em
    card:
      type: custom:mod-card
      card:
        chips:
          - type: entity
            entity: '[[ENTITY]]'
            icon: mdi:[[ICON]]
            icon_color: '[[ICON_COLOR]]'
            content_info: none
      card_mod:
        style:
          decluttering-card $ mushroom-chips-card $: |
            ha-card {
              position: absolute;
              top: '[[POSITION_TOP]]';
              left: '[[POSITION_LEFT]]';
              z-index: 1;
              --chip-icon-size: '[[CHIP_ICON_SIZE]]';
              --chip-border-width: 0;
According to the example above, Iā€™ve inserted the line
to make the card_mod work within decluttering card.
Here the code for the card:
type: custom:decluttering-card
template: raumcard_overview_template_icon_links
variables:
  - ENTITY: sun.sun
  - ICON: sofa-outline
  - ICON_COLOR: orange
  - POSITION_TOP: 35px
  - POSITION_LEFT: 15px
Please note, that this code is simplified to just show the issue.
The hole code of the card would be more than 500 lines and could be reduced by using the decluttering-card.
What do I need to change to make the card_mod (POSITION_TOP & LEFT) working for this combination?
@Ildar_Gabdullin can you make a fixed post in the grand fantastic overview for the 2025.1 breaking of entity-rows, and how to temporarily fix it? Maybe just link to the GitHub repo post where we explain how to proceed, or to this one in this thread: šŸ”¹ Card-mod - Add css styles to any lovelace card - #7894 by Mariusthvdb
I can get it to work in standard glance. But if i transpose this to picture-glance, no avail ? :frowning:
type: glance
entities:
    state_color: false
    card_mod:
      style: |
        state-badge {
          {% if is_state(config.entity,'on') %}
            color: red;
          {% else %}
            color: yellow;
          {% endif %}
NOT working:
camera_view: auto
title: Front Door
entities:
    state_color: false
    card_mod:
      style: |
        state-badge {
            color: red;
          {% else %}
            color: yellow;
          {% endif %}
Thank you so much! Indeed, what I had completely overlooked this whole time is that mushrooms has a syntax that does not follow the same logic. So I was trying complex DOM piercing that actually led to nothing.
For anyone that would bump into this in the future, what I should have looked at much earlier was this post that describes well the combination of mushrooms with card-mod: Mushroom Cards Card Mod Styling/Config Guide
Thanks also to Ildar for the pointers, it was my bad for not talking about mushrooms at the beginning!
No, I have not installed it yet. Iā€™ll try to check what have changed there.
