What do you mean by āoutdatedā? The only outdated thing could be an absense of ācard_modā keyword in some examples.
I was trying directly Your command, but it didnāt work as well.
āāstate-lawn_mower-docked-color: cyan
Then I played with modifying it to match lawnmower name.
Then see my 1st post related to this issue - this domain seems to be not themeable.
I need help customizing the badge icon size and font size for the temperature sensor values in Badges. Additionally, Iām also trying to change the font size of the temperature control bar in the āClimateā card or the Thermostat card.
Can anyone please help shed some lights on the above? Much appreciated.
If you mean āview badges:
1st post - fantastic link - badges 2024.8
There are 2 methods available (mod-card, hacked card-mod), choose any.
Suggest to use posted examples as a starting point and TRY yourself, then post your attempts.
Thanks for your reply. I tried to change the state font size and it doesnāt change or enlarge the font size. Can you please shed some lights?
type: heading
heading: New section
heading_style: subtitle
badges:
- type: entity
entity: sensor.bedroom_rounded_temp
card_mod:
style:
ha-state-label-badge:
ha-label-badge:
.badge-container .label-badge .value {
color: red;
font-size: 88px;
I would suggest reading up on using Chromeās element inspector. There are multiple ways to attack mods.
Ildarās guide is extremely robust and offers an enormous amount of information. Itās impossible to cover all aspects, so educating yourself is required.
type: heading
badges:
- type: entity
card_mod:
style: |
ha-card {
--secondary-text-color: blue !important;
--ha-heading-card-subtitle-font-size: 40px !important;
--ha-heading-card-subtitle-line-height: 41px !important;
Thanks for the reply. What I wanted to change is the bedroomās sensor temperature value reading, not the āNew Sectionā heading. Take a look at my another attempt. The 74.4F didnāt change to red or font size didnāt change. Not sure which part of my code is experiencing problem. TIA.
For example:
type: heading
heading_style: title
badges:
- type: entity
show_state: true
show_icon: true
entity: sensor.outdoor_ambient_rounded_temp
card_mod:
style:
ha-label-badge:
color: red;
font-size: 48px;
Never mind. I found this code is working:
type or paste code heretype: heading
badges:
- type: entity
show_state: true
show_icon: true
card_mod:
style:
.badges hui-entity-heading-badge $: |
ha-state-icon {
--mdc-icon-size: 20px;
state-display {
font-size: 150%;
.type-heading .container .content {
font-size: 100%;
type: heading
badges:
- type: entity
entity: sensor.living_room_temperature
card_mod:
style:
hui-entity-heading-badge$:
ha-heading-badge$: |
.heading-badge {
--icon-color: yellow !important;
--mdc-icon-size: 50px !important;
font-size: 50px !important;
color: red !important;
Oh. Yours is even better! Itās exactly what I want to achieve. Thanks again for your help!!!
Correct your terminology: these are not ābadgesā, these is a Heading card.
Got it! Didnāt know I had that mixed up. Thanks.
Now, I am looking into āBadgesā (I hope it got it correctly this time). I was referring to š¹ Card-mod - Add css styles to any lovelace card - #1310 by Ildar_Gabdullin. But none of the card_mod code works. Do I need to put some patch before using the card_mod code?
Depends on what badges you need.
pre 2024.8: that thread + a sibling thread about āhow to style old badges after HA 2024.8ā.
after 2024.8: already gave you a path to 2 possible methods
Thanks for the suggestion. I attempted one of the workarounds, which involves replacing the strings in card-mod.js. Finally, it worked with all your code examples. However, it completely changed the style and appearance of the current native HAās badge style and design, which I prefer. I was hoping to simply increase the font size while preserving the native badge design. Is it possible to use your workaround but not alter the native badge style and design?
This āreplacing stringā method is purposed to make card-mod compatible with a specially added ātypeā line to āturnā new badges into old badges. This replacing does NOT affect new badges.
How can I fix that. Im decrease the hight but text is not aligned in relation to the box. I tried padding and margin, but the whole thing moves. THank you!
Set zero paddings for ā.card-contentā.
Thank you! I tried .content and was not working, .card-content did the trick. Appreciate!
