πŸ”Ή Card-mod - Add css styles to any lovelace card
--ha-card-background is already set, so just use background: #fff0 !important;
Hello
Would you like to help me with traversing layout card?
I know already I had to use card-mod. I can apply style to its ha-card. But I failed to go deeper. I need to style those div.column elements. In fact I failed to even reach
BTW the motivation is to remove overflow settings from culumns, because something goes wrong on small displays causing right shadows to be clipped.
You’re doing pretty good so far! Change div div.column to div.column or div.column div.
sorry if i bother , 1 more thing
i have
if i adjust from the dev paddings it works , if i do via yaml , no , can you just tell me what is wrong ?
                      - card: 'media-control'
                        wider: true
                        widerSize: 2
                        noPadding: true
                        cardOptions:
                            entity: media_player.tv_living
                            style: |
                              ha-card {
                                  padding: 2px !important;
                                  display: flex !important;
                                  flex-direction: column !important;
                                  background: transparent !important;
                                  box-shadow: none !important;
                                  border-radius:0 !important;
                              .player {
                                  position: relative;
                                  padding: 5px;
                                  height: 100%;
                                  box-sizing: border-box;
                                  display: flex;
                                  flex-direction: column;
                                  justify-content: space-between;
                                  color: var(--text-primary-color);
                                  transition-property: color, padding;
                                  transition-duration: 0.4s;
Unfortunately it doesn’t work. I ave feeling I checked all possible combinations :wink:
But what worrying me is I cannot reach layout-card element either.
this doesn’t work, but I think it should.
style:
  ha-card:
    layout-card: '{background-color: red !important}'
While testing various options I succeed with this syntax:
style: |
  ha-card layout-card {background-color: red !important}
So… what am I I doing wrong?
try :
                            style: |
                              ha-card {
                                  background: red  !important;
This works (obviously)
What I’m trying is, to traverse to layout-card and deeper.
Because I’m failing to change layout-card in the way I showed above, I cannot go into shadow roots (see my posts above)
Try this:
style:
  ha-card$:
    layout-card {
      background-color: red !important;
Try changing padding: 5px; to padding: 5px !important;
I start using this card mode to fix an bug with the camera.
All I want is to change the Image in a iframe to 100%.
Default there is no width and height defined.
Can someone help me to find a solution?
For security reasons, you can’t go into an iframe. What’s the URL you’re embedding from?
well … thanks so much… i would love an explaination to how understand why , but anyway…it worked…
URL reference to the video of the doorbird cam.
But to add it as a camera is no option, it has too much delay.
What’s the URL that starts with http://192.168., that’s inside of the img tag?
That is the URL
src=β€œhttp://192.168.1.12/bha-api/video.cgi?http-user=###&http-password=###”>
Add a picture card, and set the source to that, instead of using the iframe card. Does it work at all?
Lets see if anyone can help me;
I have a simple Graph card that I managed to edit and mod, to get the icon to change colors:
type: horizontal-stack
cards:
  - type: 'custom:mini-graph-card'
    style:
      .icon ha-icon:
          ha-svg-icon {
          {% if states('sensor.zzzzzzz_remaining_range_total')|float >= 120%}
            color: white !important;
          {% elif states('sensor.zzzzzz_remaining_range_total')|float >= 50%}
            color: orange !important;
          {% else %}
          {% endif %}
    entities:
      - entity: sensor.zzzzzzz_remaining_range_total
    show:
      legend: false
    color_thresholds:
      - value: 250
        color: '#3498DB'
      - value: 150
        color: orange
      - value: 100
        color: red
    line_width: 6
    font_size: 75
    animate: true
    lower_bound: 0
    upper_bound: 750
    hours_to_show: 360
    points_per_hour: 0.1
    icon: 'mdi:gas-station'
    style:
      .icon ha-icon:
          ha-svg-icon {
          {% if states('sensor.yyyyyy_remaining_range_total')|float >=
          120%}
          {% elif states('sensor.yyyyy_remaining_range_total')|float >=
          50%}
          {% else %}
          {% endif %}
    entities:
      - entity: sensor.yyyyy_remaining_range_total
    show:
      legend: false
    color_thresholds:
      - value: 250
        color: '#3498DB'
      - value: 150
        color: orange
      - value: 100
        color: red
    line_width: 6
    font_size: 75
    animate: true
    lower_bound: 0
    upper_bound: 750
    hours_to_show: 360
    style:
      .icon ha-icon:
          ha-svg-icon {
          {% if states('sensor.xxxx_remaining_range_total')|float >= 120%}
          {% elif states('sensor.xxxx_remaining_range_total')|float >= 50%}
          {% else %}
          {% endif %}
    entities:
      - entity: sensor.xxxx_remaining_range_total
    show:
      legend: false
    color_thresholds:
      - value: 250
        color: '#3498DB'
      - value: 150
        color: orange
      - value: 100
        color: red
    line_width: 6
    font_size: 75
    animate: true
    lower_bound: 0
    upper_bound: 750
    hours_to_show: 360
Up to here, all good.
I am designing a more detailed card for each car, and I would like to have the same behavior on the Fuel Icon, (and also the lock icon coloring),
Could this be easier to be done via templating?
via card styling I have the following with ZERO success.
type: 'custom:stack-in-card'
mode: vertical
keep:
  box_shadow: false
  background: false
cards:
  - type: entities
    entities:
      - type: 'custom:multiple-entity-row'
        style:
          .icon ha-icon:
              ha-svg-icon {
              {% if states('sensor.xxxxx_remaining_range_total')|float >= 120%}
              {% elif states('sensor.xxxxx_remaining_range_total')|float >= 50%}
              {% else %}
              {% endif %}
        entities:
          - entity: sensor.xxxxx_remaining_fuel
          - entity: sensor.xxxxx_remaining_range_total
        secondary_info: last-updated
        show_state: false
        state_color: true
        state_header: true
      - type: divider
CSS targeting the ICON itself,
Have you tried to find a solution here for β€œmultiple-entity-row” ?
It was described here a few days ago.
BEST POST EVER! should be in the GitHub sample area. THANKS
One more post for beginners - styling Glance card.
Colored text:
ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅
code
type: glance
title: Colored text
style: |
  ha-card {
    color: red;
entities:
  - entity: sensor.cleargrass_1_co2
Colored title:
code
type: glance
title: Colored title
card_mod:
  style:
      .card-header {
entities:
stopped working in the end of 2022
Before this change:
type: glance
style: |
  ha-card .card-header {
    color: red;
entities:
Colored name & value (all entities):
code
type: glance
title: Colored name & value
style: |
  ha-card .entities {
    color: red;
entities:
Colored name & value (1st entity):
code
type: glance
title: Colored name & value (1st entity)
entities:
    style: |
      :host {
        color: red;
Colored name (all entities):
code
type: glance
title: Colored name
style:
  .entities .entity:
      .name {
        color: red;
entities:
Colored name (1st entity):
code
type: glance
title: Colored name (1st entity)
entities:
    style: |
      :host .name {
        color: red;
Colored state (all entities):
code
type: glance
title: Colored states
style:
  .entities .entity:
      div:not(.name) {
        color: red;
entities:
Colored state (1st entity):
code
type: glance
title: Colored state (1st entity)
entities:
    style: |
      div:not(.name) {
        color: red;
Colored icons:
By default for entities like "sensor" (same for "device_tracker", "person", "zone", …) an icon’s color does not depend on the entity’s state.
There are two methods for changing a color:
  • using a "--paper-item-icon-color" variable;
  • using a "color" CSS property.
Method #1 (using a "--paper-item-icon-color" variable):
For all entities:
code
type: glance
title: Colored icons
style: |
  ha-card {
    --paper-item-icon-color: red;
entities:
For some entity:
code
type: glance
title: Colored icon (1st entity)
entities:
    style: |
      :host {
Method #2 (using a "color" CSS property):
code: For all entities
type: glance
card_mod:
  style:
    .entity:
        state-badge {
          color: red;
entities:
code: For some entity
type: glance
entities:
    card_mod:
      style: |
        state-badge {
          color: red;
By default for entities like "binary_sensor", "sun.sun", "switch", "input_boolean" - an icon’s color DOES depend on the entity’s state - if the property "state_color: true" is set for the card. If it is set to "false", then the color DOES NOT depend on the state - use same Methods #1, #2 as for the "sensor" (described above).
  • using "--paper-item-icon-color" and "--paper-item-icon-active-color" variables;
Method #1 (using "--paper-item-icon-color" and "--paper-item-icon-active-color" variables):
code
type: glance
state_color: true
style: |
  ha-card {
    --paper-item-icon-active-color: cyan;
entities:
  - entity: binary_sensor.service_on_value
  - entity: binary_sensor.iiyama_2_ping_availability_status
Method #2 (using a "color" CSS property) - identical to the Method #2 described for the "sensor" entity above.
How to implement conditional color dependently on state for "binary_sensor" using Method #2 (may be used for "sun.sun" & others too with some corrections):
code
type: glance
entities:
    card_mod:
      style: |
        state-badge {
          {% if is_state(config.entity,'on') %}
            color: red;
          {% else %}
            color: blue;
          {% endif %}
Wrapped text (all entities):
code
type: glance
title: Wrapped text
style:
  .entities .entity:
      .name {
        text-overflow: unset !important;
        white-space: unset !important;
entities:
    name: Wrapped wrapped wrapped wrapped wrapped wrapped
Wrapped text (1st entity):
code
type: glance
title: Wrapped text (1st entity)
entities:
    style: |
      .name {
    name: Not wrapped Not wrapped Not wrapped Not wrapped
+some alignment:
code
type: glance
title: Wrapped text (1st entity) + aligned
card_mod:
  style: |
    .entities {
      align-items: end !important;
entities:
    style: |
      .name {
Wrapped values (all entities):
code
type: glance
title: Wrapped values
style:
  .entities .entity:
      div:not(.name) {
entities:
  - entity: input_text.test_text
Wrapped value (1st entity):
code
type: glance
title: Wrapped value (1st entity)
entities:
    style: |
      div:not(.name) {
+some alignment:
code
type: glance
title: Wrapped value (1st entity) + aligned
card_mod:
  style: |
    .entities {
      align-items: start !important;
entities:
    style: |
      div:not(.name) {
Resizing icons:
For the whole card:
code
type: glance
entities:
style: |
  ha-card {
    --mdc-icon-size: 60px;
For some row:
code
type: glance
entities:
    style: |
      :host {
Changing font-size:
code
type: vertical-stack
title: font-size
cards:
  - type: glance
    style:
      .entities .entity:
          .name {
            font-size: 20px;
    entities:
  - type: glance
    entities:
        style: |
          :host .name {
            font-size: 20px;
  - type: glance
    style:
      .entities .entity:
          div:not(.name) {
            font-size: 20px;
    entities:
  - type: glance
    entities:
        style: |
          div:not(.name) {
            font-size: 20px;
Make a square entity_picture:
code
type: glance
entities:
  - entity: person.ildar
    card_mod:
      style: |
        state-badge {
          border-radius: 10%;
Math operations, replacing a value:
post
More examples are described here.
