maxym
December 29, 2020, 9:34am
1239
Unfortunately, not even after fixing syntax error you made
But at the end I’ve made it after lot of trial&errors
style:
layout-card: '{background-color: red !important}'
Still however don’t understand why it doesn’t work this way:
style:
ha-card:
IMO it should. since layout-card is child of ha-card (and ha-card alone is accessible), see the DOM tree:
Anyway, this little success led me to final solution:
style:
layout-card:
div#columns {margin: 15px !important}
div.column {overflow-x: visible !important}
KTibow
(Kendell R)
December 29, 2020, 5:25pm
1240
Because card-mod was designed with a different syntax.
Macke
January 1, 2021, 11:19am
1241
How can I change the font size of the “secondary info”? Tried for hours now without any luck.
- cards:
- card:
type: entities
style: |
ha-card {
border-radius: 0px;
border: solid 0px rgba(255, 255, 255, 0.15);
font-size: 20px;
font-weight: bold;
background-color: rgba(207, 212, 199, 0.1);
filter:
include:
- entity_id: '*rorelselarm*'
options:
secondary_info: last-changed
- entity_id: '*motion*'
options:
sort:
count: 10
method: last_changed
type: 'custom:auto-entities'
type: horizontal-stack
Try searching here.
How to change a font-size for Entities card:
[image]
type: entities
title: Size for title
card_mod:
style: |
ha-card .card-header {
font-size: 35px;
color: red;
entities:
- entity: sun.sun
- entity: sun.sun
name: Size for whole row
card_mod:
style: |
:host {
font-size: 25px;
color: red;
- entity: sun.sun
name: Size for …
To change a style for all secondary_info’s - use this:
Styling Entities card.
(including some special row elements - button, section, divider)
NOTE:
Do not forget to add a "card_mod:" keyword before "style:" (new in card-mod 3).
Colored background & rounded corners - can be easily achieved by using "--ha-card-background" & "--ha-card-border-radius" variables:
[image]
type: entities
title: Title
entities:
- entity: sun.sun
style: |
ha-card {
--ha-card-background: orange;
--ha-card-border-radius: 14px;
Using background image:
T…
Macke
January 1, 2021, 11:54am
1243
Many many thanx…worked perfectly!!
olum
January 3, 2021, 1:26pm
1244
Thank you for that hint. Sometimes it is too easy.
alnavasa
(A)
January 4, 2021, 1:15pm
1245
Great post again, what about changing the padding/margin above and below an icon on this glances card?
This is a margin.
Removing margin:
cards:
- type: glance
title: Margin
entities:
- entity: sun.sun
- entity: sun.sun
- type: glance
title: No margin
style:
.entities .entity:
state-badge {
margin-top: 0px;
margin-bottom: 0px;
entities:
- entity: sun.sun
- entity: sun.sun
alnavasa
(A)
January 4, 2021, 10:01pm
1247
I really need to learn this things! THANKS AGAIN!
fra
(francesco)
January 4, 2021, 11:14pm
1248
Hi at all!
Could i use only Card-mod to hide the three vertical dot on the upper right corner on my HA dashboard??
(i wanna hide the vertical menu with customize and help links on the right)
thanks a lot.
KTibow
(Kendell R)
January 5, 2021, 2:12am
1249
Sure. Do you have themes set up?
fra
(francesco)
January 5, 2021, 2:58am
1250
Yes, i’ve a dark theme installed.
frontend:
themes: !include_dir_merge_named themes/
Please, could you point me to the right direction to solve??
Thanks a lot.
KTibow
(Kendell R)
January 5, 2021, 3:02pm
1251
Post your dark theme’s YAML file, I’ll edit it, paste it back in, restart HA, and it should be gone.
fra
(francesco)
January 5, 2021, 4:29pm
1252
This is my theme.
Thanks a lot.
noctis:
# Fonts
primary-font-family: 'Raleway,sans-serif'
paper-font-common-base_-_font-family: "var(--primary-font-family)"
paper-font-common-code_-_font-family: "var(--primary-font-family)"
paper-font-body1_-_font-family: "var(--primary-font-family)"
paper-font-subhead_-_font-family: "var(--primary-font-family)"
paper-font-headline_-_font-family: "var(--primary-font-family)"
paper-font-caption_-_font-family: "var(--primary-font-family)"
paper-font-title_-_font-family: "var(--primary-font-family)"
ha-card-header-font-family: "var(--primary-font-family)"
# Text
text-color: '#ffffff'
primary-text-color: 'var(--text-color)'
text-primary-color: 'var(--text-color)'
secondary-text-color: "#BAC0C6"
text-medium-light-color: '#A0A2A8'
text-medium-color: '#80828A'
disabled-text-color: '#626569'
primary-color: 'var(--accent-color)'
# Main Colors
app-header-background-color: '#242e42'
accent-color: '#1A89F5'
accent-medium-color: 'var(--accent-color)'
# Background
primary-background-color: 'var(--background-color)'
background-color-2: '#20293c'
secondary-background-color: 'none'
markdown-code-background-color: 'var(--background-color)'
# Card
card-background-color: 'var(--ha-card-background)'
ha-card-background: 'rgba(43,55,78,1)' #'linear-gradient(145deg, #273246, #2e3b53)'
ha-card-box-shadow: "3px 3px 13px -6px rgba(17,35,52,1)"
ha-card-border-radius: "5px"
border-color: 'none'
# Icons
paper-item-icon-color: '#EBEBEB'
paper-item-icon-active-color: 'var(--accent-color)'
# Sidebar
sidebar-background-color: 'var(--background-color)'
sidebar-icon-color: '#98a7b9'
sidebar-selected-icon-color: 'var(--accent-color)'
sidebar-selected-text-color: 'var(--text-color)'
paper-listbox-background-color: 'var(--sidebar-background-color)'
divider-color: 'var(--background-color)'
light-primary-color: 'var(--ha-card-background)'
# Sliders
paper-slider-knob-color: 'var(--accent-color)'
paper-slider-pin-color: 'var(--background-color-2)'
paper-slider-active-color: 'var(--accent-color)'
paper-slider-container-color: 'var(--background-color-2)'
# Toggle:
paper-toggle-button-checked-bar-color: 'var(--accent-color)'
mdc-theme-primary: 'var(--accent-color)'
# Switch
switch-unchecked-color: '#70889e'
switch-checked-button-color: 'var(--accent-color)'
switch-unchecked-track-color: 'var(--background-color-2)'
switch-checked-track-color: 'var(--background-color-2)'
# Radio Button
paper-radio-button-checked-color: 'var(--accent-color)'
# Popups
more-info-header-background: 'var(--secondary-background-color)'
paper-dialog-background-color: 'var(--background-color)' #'rgba(47,59,82,0.4)'
# Tables
table-row-background-color: 'var(--background-color)'
table-row-alternative-background-color: 'var(--ha-card-background)'
# Badges
label-badge-background-color: 'var(--background-color)'
label-badge-text-color: 'var(--text-primary-color)'
label-badge-red: 'rgba(73,85,108,1)'
label-badge-blue: 'rgba(26,137,245,1)'
label-badge-green: 'rgba(0,202,139,1)'
label-badge-yellow: 'rgba(222,176,107,1)'
paper-input-container-focus-color: 'var(--accent-color)'
# Custom Header
ch-background: 'var(--background-color)'
ch-active-tab-color: 'var(--accent-color)'
ch-notification-dot-color: 'var(--accent-color)'
ch-all-tabs-color: 'var(--sidebar-icon-color)'
ch-tab-indicator-color: 'var(--accent-color)'
# Mini Mediaplayer
mini-media-player-base-color: 'var(--text-color)'
mini-media-player-accent-color: 'var(--accent-color)'
alnavasa
(A)
January 5, 2021, 8:39pm
1253
Is it possible to remove an element from part of an inserted website
EG:
Top bar:
Bottom bar:
not that I don’t want to give them credit, is just that I am planing to make it even smaller, and the bar takes a lot of space.
KTibow
(Kendell R)
January 5, 2021, 8:45pm
1254
No website, Home Assistant, or otherwise, can go inside an iframe.
KTibow
(Kendell R)
January 5, 2021, 8:52pm
1255
noctis:
# Fonts
# Text
# Main Colors
# Background
# Card
# Icons
# Sidebar
# Sliders
# Toggle:
# Switch
# Radio Button
# Popups
# Tables
# Badges
# Custom Header
# Mini Mediaplayer
# Card-mod Theming
card-mod-theme: "noctis"
card-mod-root: |
mwc-icon-button[slot="trigger"] > ha-svg-icon {
display: none;
fra
(francesco)
January 5, 2021, 9:24pm
1256
Thanks a lot man!
It works like a charm !!!
KoenChiau
(Koen Chiau)
January 6, 2021, 2:00pm
1257
Dear friends,
I would appreciate any help with styling a glance card (within an auto-entities card).
I need to get rid of the margin of the “state-badge” within the “entity” class of a glance card.
Please see the screenshot for a more detailed indication.
My CSS navigation knowledge must be insufficient, as my attempts so far have been not successful. Please see the screenshot for my attempts.
Is anyone willing to help me out ?
Thank you in advance !!
Screenshot 2021-01-06 at 14.47.54|690x445
KTibow
(Kendell R)
January 6, 2021, 2:46pm
1258
Please paste code; I won’t rewrite all of that from your screenshot.
