šŸ”¹ Card-mod - Super-charge your themes!
Thanks! Not sure what you mean though - hereā€™s my theme yaml, I can edit the colour of the icons with that path (ha-svg-icon) but not add animation
Christmas:
  modes:
    dark:
      sidebar-background-color: '#090e3b'
      scrollbar-thumb-color: 'var(primary-color)'
      app-header-background-color: '#090e3b'
      app-header-edit-background-color: 'var(--app-header-background-color)'
      app-header-text-color: '#99eeff'
      card-background-color: '#090e3b'
      primary-text-color: '#99eeff'
      accent-color: '#e4002b'
    light:
      sidebar-background-color: '#99eeff'
      app-header-background-color: '#99eeff'
      card-background-color: '#99eeff'
      text-primary-color: '#000000'
  ha-card-border-color: 'var(--card-background-color)'
  state-switch-active-color: '#008000'
  state-binary_sensor-active-color: '#008000'
  lovelace-background: center / cover no-repeat fixed url('/local/media/images/christmas-background.jpg')
  ha-card-header-font-family: "Dancing Script"
  card-mod-theme: Christmas
  card-mod-sidebar-yaml: |
      .menu .title {
        font-family: Dancing Script;
      a[data-panel='panel'] paper-icon-item .item-text {
        font-size: 26px;
      .spacer {
        background: center / cover url("/local/media/images/christmasdecor.png");
      a[data-panel='dashboard-home'] paper-icon-item ha-icon {
        color: lime !important;
      a[data-panel='dashboard-home'] paper-icon-item .item-text {
        color: lime;
      a[data-panel='status-page'] paper-icon-item ha-icon {
        color: red !important;
      a[data-panel='status-page'] paper-icon-item .item-text {
        color: red;
      a[data-panel='todo'] paper-icon-item ha-svg-icon {
      a[data-panel='todo'] paper-icon-item .item-text {
        color: red;
      a[data-panel='calendar'] paper-icon-item ha-svg-icon {
      a[data-panel='calendar'] paper-icon-item .item-text {
        color: lime;
      a[data-panel='map'] paper-icon-item ha-svg-icon {
      a[data-panel='map'] paper-icon-item .item-text {
        color: red;
      a[data-panel='history'] paper-icon-item ha-svg-icon {
      a[data-panel='history'] paper-icon-item .item-text {
        color: lime;
      a[data-panel='core_configurator'] paper-icon-item ha-icon {
      a[data-panel='core_configurator'] paper-icon-item .item-text {
        color: red;
      a[data-panel='hacs'] paper-icon-item ha-icon {
      a[data-panel='hacs'] paper-icon-item .item-text {
        color: lime;
      a[data-panel='media-browser'] paper-icon-item ha-svg-icon {
      a[data-panel='media-browser'] paper-icon-item .item-text {
        color: red;
      a[data-panel='developer-tools'] paper-icon-item ha-svg-icon {
      a[data-panel='developer-tools'] paper-icon-item .item-text {
        color: lime;
      a[data-panel='config'] paper-icon-item ha-svg-icon {
      a[data-panel='config'] paper-icon-item .item-text {
        color: red;
      .notifications-container paper-icon-item ha-svg-icon {
        color: lime;
      .notifications-container paper-icon-item .item-text {
        color: lime;
        color: red;
      {% if now().strftime('%d') == '25' %}
        paper-listbox {
          background: url("/local/media/images/fallingsnow.gif") !important;
        @keyframes rgb1 {
          0%, 49% {
            color: lime;
          50%, 100% {
            color: red;
        @keyframes rgb2 {
          0%, 49% {
            color: red;
          50%, 100% {
            color: lime;
          animation: rgb2 5s linear infinite;
          animation: rgb1 5s linear infinite;
      {% endif %}
  card-mod-root: |
    .main-title {
The link to a possible solution was already provided:
card mod thread ā†’ 1st post ā†’ link at the bottom ā†’ themes ā†’ sidebar
A ā€œcopy/paste someoneā€™s codeā€ way does not work here, you need to learn how card-mod works.
Have you defined your @keyframes rgb1 { and @keyframes rgb2 { ?
How to change the fill color of this button row in an entities card? I can do it through the browser inspector but canā€™t figure out how to translate that into the card-mod style.
- type: entities
  entities:
    - entity: input_select.car_service_reset_drop_down_mirage
    - type: conditional
      conditions:
          state_not: Select
      row:
        type: buttons
        entities:
          - entity: input_button.car_service_reset_mirage
            card_mod:
              style: |-
                button {
                  --ha-assist-chip-filled-container-color: teal;
Wrong thread, not about themes.
Go to card mod thread - 1st post, this was explained already many times:
  • how to style a button-row inside Entities card
  • how to style a conditional row inside Entities card
If you canā€™t provide any input just donā€™t bother. And like I said the code is fine. Maybe you should learn how card-mod works.
Yeah itā€™s in the code just before the end, but I omitted the parts with the icon referring to the key frames as it didnā€™t work. Dw if itā€™s too difficult! Thanks!
The ā€œinputā€ was already provided. If you unable to see/understand it & yet react in a such rude way - surely I will not bother)))
Hello everyone, being a newbie in the world of theme creation I am doing a little research, the cards on my Dashboard are modified with mushroom and card-mod everything is good to adjust to the pixel, but I am facing a problem , on the tree of theme codes for my map configuration which are 99% identical I would like to change the map configuration to theme to lighten the Dashboard code, I thank you in advance if you can help me gentlemen the coders even just a bit that would help me a lot Iā€™ve been looking for several days, Iā€™ve been testing things but without success. Iā€™ll give you one of my cards as an example
type: horizontal-stack
cards:
  - type: custom:vertical-stack-in-card
    cards:
        entity: light.le_salon
        icon: mdi:sofa
        icon_color: |-
          {% if is_state('light.le_salon', 'on') %}
            #FFAE0080
          {% else %}
            #0000
          {% endif %}
        primary: Salon
        secondary: >-
          {{ states('sensor.thermometre_salon_temperature') }}Ā°C/{{
          states('sensor.thermometre_salon_humidity') }}%
        layout: horizontal
        tap_action:
          action: more-info
        double_tap_action:
          action: none
        hold_action:
          action: none
        card_mod:
          style:
            mushroom-state-info$: |
              .primary {
                position: relative;
                top: -50px;
                left: -155px;
                overflow: visible !important;
                white-space: normal !important;
                background-color: #00000090;
                width: 44%;
                border-radius: 5px 5px 5px 5px;
              .secondary {
                position: relative;
                top: -49px;
                left: -155px;
                width: 78%;
            mushroom-shape-icon$: |
              .shape {
                position: relative;
                left: -43px;
                top: 55px;
              :host {
                --mush-icon-size: 146px;
            style: |
              mushroom-badge-icon {
                left: 60px;
                top: 25px;
              ha-card {
                background: none;
      - type: custom:mushroom-chips-card
        chips:
          - type: conditional
            conditions:
              - condition: state
                state: 'on'
            chip:
              type: template
              tap_action:
                action: none
              icon: mdi:ceiling-light
              icon_color: |-
                {% if is_state(entity, 'on') %}
                 orange
                {% endif %}
              hold_action:
                action: none
              double_tap_action:
                action: none
          - type: conditional
            conditions:
              - condition: state
                entity: media_player.samsung_7_series_65
                state: 'on'
            chip:
              type: template
              icon: mdi:play-pause
              icon_color: |-
                {% if is_state('media_player.samsung_7_series_65', 'on') %}
                  orange
                {% endif %}
              hold_action:
                action: none
              double_tap_action:
                action: none
              tap_action:
                action: none
          - type: conditional
            conditions:
              - condition: state
                entity: alarm_control_panel.alarmo
                state: armed_away
            chip:
              type: alarm-control-panel
              tap_action:
                action: none
              content_info: none
        card_mod:
          style:
              ha-card {
                width: 66px;
                margin-left: 85%;
                top: -170px;
                background: none;
                --chip-border-width: 0;
    card_mod:
      style: |
        ha-card {
          height: 178px ;
          margin: auto;
          background-image: url(https://i.ibb.co/NjM7Dd6/salon.png);
          background-size: cover;
          background-position: center;
    cards:
        icon: mdi:silverware-variant
        icon_color: >-
          {% if is_state('light.la_salle_a_manger', 'on') or
          is_state('switch.prise_connectee_mystrom', 'on') or
          is_state('switch.prise_salle_a_manger', 'on') %}
            #FFAE0080
          {% else %}
            #0000
          {% endif %}
        primary: Salle a manger
        layout: horizontal
        tap_action:
          action: more-info
        double_tap_action:
          action: none
        hold_action:
          action: none
        badge_icon: |+
        badge_color: |+
        entity: light.la_salle_a_manger
        secondary: ''
        card_mod:
          style:
              .primary {
                position: relative;
                top: -50px;
                left: -155px;
                width: 110%;
              .secondary {
                position: relative;
                top: -49px;
                left: -155px;
              .shape {
                position: relative;
                left: -43px;
                top: 55px;
              :host {
            style: |
                left: 60px;
                top: 25px;
              ha-card {
                background: none;
        chips:
          - type: conditional
            conditions:
              - condition: state
                state: 'on'
            chip:
              type: template
              tap_action:
                action: none
              icon_color: |-
                 orange
                {% elif is_state(entity, 'off') %}
                 grey
                {% else %}
                 grey
                {% endif %}
              hold_action:
                action: none
              double_tap_action:
                action: none
          - type: conditional
            conditions:
              - condition: state
                entity: switch.prise_connectee_mystrom
                state: 'on'
            chip:
              type: template
              tap_action:
                action: none
              icon_color: |-
                 orange
                 grey
                {% else %}
                 grey
                {% endif %}
              icon: mdi:power-socket-eu
              hold_action:
                action: none
              double_tap_action:
                action: none
          - type: conditional
            conditions:
              - condition: state
                entity: switch.prise_salle_a_manger
                state: 'on'
            chip:
              type: template
              icon_color: |-
                 orange
                 grey
                {% else %}
                 grey
                {% endif %}
              tap_action:
                action: none
              hold_action:
                action: none
              double_tap_action:
                action: none
        card_mod:
          style:
              ha-card {
                width: 66px;
                margin-left: 85%;
                top: -170px;
                background: none;
    card_mod:
      style: |
        ha-card {
          height: 178px ;
          margin-left: auto;
          margin-right: auto;
          background-image: url(https://i.ibb.co/rmk15p2/salle-a-manger.png);
    cards:
        entity: light.cuisine
        icon: mdi:pot-steam
        icon_color: |
          {% if is_state('light.cuisine', 'on') %}
            #FFAE0080
          {% else %}
            #0000
          {% endif %}
        primary: Cuisine
        layout: horizontal
        tap_action:
          action: more-info
        double_tap_action:
          action: none
        hold_action:
          action: none
        badge_icon: |+
        badge_color: |+
        card_mod:
          style:
              .primary {
                position: relative;
                top: -50px;
                left: -155px;
                width: 55%;
              .secondary {
                position: relative;
                top: -49px;
                left: -155px;
              .shape {
                position: relative;
                left: -43px;
                top: 55px;
              :host {
            style: |
                left: 60px;
                top: 25px;
              ha-card {
                background: none;
        secondary: ''
        chips:
          - type: conditional
            conditions:
              - condition: state
                state: 'on'
            chip:
              type: template
              tap_action:
                action: none
              icon: mdi:vanity-light
              icon_color: |-
                 orange
                 grey
                {% else %}
                 grey
                {% endif %}
              hold_action:
                action: none
              double_tap_action:
                action: none
          - type: conditional
            conditions:
              - condition: state
                entity: light.plan_de_travail
                state: 'on'
            chip:
              type: template
              icon_color: |-
                 orange
                 grey
                {% else %}
                 grey
                {% endif %}
              tap_action:
                action: none
              hold_action:
                action: none
              double_tap_action:
                action: none
        card_mod:
          style:
              ha-card {
                width: 66px;
                margin-left: 85%;
                top: -170px;
                background: none;
    card_mod:
      style: |
        ha-card {
          height: 178px ;
          margin-left: auto;
          margin-right: auto;
          background-image: url(https://i.ibb.co/19NXD2Z/cuisine.png);
  - type: custom:popup-card
    dismissable: true
    card:
      type: vertical-stack
      cards:
        - type: custom:mushroom-light-card
          show_brightness_control: true
          use_light_color: true
          show_color_control: false
          collapsible_controls: true
          show_color_temp_control: true
        - type: custom:mushroom-alarm-control-panel-card
          states:
            - armed_away
            - armed_night
        - type: custom:mushroom-media-player-card
    title: La salon
    dismissable: true
    card:
      cards:
          name: ' La salle a manger'
        - type: horizontal-stack
          cards:
            - type: custom:mushroom-entity-card
              icon: mdi:power-socket-fr
              name: Prise salle Ć  manger
              double_tap_action:
                action: none
              hold_action:
                action: none
              tap_action:
                action: toggle
              tap_action:
                action: toggle
              hold_action:
                action: none
              double_tap_action:
                action: none
    title: La salle a manger
    dismissable: true
    card:
      cards:
          name: ' La cuisine'
          name: ' Le plan de travail'
    title: La cuisine
Can anybody help me out with this, please?
I am unable to make this work :frowning:
And I cannot find any other solution to text_box contents that are too long for the field :frowning:
I had this code working fine in a mushroom template card, but after the latest update I canā€™t change the color or the font size. I have been searching but could not find a solution.
Any help, please?
card_mod:
  style: |
    ha-card {
      --primary-text-color: white;
      --secondary-text-color: white;
      --title-font-size: 30px;
      --subtitle-font-size: 15px:
There were a few changes with the 3.4.1 update and you had a colon vs a semi-colon.
card_mod:
  style: |
    ha-card {
      --card-primary-color: white !important;
      --card-secondary-color: white !important;;
     --subtitle-font-size: 15px;
check out this topic for direct Mushroom card info.
@xlyralycanx I like your theme. I added a simple fan animation to the theme. I thought it may help you address your formatting and get your animation working.
Test Theme:
  modes:
    dark:
      accent-color: '#cc7000'
    light:
  card-mod-theme: Test Theme
      #.menu .title {
       # font-family: Dancing Script;
      #a[data-panel='panel'] paper-icon-item .item-text {
        #font-size: 26px;
      #.spacer {
       # background: center / cover url("/local/media/images/christmasdecor.png");
        color: #cc7000 !important;
        color: #cc7000;
        color: #000080 !important;
        #color: #000080;
        color: #000080;
        color: #cc7000;
      #a[data-panel='map'] paper-icon-item ha-svg-icon {
       # color: #000080 !important;
      #a[data-panel='map'] paper-icon-item .item-text {
        #color: #000080;
      #a[data-panel='history'] paper-icon-item ha-svg-icon {
        #color: #cc7000 !important;
      #a[data-panel='history'] paper-icon-item .item-text {
        #color: #cc7000;
        color: #cc7000;
        color: #cc7000;
      #a[data-panel='media-browser'] paper-icon-item ha-svg-icon {
        #color: #000080 !important;
      #a[data-panel='media-browser'] paper-icon-item .item-text {
        #color: #000080;
        color: #cc7000;
      #a[data-panel='config'] paper-icon-item ha-svg-icon {
      #a[data-panel='config'] paper-icon-item .item-text {
        #color: #000080;
        color: #cc7000;
        color: #cc7000;
        #color: #000080;
  card-mod-card: |
    ha-card {
        border: none !important;
        background-color: none !important;
        --mdc-icon-size: 26px;
        --shape-color: none !important;
        --title-font-weight: 200;
        --card-primary-font-weight:300;
        --title-font-size: 16px;
        --title-padding: 12px 12px 4px;
        border-radius: 4px !important;
        box-shadow: none !important;
        --card-secondary-line-height: 11px !important;
        --card-secondary-font-size: 11px !important;
        --mush-icon-symbol-size: 38px;
        --control-height: 36px;
    :host {
        --rgb-primary-text-color: none !important;
  card-mod-row-yaml: |
    "*:first-child$": |
      @keyframes spin {
        0% {
          transform: rotate(0deg);
        100% {
          transform: rotate(359deg);
      @keyframes spinr {
        0% {
        100% {
          transform: rotate(-359deg);
      state-badge {
        {% if config.entity.startswith('fan.') and is_state('sensor.fan_direction', 'forward') %}
          animation: spin 3s infinite linear, coloring 8s linear infinite alternate;
        {% else %}
         animation: spinr 3s infinite linear, coloring 8s linear infinite alternate;
        {% endif %}
      @keyframes coloring {
            0% {
              color: red;
            17% {
              color: orange;
            34% {
              color: yellow;
            51% {
              color: green;
            68% {
              color: lightblue;
            85% {
              color: blue;
            100% {
              color: violet;
Here is one sidebar icon spinning
Test Theme:
  modes:
    dark:
    light:
        animation: spin 3s infinite linear;
      @keyframes spin {
        0% {
        100% {
Hello everyone,
Please correct me if Iā€™m in the wrong spot for this question!!
I recently updated Card Mod to the latest version, which didnā€™t break anything except for one single area where Iā€™m highlighting the 'Real Feel" temperature.
For some reason, the ā€œJustify-Contentā€ area is VERY squished, and I canā€™t seem to figure out how to adjust it so it shows and fills the whole area.
If I modify the HTML and make the ā€œJustify-Contentā€ 50px, it looks great! But it is defaulting to 20px, and I canā€™t seem to edit this from the Card_Mod configurationsā€¦
Below is my YAML for the card:
card:
  square: false
  columns: 1
  type: grid
  cards:
    - type: custom:layout-card
      layout_type: custom:grid-layout
      cards:
        - type: custom:weather-card
          entity: weather.home
          forecast: false
          details: false
          current: true
          card_mod:
            style: |
              ha-card {
                background: none;
                border: none;
                --font-size: 10px;
                text-align: left;
          fill_container: true
          primary: '{{ states(''sensor.home_realfeel_temperature'') }} Ā°C'
          secondary: Real Feel
          card_mod:
            style: |
              ha-card {
                --card-primary-font-size: 50px;
                --card-secondary-font-size: 15px;
                --card-primary-line-height, 50px;
                background: none;
                border: none;
                text-align: center;
      layout:
        grid-template-columns: 55% auto
        grid-template-rows: auto
Also below is a screenshot of the card with the issue, as well as some of the HTML for visibility.
Any help would be greatly appreciated! Many of you are much smarter than I, so Iā€™m hoping someone here knows the solution!
You have a typo
should be
--card-primary-line-height: 50px;
Could anyone advise on how to hide/remove the three stacked lines as seen below from the top left of the Lovelace dashboard? Could this be achieved using Card-mod?
Solution of customizing this button was posted here.
Here is how to find it:
huge card-mod thread ā†’ 1st post ā†’ link at the bottom ā†’ themes ā†’ sidebar
Now try to hide this button with ā€œdisplay: noneā€.
Oh manā€¦i canā€™t believe this whole thing was a simple typoā€¦
Thank you so much for catching this for me!! You have cured my headache!:pray:
Given that a try & unfortunately it doesnā€™t seem to work. Unless Iā€™m missing something.
card-mod-root-yaml: |
      .header .toolbar .action-items {
        display: none;
Iā€™m using this dashboard on a tablet. So donā€™t want users to be able to get to other parts of HA that they shouldnā€™t via the menu. So by removing this it just gives access to only what they need.
Can you see a difference?
