bribbon
February 12, 2020, 7:35pm
1
I d’like a radial-menu on my floorplan. The menu should be placed directly in the middle of the room. I do not succeed in realizing this and am glad about every input.
I could make a floor plan with equipment on it but a radial menu does not work.
early floorplan (type: pictures-elements):
I would like to visualize this menu (type: ‘custom:radial-menu’):
Lovelace Radial Menu Element
thanks for your support
bribbon
@iantrich
bribbon
February 12, 2020, 7:54pm
2
My test “radial-menu” looks like this if it is open.
How can I get two different “type” on one card?
type: picture-element (floorplan)
type: custom:radial-menu
iantrich
(Ian)
February 13, 2020, 4:39am
3
You should be able to just add it as an element. What did you try? Share your config.
bribbon
February 13, 2020, 9:06am
4
Hey,
I’doing that over the GUI Interface, because I was not able to include ui-lovelace.yaml. If I include the ui-lovelace to my config I’m getting the message “Deprecated” on the lovelace. Actually I want to do this with the editor (VSC), so I learn a lot more…
Here are my two examples. First the code of the floorplan which I realized as a picture-element.
elements:
- entity: light.buro_decke
style:
left: 36%
top: 66%
tab_action:
action: toggle
type: state-icon
- entity: media_player.radio_buro
filter: brightness(5%)
image: /local/radio.png
state_filter:
playing: brightness(100%)
style:
left: 40%
top: 66%
width: 5%
tap_action:
action: call-service
service: media_player.media_play_pause
service_data:
entity_id: media_player.radio_buro
type: image
- entity: media_player.radio_kuche
state_filter:
style:
left: 45%
top: 66%
width: 5%
tap_action:
service_data:
entity_id: media_player.radio_kuche
type: image
- entity: weather.home
prefix: 'Aussentemperatur '
style:
left: 15%
top: 5%
tab_action:
action: navigate
navigation_path: /lovelace/default_view
type: state-label
- entity: sensor.rt_ac68u_kb_sec_received
style:
color: orange
left: 35%
top: 8%
tab_action:
action: navigate
type: state-label
- entity: sensor.rt_ac68u_kb_sec_sent
style:
color: pink
left: 35%
top: 6%
tab_action:
action: navigate
type: state-label
- entity: sun.sun
prefix: 'Sonnenstand '
style:
left: 70%
top: 6%
tab_action:
action: navigate
type: state-label
- entity: script.1581374463208
prefix: 'Alle Lampen '
style:
left: 50%
top: 95%
tab_action:
service: script.1581374463208
type: state-label
image: /local/floorplan_2.png
type: picture-elements
Below is my attempt code for the radial-menu:
I want to display this menu in every room on the floorplan.
type: 'custom:radial-menu'
icon: 'mdi:dots-horizontal-circle'
default_open: false
default_dismiss: false
items:
icon: 'mdi:radio'
tap_action:
action: toggle
haptic: true
icon: 'mdi:ceiling-light'
tap_action:
action: toggle
haptic: true
thanks!
bribbon
February 13, 2020, 8:43pm
5
Yippee, with your tip, I just managed to do it.
I had tried several times to insert the type: 'custom:radial-menu in the picture elements card. The mistake was that I always inserted the radial menu code at the end. The code must be at the beginning, before the type: picture-elements begins, in which the rest of the floorplan & devices are located… Then it works.
Now I can go into detail and integrate several devices into it. Thanks
-> solved
elements:
- type: 'custom:radial-menu'
default_dismiss: true
default_open: false
style:
left: 36%
top: 66%
items:
icon: 'mdi:radio'
tap_action:
action: more-info
haptic: true
tap_action:
action: more-info
haptic: true
- entity: switch.shelly_shsw_pm_f2fb98
icon: 'mdi:radiator.png'
tap_action:
action: toggle
haptic: true
style:
left: 15%
top: 66%
tab_action:
action: toggle
type: state-icon
state_filter:
style:
left: 70%
top: 66%
width: 5%
tap_action:
service_data:
type: image
state_filter:
style:
left: 75%
top: 66%
width: 5%
tap_action:
service_data:
type: image
style:
left: 15%
top: 5%
tab_action:
action: navigate
type: state-label
style:
color: orange
left: 35%
top: 8%
tab_action:
action: navigate
type: state-label
style:
color: pink
left: 35%
top: 6%
tab_action:
action: navigate
type: state-label
- entity: sun.sun
style:
left: 70%
top: 6%
tab_action:
action: navigate
type: state-label
style:
left: 50%
top: 95%
tab_action:
type: state-label
@iantrich - is it possible to resize the icons? I haven’t had much luck with
icon: 'fas:couch'
style:
left: 15%
top: 20%
width: 10%
size: 20% #(also tried px)
