Due to the Lutron Caseta non-pro hub no longer working, I made a workaround configuration to control my lights that relies heavily on IFTTT. It’s a hassle because you have to make two IFTTT applets for every light switch you have (one for on and one for off).
Works for me as well! Took a little bit of figuring.
Here’s what I did, in case it helps someone else. I set up an ifTTT with event name basement_off and then did the following in my config:
- alias: Turn off basement light 10 minutes after last movement
platform: state
entity_id: binary_sensor.vistacam_700_motion_sensor_18
to: 'off'
for:
minutes: 10
service: ifttt.trigger
event: basement_off
value1: off
This doesn’t update the status of the switch (yet), but it appears that’s possible by having IFTTT call back to HASS and then updating the input_boolean.
[UPDATE]: Looks like non-media third-party devices integrated in to Harmony Hub (such as lights), are not accessible or visible via HA, only the media devices and actions. Not sure why this is, but if anyone has suggestions (until Lutron Caseta can be fixed directly) please reply…
[UPDATE 2]: Also, looks like the HomeBridge Harmony Hub plug in is getting some update love and may be getting more stable, fyi…
Another workaround option I’m exploring is to use my Harmony Hub, as a bridge. I’ll be digging in to this further and will share any specifics I can, but I’m really just gleaning info from other posts on how to access/control Devices connected to the Harmony Hub. Use the remote: component to send commands to Harmony Hub to control Devices (such as my Lutron Caseta dimmer switches), using HASS Template Switches as a mechanism. This is in addition to accessing Activities on my Harmony. My real goal is to have my Activities available via HomeKit and Siri, as the Harmony Hub functionality of Homebridge is flaky and crashes Homebridge often, but I digress…
Since it appears Caseta integration with Harmony, and 2GIG Go Control panel (and Alarm.com) are still functional I’m hopeful some of the other efforts to get direct integration working again in HASS are achievable.
I’ve got it working with my Vera device. http://forum.micasaverde.com/index.php?topic=35577.0
Not sure if anyone wants to dig into his source to get the answer, but he got it working somehow. Needs the luton username/password to function.
The work around talked about on this thread worked for me, and sounds as though its being prepared for roll-out (so it won’t require custom components).
