I previously posted a blueprint for Pico to ZHA lights. I recently transitioned to Z2M / Zigbee2MQTT for my lights, and I wanted to write a similar blueprint for Zigbee2MQTT as I wanted smooth dimming for those lights as well. The blueprint includes a cluster command to stop dimming, which is why it needs to be implementation-dependent. The lights will receive a start dimming command with the duration specified and then a stop dimming command when the button is released.
The original blueprint used stephack’s blueprint for pico remotes and then this blueprint builds on top of that. Zigbee2MQTT is a little easier to use as it uses the same integration for sending cluster commands to Zigbee groups and individual lights.
You may notice a slight pop effect at the end of a dimming sequence with a Zigbee group as the integration waits for a second before reading in the brightness and setting all of the bulbs to the same level. By default, the middle button doesn’t do anything, but it is exposed in case you want to implement something for it. I like to use it to toggle a lamp or turn Christmas tree lights on and off or set a scene like movie theater mode.
As mentioned in the previous post, I still have the modified joshcarter’s 3D printed Pico wall mount for a more solid feel, which I posted here.
blueprint:
name: Z2M - Pico Config
description: "This is for the 5 button picos that have the following model:\n\n
PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)\n\nSelect the pico and light to use below"
domain: automation
input:
pico_remote:
description: 'Select the pico remote to configure:'
selector:
device:
model: PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)
multiple: false
light:
description: "Select the light to control.\nIf using a group, select the main light for matching brightness:"
selector:
entity:
multiple: false
z2m_friendly_name:
name: Z2M Friendly Name
description: "Friendly name in Zigbee2MQTT - Can be group or individual light"
default: []
dimming_speed:
description: 'Input the dimming speed to go from 0 to 100%'
default: 5
turn_on_speed:
name: Turn On Speed
description: 'Input the time to turn on the light'
default: 0
turn_off_speed:
name: Turn Off Speed
description: 'Input the time to turn off the light'
default: 2
auto_mode:
description: Mode that automation runs in (single, restart, queued, parallel).
default: restart
selector:
select:
options:
- single
- restart
- queued
- parallel
multiple: false
custom_value: false
mode_max:
name: Mode Max (ignored by Single and Restart Modes)
description: Maximum number of runs that can be executed or queued at a time.
default: 10
selector:
number:
min: 1.0
max: 15.0
mode: slider
step: 1.0
middle_stop:
name: Middle (Fav) Button Pressed
description: Execute when MIDDLE button is PRESSED
default: []
selector:
action: {}
middle_stop_release:
name: Middle (Fav) Button Released
description: Execute when MIDDLE button is RELEASED
default: []
selector:
action: {}
variables:
light_entity: !input light
dimming_speed: !input dimming_speed
z2m_friendly_name: !input z2m_friendly_name
turn_off_speed: !input turn_off_speed
- platform: device
device_id: !input pico_remote
domain: lutron_caseta
type: press
subtype: 'on'
- platform: device
type: press
subtype: raise
- platform: device
type: press
subtype: stop
- platform: device
type: press
subtype: lower
- platform: device
type: press
subtype: 'off'
- platform: device
type: release
subtype: 'on'
- platform: device
type: release
subtype: raise
- platform: device
type: release
subtype: stop
- platform: device
type: release
subtype: lower
- platform: device
type: release
subtype: 'off'
condition: []
- choose:
- conditions: '{{ trigger.event.data.action == "press" }}'
sequence:
- choose:
- conditions: '{{ trigger.event.data.button_number == 5 }}' #up_raise
sequence:
- service: mqtt.publish
topic: zigbee2mqtt/{{z2m_friendly_name}}/set
payload: |-
"command": {
"cluster": 8,
"command": 3,
"payload": {}
topic: zigbee2mqtt/{{z2m_friendly_name}}/get
payload: |-
{"brightness": ""}
- service: light.turn_on
brightness: 255
transition: >-
{{(((255-(state_attr(light_entity, 'brightness') | int(0)))/255)*(dimming_speed|float(5)-0.1))+0.1}}
entity_id: >
{{light_entity}}
- conditions: '{{ trigger.event.data.button_number == 3 }}'
sequence: !input middle_stop
- conditions: '{{ trigger.event.data.button_number == 6 }}' #down_lower
sequence:
payload: |-
"command": {
"cluster": 8,
"command": 3,
"payload": {}
payload: |-
{"brightness": ""}
- if:
- condition: not
conditions: >
{{is_state(light_entity, 'off')}}
then:
brightness: 4
transition: >-
{{(((state_attr(light_entity, 'brightness') | int(0))/255)*(dimming_speed|float(5)-0.1))+0.1}}
entity_id: >
{{light_entity}}
- conditions: '{{ trigger.event.data.action == "release" }}'
sequence:
- choose:
- conditions: '{{ trigger.event.data.button_number == 2 }}' # top_on_release
sequence:
payload: |-
"command": {
"cluster": 8,
"command": 3,
"payload": {}
brightness: 255
transition: !input turn_on_speed
entity_id: >
{{light_entity}}
sequence: !input middle_stop_release
- conditions: '{{ trigger.event.data.button_number == 6 or trigger.event.data.button_number == 5 }}' # down_lower_release or up_raise_release
sequence:
- if:
- alias: "Test for off"
condition: template
value_template: >
{{is_state(light_entity, 'on')}}
then:
payload: |-
"command": {
"cluster": 8,
"command": 3,
"payload": {}
payload: |-
{"brightness": ""}
qos: "2"
- delay:
seconds: 1
brightness: >
{{state_attr(light_entity, 'brightness')}}
entity_id: >
{{light_entity}}
- conditions: '{{ trigger.event.data.button_number == 4 }}' # bottom_off_release
sequence:
- service: light.turn_off
transition: '{{ turn_off_speed - 0.2 }}'
entity_id: >
{{light_entity}}
default: []
mode: !input auto_mode
max: !input mode_max
