This blueprint is based on stephack’s Lutron Caseta Pico Blueprint and requires ZHA Toolkit in order to work. ZHA Toolkit can be found through HACS as one of the repositories in the default list. Thank you to both for creating great integrations!
ZHA Group Update: This blueprint now supports ZHA groups. If you want to control multiple bulbs at the same time, you can select a main bulb, the group’s entity ID, the group number, and the group entity ID. If you don’t enter a group entity ID, then the blueprint will ignore the group control part of the blueprint and just control a single light. The Groups supported are the groups found in settings → devices and services → configure (on ZHA) → groups. This blueprint will use the native Zigbee group commands to keep the lights in sync and to reduce the total number of commands needed. I have this bluepint set to control all of the Zigbee bulbs in my living room in parallel with a native pico to caseta dimmer, and the Zigbee lights act as if they are connected to the same control sequence. Even when using a group, an entity ID of a single light in the group is used to sync the brightness at the end of a dimming sequence as some bulb manufacturers have slight variations on how quickly they will start and stop dimming.
I wanted to be able to use a pico remote to control some of my Zigbee bulbs, but I didn’t want them to act differently from my Caseta dimmers. This blueprint uses cluster commands through ZHA Toolkit to stop in-progress dimming and to read back the state in order to mimic the smooth dimming seen in Caseta dimmers. I left the middle button alone. You can set a favorite brightness like on the original remote or you can use it for any function you like.
In the Caseta app, you can unpair the pico remote from your dimmer by tapping on it → going to edit device → select devices → uncheck the original dimmer and save.
I also modified joshcarter’s 3D printed Pico wall mount for a more solid feel and posted it here.
You should be able to import the blueprint through either clicking on the button below or by copying and pasting the blueprint into a .yaml file in your blueprint folder.
blueprint:
name: ZHA - Pico Config
description: "This is for the 5 button picos that have the following model:\n\n
PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)\n\nSelect the pico and light to use below"
domain: automation
input:
pico_remote:
description: 'Select the pico remote to configure:'
selector:
device:
model: PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)
multiple: false
light:
description: "Select the light to control.\nIf using a group, select the main light for matching brightness:"
selector:
entity:
multiple: false
group_entity:
name: Zigbee Group Entity ID
description: "Optional - Entity ID for the ZHA group you wish to control"
default: []
selector:
entity:
multiple: false
zha_group:
name: ZHA Group Number
description: "Optional - If using a group, set this to the matching group number from the ZHA interface. Otherwise, leave blank"
default: []
dimming_speed:
description: 'Input the dimming speed to go from 0 to 100%'
default: 5
turn_on_speed:
name: Turn On Speed
description: 'Input the time to turn on the light'
default: 0
turn_off_speed:
name: Turn Off Speed
description: 'Input the time to turn off the light'
default: 2
auto_mode:
description: Mode that automation runs in (single, restart, queued, parallel).
default: restart
selector:
select:
options:
- single
- restart
- queued
- parallel
multiple: false
custom_value: false
mode_max:
name: Mode Max (ignored by Single and Restart Modes)
description: Maximum number of runs that can be executed or queued at a time.
default: 10
selector:
number:
min: 1.0
max: 15.0
mode: slider
step: 1.0
middle_stop:
name: Middle (Fav) Button Pressed
description: Execute when MIDDLE button is PRESSED
default: []
selector:
action: {}
middle_stop_release:
name: Middle (Fav) Button Released
description: Execute when MIDDLE button is RELEASED
default: []
selector:
action: {}
variables:
light_entity: !input light
dimming_speed: !input dimming_speed
zha_group: !input zha_group
group_entity: !input group_entity
turn_off_speed: !input turn_off_speed
- platform: device
device_id: !input pico_remote
domain: lutron_caseta
type: press
subtype: 'on'
- platform: device
type: press
subtype: raise
- platform: device
type: press
subtype: stop
- platform: device
type: press
subtype: lower
- platform: device
type: press
subtype: 'off'
- platform: device
type: release
subtype: 'on'
- platform: device
type: release
subtype: raise
- platform: device
type: release
subtype: stop
- platform: device
type: release
subtype: lower
- platform: device
type: release
subtype: 'off'
condition: []
- choose:
- conditions: '{{ trigger.event.data.action == "press" }}'
sequence:
- choose:
- conditions: '{{ trigger.event.data.button_number == 5 }}' #up_raise
sequence:
- if: '{{ zha_group != []}}'
then:
- service: zha.issue_zigbee_group_command
cluster_id: 8
command: 3
else:
- service: zha_toolkit.execute
ieee: !input light
cluster: 8
cmd: 3
command: zcl_cmd
- service: zha_toolkit.attr_read
cluster: 8
ieee: !input light
attribute: 0
state_id: >
{% if zha_group != [] %}
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
state_attr: brightness
- service: light.turn_on
brightness: 255
transition: >-
{{(((255-(state_attr(group_entity, 'brightness') | int(0)))/255)*(dimming_speed|float(5)-0.1))+0.1}}
{% else %}
{{(((255-(state_attr(light_entity, 'brightness') | int(0)))/255)*(dimming_speed|float(5)-0.1))+0.1}}
{% endif %}
entity_id: >
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
- conditions: '{{ trigger.event.data.button_number == 3 }}'
sequence: !input middle_stop
- conditions: '{{ trigger.event.data.button_number == 6 }}' #down_lower
sequence:
then:
cluster_id: 8
command: 3
else:
ieee: !input light
cluster: 8
cmd: 3
command: zcl_cmd
cluster: 8
ieee: !input light
attribute: 0
state_id: >
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
- if:
- condition: not
conditions: >
{{is_state(group_entity, 'off')}}
{% else %}
{{is_state(light_entity, 'off')}}
{% endif %}
then:
brightness: 4
transition: >-
{{(((state_attr(group_entity, 'brightness') | int(0))/255)*(dimming_speed|float(5)-0.1))+0.1}}
{% else %}
{{(((state_attr(light_entity, 'brightness') | int(0))/255)*(dimming_speed|float(5)-0.1))+0.1}}
{% endif %}
entity_id: >
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
- conditions: '{{ trigger.event.data.action == "release" }}'
sequence:
- choose:
- conditions: '{{ trigger.event.data.button_number == 2 }}' # top_on_release
sequence:
then:
cluster_id: 8
command: 3
else: # Not using a group
ieee: !input light
cluster: 8
cmd: 3
command: zcl_cmd
brightness: 255
transition: !input turn_on_speed
entity_id: >
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
sequence: !input middle_stop_release
- conditions: '{{ trigger.event.data.button_number == 6 or trigger.event.data.button_number == 5 }}' # down_lower_release or up_raise_release
sequence:
- if:
- alias: "Test for off"
condition: template
value_template: >
{{is_state(group_entity, 'on')}}
{% else %}
{{is_state(light_entity, 'on')}}
{% endif %}
then:
then:
cluster_id: 8
command: 3
else:
ieee: !input light
cluster: 8
cmd: 3
command: zcl_cmd
cluster: 8
ieee: !input light
attribute: 0
state_id: >
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
then:
brightness: >
{{state_attr(group_entity, 'brightness')}}
{% else %}
{{state_attr(light_entity, 'brightness')}}
{% endif %}
entity_id: !input group_entity
- conditions: '{{ trigger.event.data.button_number == 4 }}' # bottom_off_release
sequence:
then:
cluster_id: 8
command: 3
ieee: !input light
cluster: 8
cmd: 3
command: zcl_cmd
brightness: 1
transition: !input turn_off_speed
entity_id: >
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
- if: '{{ (turn_off_speed - 0.2) > 0 }}'
then:
- delay:
seconds: '{{ turn_off_speed - 0.2 }}'
- service: light.turn_off
entity_id: >
{{group_entity}}
{% else %}
{{light_entity}}
{% endif %}
default: []
mode: !input auto_mode
max: !input mode_max
