A few devices are already working for a while now. We just need help with the implementation of the missing devices over at pyhomematic. And you are right, they are delivered on port 2010. If you configure a host to use that port you will get the HASS entities for devices which are already supported.
Great!
I just got some Homematic IP ready devices at home but no CCU or IP access point yet. When I do I will look into implementing any missing devices in pyhomematic.
When yóu’re ready this may help you to get started.
PS: For Home Assistant you need the CCU. I’m unsure if the IP Access Point has the same XML-RPC API, which is what is used to communicate with the devices.
Is this supported?
Little confused about supported/not supported devices …
I read in changelog https://github.com/danielperna84/pyhomematic/blob/master/changelog.txt:
Version 0.1.22 (2017-02-14)
- Added support for HMIP-eTRV (Homematic IP Thermostat) @braindump
I bought two homematic thermostats for testing HM-CC-RT-DN and HmIP-eTRV-2
These devices are connected to RaspberryMatic 2.29.22.20170902 and both working
Homeassistant 0.53.1 config:
homematic:
hosts:
wired:
ip: 192.168.1.58
resolvenames: json
username: user
password: pass
Only HM-CC-RT-DN is showing up in homeassistant and works well.
But HmIP-eTRV-2 does not show up
Is HmIP-eTRV-2 simply not supported or am i doing something wrong ?
There is a difference between HmIP-eTRV (the supported one) and HmIP-eTRV-2. Maybe not technically, but pyhomematic needs to explicitly know about your version. It will probably work if you make a small change to the pyhomematic library your HASS is using. There should be a file called thermostats.py
in the deps/pyhomematic/devicetypes/
folder. Duplicate the line with "HMIP-eTRV": IPThermostat,
and add the -2
to your duplicate. After restarting HASS you should get the thermostat.
If HMIP-eTRV-2
doesn’t work, try with HmIP-eTRV-2
(small m). EQ3 is not being consistent with how they are naming the devices.
im running homeassistant in docker - hass.io
The deps dir in config is emty.
Where do i find deps/pyhomematic/devicetypes/ folder ?
thanks
I think in case of hassio it is not possible to manually patch the required file. Is it possible for you to set up a VM for testing this out in a test-environment? There you’d only have to configure the homematic component and see if the devices shows up in the UI after applying the change I have mentioned above.
I’m 99% sure that all we need is adding the extra name of the device. But as said before, EQ3 sometimes is not consistent with the naming, so I don’t want to take the chance and just try it out and create an extra version for every variation.
just tried:
https://home-assistant.io/developers/component_loading/
But its seems pyhomematic is in /usr/lib/python3.6/site-packages/pyhomematic
and not in /usr/lib/python3.6/site-packages/homeassistant/components
another way to patch this file i have overseen ?
if no i will install a test-homeasistant tomorrow without hass-io and give it a try
Components are the parts of HASS that provide the needed functionality. In case of Homematic it needs the pyhomematic library, which handle the communication with the CCU. And thr problem with your thermostat is, that pyhomematic does not know about your thermostat. Hence that’s where the patching has to be done.
I haven’t worked much wit hassio, so I don’t know if there’s a workaround. But I think there is none. So to my knowledge there’s no other way than having a separate testing environment.
working !
HmIP-eTRV-2 Firmware-Version:1.6.3
configuration.yaml :
homematic:
hosts:
wireless:
ip: 192.168.1.58
resolvenames: json
username: user
password: pass
ip:
ip: 192.168.1.58
resolvenames: json
username: user
password: pass
port: 2010
thermostats.py :
DEVICETYPES = {
"HM-CC-RT-DN": Thermostat,
"HM-CC-RT-DN-BoM": Thermostat,
"HM-TC-IT-WM-W-EU": ThermostatWall,
"HM-CC-TC": ThermostatWall2,
"ZEL STG RM FWT": ThermostatWall2,
"BC-RT-TRX-CyG": MAXThermostat,
"BC-RT-TRX-CyG-2": MAXThermostat,
"BC-RT-TRX-CyG-3": MAXThermostat,
"BC-RT-TRX-CyG-4": MAXThermostat,
"BC-RT-TRX-CyN": MAXThermostat,
"BC-TC-C-WM-2": MAXWallThermostat,
"BC-TC-C-WM-4": MAXWallThermostat,
"HmIP-eTRV-2": IPThermostat,
"HmIP-STHD": IPThermostatWall
States in homeassistant:
assumed_state: false
current_temperature: 18
id:
temperature: 17
operation_list: boost
operation_mode: auto
min_temp: 4.5
mode: Auto
max_temp: 30.5
rssi: -23
proxy: ip
unit_of_measurement: °C
friendly_name: HmIP-eTRV-2
valve: 2
Setting temperature in homeassistant is working.
But in homeassistant HmIP-eTRV-2 only shows: operation_list: boost
and no battery in states.
HM-CC-RT-DN - operation_list: boost,manual,comfort,lowering,auto
battery: 3.2
thats disappointing - battery and other modes not implemented ?
Working partly
Homeassistant log:
2017-09-18 10:44:22 ERROR (Thread-9) [pyhomematic.devicetypes.generic] HMGeneric.getValue: CONTROL_MODE on 000xxxxxxxxxx:1 Exception: <Fault -5: ‘Unknown Parameter value for value key: CONTROL_MODE’>
Good to hear that basic functionality is working. As for the control-modes: until now nobody has taken care of the different modes for IP devices. If you want to you can fork pyhomematic and work on the implementation.
I think i wasted my time with HmIP-eTRV-2
bought it for test and compare it to HM-CC-RT-DN and have a look in the ‘world’ of EQ-3 devices
EQ-3 sent a HmIP-eTRV-2 with nearly one year old firmware with bugs - updating firmware took 18h …
HmIP-eTRV-2 cost about 15% more
HM-CC-RT-DN worked out of the box with temperatureprofile for week - HmIP-eTRV-2 results in renaming my office-room to sauna …
HM-CC-RT-DN is exactly doing what i want since last days and is working in homeassistant/iobroker/RaspberryMatic
I think u should remove HmIP-eTRV-2 from device list cause in homeassistant it does not show battery state and valve attribute is always at 4 - no change when i manually set OFF or BOOST - in RaspberryMatic it returns corect values
The main features of a thermostat are setting a target temperature and reading the current temperature. Are those two values correct? If so, I would keep it. The other values can be fixed later on. The battery level is missing from a lot of devices since it hasn’t been implemented. A few missing values are no dealbreaker if the main functionality is provided. After all this is open source, so anybody who wants to fix these minor issues is free to do just that.
Yes, both values are correct - setting boost also working
I will send back the divice on friday - if u like i could do some tests on codechanges (my knowledge in python is very basic)
No, I will leave it as it is for now. If someone needs more functionality, then we will take care of it.
I had the same problem, and I wanted the operation mode of the hmip-etrv-2 to work in HASS.
I also fixed that the voltage and battery low/high is shown correctly in HASS
I created a PR here and at pyhomematic:
Quick question here. I use Homematic at home and have a CCU2.
Also, I am very new to HA.
So in my config.yaml I wrote:
homematic:
interfaces:
wireless:
host: <ccu-ip-address>
After restarting HA, everything was there. Great.
Now today I got myself a HmIP-eTRV-2 and it’s connected to my CCU2 and works there. Now I thought it will automatically show up in HA. But that’s not the case.
So I am wondering what I need to do. Do I need to extend my config file? But as it’s connected to the CCU I though that should be enough?!?
Any help is greatly appreciated!
Cheers, Georg
