Hi, I’m using HA as an alarm clock via automation, using something like this:
- alias: Wake up
platform: time
after: '07:00:00'
service: script.turn_on
entity_id: script.wakeup
I’d like to combine it with data coming from an Input Select to have after parametrized instead of hardcoded into the configuration, to avoid a config change and a restart any time I want to edit the wake up time, but if I understand it correctly, the only dynamic config content is available through the value_template properly.
Is there currently any other way to achieve this? Thanks
For now, only thing you can do is create multiple automations, and put condition based on the value of the input_select component.
Something like this:
